Cylinder 1 Misfire - Mustang Evolution
Old 03-26-2016, 11:47 AM   #1
Cylinder 1 Misfire
Hey guys,
So I've been getting a cylinder 1 misfire code for months now and cannot figure it out. I don't even feel it when it happens while I'm driving. here a background on what I've done so far.
1. Compression test was fine. all cylinders were within .15 of the highest reading.
2. Brand new MSD coil packs
3. Brand new Wires
4. Spark plugs are relatively new with maybe 1000 miles on them. I switched spark plug 1 and 2 to see if the misfire moved, but it stayed on cylinder 1
5. It has the stock injectors in her, this is the only thing i haven't replaced yet.
The car is a 1996 Gt (Saleen) with 104,000 miles on her. PI heads and cams, Kooks LT headers with hi flow cats. CAI with 75mm throttle body. 3:5:5 rear gears. And a BAMA tune.
Ive read a couple forums with similar issues and haven't seen many get resolved, Does anyone have any ideas? Thanks a lot.
96saleen is offline   Reply With Quote
Old 03-26-2016, 02:59 PM   #2
Mile high JDF's Avatar
Have you swapped plug wires from 1 and 2? Also try swapping injectors from 1 and 2.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-02-2016, 05:36 PM   #3
Tried switching the injectors...still getting a misfire, I will try the wires tonight
Old 04-02-2016, 06:21 PM   #4
Alright. If that still doesn't fix it try swapping the coil packs after that.
Old 04-02-2016, 06:35 PM   #5
Just swapped the cool packs, they are brand new msds so I will let you know when I drive it tomorrow
Old 04-06-2016, 11:02 AM   #6
fomoco4life's Avatar
Yup, seems like injector or coil issue. I've heard of the MSD's failing from factory...OE cops are the way to go... Like OP said, switch a couple cops and see if it changes
Old 04-06-2016, 04:47 PM   #7
Oe coil packs are the way to go here. MSD= Might Suddenly Die
Sent from my LG-D801 using Mustang Evolution mobile app
Old 04-07-2016, 04:09 AM   #8
Steve96's Avatar
I know someone who has a few low mileage coil packs😉
1996 GT
Old 04-07-2016, 05:47 AM   #9
He's a 96, he has the actual coil packs. I just happen to have 16 low mileage OEM COPs for sale... not the same thing lol.
I should probably post those up here but I need to do the paper thingy to post all my parts here.
Old 04-07-2016, 10:40 AM   #10
Steve96's Avatar
Oh my bad, I didnt look at what year unfortunately, lol. Well then he is off a little cheaper then, haha. Anyone I still know someone with 16 COPs haha.
1996 GT
Old 04-07-2016, 10:43 AM   #11
Steve96's Avatar
But as Scotty pointed out you dont have COPs, you have the actual coil packs, so those telling you to buy OEM COPs should be saying buy OEM coil packs. You can still switch the new one around to see if you have an issue with them, Ive done this many of times on other cars
---------- Post added at 11:43 AM ---------- Previous post was at 11:43 AM ----------
Oh my bad, I didnt look at what year unfortunately, lol. Well then he is off a little cheaper then, haha. Anyway I still know someone with 16 COPs haha.
1996 GT
Old 04-07-2016, 10:45 AM   #12
Steve96's Avatar
Each time I did switch around my coil packs to find the misfire, it turned out to be leaking intake gaskets. Not Mustangs though but they are notorious for it as well.
1996 GT
Misfire in cylinder 4 Balltaatic01 1996-2004 Mustang GT 20 11-28-2012 06:37 PM
Cylinder #2 misfire. storieddeth 2005-2010 Mustang GT 10 09-26-2012 07:33 PM
2000 dodge caravan cylinder 5 misfire Niko Brown General Car Discussion 1 08-27-2012 06:44 PM
Cylinder 1 Misfire? stew99 Pre-2005 V6 Mustang 3 11-02-2011 10:31 PM
Misfire cylinder #1 with Check Engine Light JRMustang Pre-2005 V6 Mustang 29 03-14-2011 11:49 PM
09:30 PM
