cat back exhaust - Mustang Evolution
Old 03-31-2016, 10:23 AM   #1
cat back exhaust
Just installed a borla cat back now my 2003 mach 1 has a stumble ? I reset the CPU with no help still does it HELP
stillfastphil is offline   Reply With Quote
Old 03-31-2016, 11:22 AM   #2
infamous281's Avatar
There is no way the catback caused any issues.
It might of just been a coincidence
Sent from my SM-N910T using Mustang Evolution mobile app
Old 03-31-2016, 11:40 AM   #3
It happened That was the only change off with the old and installed the stingers . Car was perfect before called Borla they said drive it 400 miles then call back, I have never had this problem before either. Help !!
Old 03-31-2016, 12:05 PM   #4
It runs fine till you floor it. stumble then takes off and runs great. You can launch it great at 2000 pull second at 6500 burns the tires stumble for a second and takes off great ? Help please !!!!
Old 03-31-2016, 12:19 PM   #5
Steve96's Avatar
Did you mess with the 02 sensors at all?
1996 GT
Old 03-31-2016, 12:23 PM   #6
no
Old 03-31-2016, 01:54 PM   #7
When you say "stumble" does it hesitate or does it buck or jar a bit at WOT?
Old 03-31-2016, 02:13 PM   #8
just like u turn off the key
Old 03-31-2016, 10:40 PM   #9
I don't see how a catback could do that, unless somehow the O2 sensors get messed with. When cutting off the stock pipe did the sensor maybe break from the vibration of the pipe or get some dust up in the sensors? My guess is since it only takes about 30 minutes to check them look at the O2's this weekend.
lyonschoice is offline   Reply With Quote
Old 04-01-2016, 05:25 AM   #10
The car runs perfect except when you first go to WOT then u get that shut out for a second then it takes off fine? U can drive it around and never know anything is wrong till you slam the pedal to the floor fast ? no codes or lights on! HELP someone please I am lost
Old 04-01-2016, 05:42 AM   #11
Mile high JDF's Avatar
This ^
What sort of fuel are you using?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-01-2016, 06:13 AM   #12
93 octane premium fresh fuel
Old 04-01-2016, 12:26 PM   #13
Steve96's Avatar
So it was dirty gas?
1996 GT
Old 04-01-2016, 12:33 PM   #14
no I just ran out the tank and filled it with 93 , I had driven the car 100 miles after adding gas with no problem .
Old 04-01-2016, 12:41 PM   #15
I just bought the car out of Colorado , had it shipped in on feb12, 16 . It was in storage here till the weather got better. The car ran great only 45k with no modification's completely stock . It was a Tennessee car Tennessee title and only went out there when the owner moved there several months before.
Old 04-01-2016, 06:43 PM   #16
Steve96's Avatar
Oh I see your a fellow Michigander. At least this winter was nothing compared to what we are used to. Its strange that its doing that now after the exhaust was done. Is it possible it had the issue before and it wasnt driven enough to notice or hard enough to notice? Could it be the IAC? That usually shows up when idling, but it can do what your stating too I believe. Ive heard of a bad IAC, (a guy at work w/02 GT) making the car cut out at WOT, but his pretty much stalled out when he would then come to a stop cause it had an erratic idle after it started to cut out. No codes, but if you have it scanned or scan it, there still could be a stored code that isnt making the CEL come on? Could it be something coil wise, like a short under hard acceleration? This is weird.
See you live in Brighton, not too far from my neck of the woods. Congrats on the Mach too, its by far my favorite New Edge.
1996 GT
Old 04-02-2016, 07:48 AM   #17
I have not driven in much because of the weather as u know. But had to make sure it was OK . Would have never bought something on ebay but my daughter lived out there and looked at it for me. I drove it yesterday and I think it was better, maybe the PCU had to learn the new setup? I'm too old to craw under cars now so I had it done at a speed shop in Brighton that worked on my son's 2003 GT. He got me back in to racing, took me for a ride! We race with 3 Balls racing at several tracks including Waterford.
