Clutch noise - Mustang Evolution
Old 04-03-2016, 04:47 PM   #1
bkh1994's Avatar
Clutch noise
So the clutch has about 10k miles on it. One morning it started slipping so I adjusted it some and it has not slipped again. But what is happening, is that at 4K rpm, you can hear a scraping sound like sandpaper and noticeable power loss. It drives just fine up until there. It's a spec 3+ clutch, Steeda firewall adjuster, Steeda quadrant, MM cable
bkh1994 is offline   Reply With Quote
Old 04-16-2016, 12:22 AM   #2
Revvv's Avatar
It is possible the flywheel or clutch over heated and glazed. It is also possible that the pressure plate has gone bad.
Do you drive in a lot of stop and go traffic?
Do you race the car frequently?
Do you enjoy spirited rides with tight corners and turns?
Old 04-16-2016, 07:05 AM   #3
bkh1994's Avatar
Clutch noise
Thanks for the reply. It turned out to be belt slip. The noise I heard was more like a hiss now that I've done some research on it. I moved my idler pulley to tighten the belt up some and it's gone
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
Clutch noise?? Please help! Hyphynator 1979-1995 Mustang GT 11 02-04-2011 11:59 PM
Clutch noise jldusza Pre-2005 V6 Mustang 7 09-16-2010 07:17 AM
strange clutch noise R1CK3R Pre-2005 V6 Mustang 10 10-02-2009 10:47 PM
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-29-2008 11:24 PM
11:53 PM
