INPUT SHAFT - Mustang Evolution
Old 03-31-2016, 03:25 PM   #1
PARTSFROMERIK's Avatar
INPUT SHAFT
Wobbly input shaft, is it replaceable? t56...I keep going through throw-out bearings after 2 or 3 days of driving.
PARTSFROMERIK is offline   Reply With Quote
Old 03-31-2016, 05:29 PM   #2
Mile high JDF's Avatar
Yes it's replaceable. I know terminator guys sometimes sell theirs after upgrading to a 25l6 spline input shaft.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-04-2016, 03:22 PM   #3
I hope you're right d:
Old 04-04-2016, 05:06 PM   #4
Hop on SVTP and check their classifieds
Old 04-07-2016, 06:00 PM   #5
Doesnt throwout bearing ride on the bearing retainer sleeve?
Wobbly input shaft would have no effect on TOB, maybe on pilot bearing.
Just putting it out there...
302 Stroker TFS Heads + Cams 11.2:1 CR
327/352 hp/tq
8111870 is offline   Reply With Quote
Old 04-07-2016, 11:50 PM   #6
Speed_Mister's Avatar
Region: Arkansas
I have my stock input shaft from my tr-3650.. Idk if it will fit in a t56 tho.
2004 Mustang GT 5 Speed
Full Bolt Ons
370RWHP 470RWTQ
12.1 @ 117.9
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 04-08-2016, 01:40 PM   #7
I believe it does, I'm going to do a new clutch, flywheel, throwout bearing,pilot bearing and clutch fork and see if that's it, if not time to get into the transmission and change the input shaft
Old 04-08-2016, 06:53 PM   #8
Most premature TOB failures i have heard of were due to:
1) cheap bearings, stick to the Ford branded ones
2) improper preload on cable, or no preload at all.
Hope it all works out, BTW check that the bearing retainer isnt scored, or damaged, and bearing can slide easily .
327/352 hp/tq
Old 04-09-2016, 06:09 AM   #9
I've bought already the Ford TOB and Pilot bearing but the throw out bearing keeps going bad. But hopefully this works.
Balancing drive shaft or replacing drive shaft Iryan7 Pre-2005 V6 Mustang 6 03-22-2015 11:57 AM
input shaft seal/bearing satin06silver 2005-2010 V6 Mustang 2 07-27-2014 04:44 PM
installing clutch disc onto input shaft -is it supposed to touch guide? (pics inside) paradigm 1996-2004 Mustang GT 0 06-30-2013 05:49 PM
INPUT SHAFT!!! redcobravert 1996-2004 Mustang GT 12 08-23-2009 01:59 PM
Have You Broken Your TREMEC Input Shaft? jwyche 1979-1995 Mustang GT 0 11-09-2008 10:52 AM
01:07 AM
