Sticking idle - Mustang Evolution
Old 04-06-2016, 01:39 PM   #1
Sticking idle
98 gt. I just started using 93 octane. The car runs so much better on it I could definitely feel a difference. But now my idle hangs at a high RPM when I'm driving and If take my foot off the gas it will still hang and if I push in the clutch it will still hang for a while and then slowly come down as well. Any ideas on why. The car idles perfect at a stop. Thanks
Sent from my SAMSUNG-SM-N910A using Mustang Evolution mobile app
clean4.6gt is offline   Reply With Quote
Old 04-06-2016, 04:57 PM   #2
Mile high JDF's Avatar
Check your Idle Air Control Valve. They are a pretty common problem and cause a hanging idle.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-06-2016, 05:11 PM   #3
Westcoast408's Avatar
Would it make a noticeable different using 93 octane even without a turner?
Sent from my SM-G920T using Mustang Evolution mobile app
99 Mustang GT F.R 3.73s, MGW Short Shifter, BBK Cai, BBK 70mm Throttle Body, Mach 1 Chin Spoiler, SR Lowering Springs, Koni shocks and struts, Mach 1 Grill Delete, Black Billet Fuel Cap, Trick Flow 75mm Plenum, Raxiom Smoked Tail lights, Magnapack Mufflers
Westcoast408 is offline   Reply With Quote
Old 04-06-2016, 08:44 PM   #4
How would I find out if it's tuned. I got the car from a guy I did work on his house. It was his sons car and he gave it to me as payment. He said he didn't know what was done to car. Except for exhaust, 373 gears, it's set up for a wet shot. It also has a cold air intake. I was running 87 and it was running sluggish. I switched to 93 and u can really feel a diffrence.
Old 04-06-2016, 09:07 PM   #5
Steve96's Avatar
No it doesnt. If youre not tuned for 93 then it wont. Its just kind of a waste of $ to me if your car doesnt call for it to begin with. If you have raised the compression of the motor than yeah you will need it. But on a normal 87 octane designed engine it won't benefit you to run it IMO.
1996 GT
Old 04-06-2016, 09:17 PM   #6
Steve96's Avatar
Also OP, it does sound like you should start with cleaning your IAC and see if that helps. A bad one or dirty one can cause stupid issues with your idle. May as well clean the MAF too while your at it. IAC seems to be a common replacement item on these cars when their older, several threads on ME about it. There are you tube vids on how to clean both and what to use
1996 GT
Old 04-07-2016, 06:34 AM   #7
PARTSFROMERIK's Avatar
+1 To the IAC.
PARTSFROMERIK is offline   Reply With Quote
Acts like the choke is sticking bizwaks 1979-1995 Mustang GT 0 03-20-2011 02:38 PM
Gas peddle or throttle sticking Myles 1996-2004 Mustang GT 14 01-10-2011 06:26 PM
Idle sticking Rascal Pre-2005 V6 Mustang 2 08-11-2010 02:18 PM
Cruise Control Sticking meteorachick Pre-2005 V6 Mustang 19 06-19-2008 05:39 PM
Clutch sticking to Pressure Plate??? Rick0636 Pre-2005 V6 Mustang 5 11-08-2003 06:28 PM
11:12 AM