Old 04-02-2016, 08:36 AM   #18
U know I'm starting to put some things together. It came from 5500 ft high Denver with there low octane gas(90 octane at best), I changed the AIR Filter that was so dirty I can't believe it ran at all and I put on a low restriction cat back system, filled it with 93 gas!
Old 04-02-2016, 09:08 AM   #19
The only thing out of those three possibilities that might make a difference is the air filter. Try cleaning your MAF sensor and see what that does for you. Like everybody else has said, a catback exhaust system is not going to cause a stumble or miss like you're experiencing...
Old 04-02-2016, 10:21 AM   #20
does your car run OK at 5500 ft on the low octane gas ?
Old 04-02-2016, 10:32 AM   #21
I think the brain was over whelmed with all the changes at one time. It acted like the lean bog you got with a carburetor when the accelerator pump was not set right or the cam was to big. I had a 428 CJ with a big cam and a auto that did the same thing . If it ever gets warm here again I will just go for a long ride and see if it gets better.
Old 04-02-2016, 11:03 AM   #22
It runs just fine, same with my old GT.
post up some pictures, I'm curious as to which Mach 1 you bought.
I don't know carbs too well so that comparison is kind of lost on me. You could try disconnecting the battery for 15 minutes and connect the battery cables together (while disconnected) to reset the engine memory. That will drain the KAM (keep alive memory) and reset learned values.
Old 04-02-2016, 11:06 AM   #23
I did that but have not driven it long enough because of the weather here , hope it works
Old 04-02-2016, 11:14 AM   #24
I'm not much on the new phone stuff I will get my son to post a pic for me. It's red got it from aurora just south of Denver. Nice 48k as it came from factory
Old 04-02-2016, 12:07 PM   #25
Awesome! I'm quite curious to see it because that one doesn't ring a bell for me.
Old 04-02-2016, 01:07 PM   #26
My daughter lives in castle rock has a 15 with the track pack , the whole family are gear heads. She went to ck out the car for me. I was a fmc engineer for 33 years now just old but still love to go fast. I ran the proto-type machine shop for a few years but always loved speed and still do. Its snowing now so the pic will take a few days waiting for the sun
Old 04-04-2016, 08:40 AM   #27
About to go cat less need advise
Hey guys, about to take out my cats due to a broken cat so I have decided to just take them out and go catless with a stock h pipe and slp loudmouth 1's. My question is do I need a tuner to do this (remove the cats) had a buddy tell me I need to get a tuner if I go Catless is this true if so what tuner for my 2000 mustang GT would work best with this set up (slp loudmouth 1's, stock H pipe, and removing the catalytic converters)
BlackGT2000 is offline   Reply With Quote
Old 04-04-2016, 09:40 AM   #28
Steve96's Avatar
You dont "have" to get a tuner. Your CEL light will be on due to the no cats, and with a tuner you can shut that off. Also a tuner will obviously not be a bad decision if you want one since you are probably going to add future mods. But you dont have to have one currently for what your doing. A lot of people are happy with their Bama tunes, and MPT tunes. There are quite a few out there as far as tuners and canned tunes.
1996 GT
Old 04-04-2016, 12:53 PM   #29
Thanks for the advise one more question would any bama tuner cure this issue of the CEL?
Old 04-04-2016, 11:12 PM   #30
Steve96's Avatar
Yes they should. You fill out a webform from them with what you have and can also list on there that you specifically want that. And the SCT tuners will allow you to fix that after the fact anyway. I dont think its too hard if the canned tune doesnt do it or isnt tuned for that, to take care of it
1996 GT
exhaust
Cat Back vs. Axel Back syas07 2011-2014 V6 Mustang 5 07-16-2012 12:52 PM
Tech question about exhaust? Axle back bolt to Cat back? 2012Coyote 2011-2014 Mustang GT 3 02-28-2012 04:56 PM
Axle back vs cat back Big Johnson 2011-2014 Mustang GT 3 01-10-2012 05:43 PM
Cat-back or Axle-back Borla Touring Gmcnomore 2011-2014 V6 Mustang 12 07-23-2011 03:48 PM
Cat back or Axel Back Ravnus 2011-2014 Mustang GT 8 04-28-2011 04:59 AM
01:32 AM
