Thermostat for mach 1 - Mustang Evolution
Old 04-12-2016, 06:42 PM   #1
superdrift's Avatar
Car today started overheating thanks to a bad radiator pressure cap releasing fluid. Im seeing that this might be a good time to get a colder thermostat but im seeing that i might need a tune and some of these colder thermostats cost a huge amount of money. Wondering is it a good idea to change it to a colder one sense these cars are know for being really hot?
superdrift is offline   Reply With Quote
Old 04-13-2016, 12:50 AM   #2
I think that I would try a new thermostat first.
I was having a problem with my truck running a little warm a while back, and decided to try a Motorcraft thermostat, rather than the style commonly found at the "box" auto parts stores. So far it has worked flawlessly. They cost about double what a typical thermostat usually costs, but you can see right away that they are better constructed.
Rockauto has them for about $15.
Old 04-13-2016, 05:27 AM   #3
If you do wind up replacing the thermostat, make sure you burp the cooling system or you will continue to overheat due to air bubbles caught in the system.
Sent from my SM-N910P using Mustang Evolution mobile app
Old 04-13-2016, 07:02 AM   #4
Try www.termi-stat.com he might have something that works for the Machs, I am having a hard time viewing the site on a work browser.
Need help replacing thermostat floridamba Pre-2005 V6 Mustang 1 04-01-2007 06:30 PM
thermostat? ryanxup Pre-2005 V6 Mustang 3 11-27-2006 08:17 AM
Thermostat 97conv6 Pre-2005 V6 Mustang 18 06-13-2005 06:41 PM
thermostat housing Warfire80 1996-2004 Mustang GT 14 09-16-2004 11:00 AM
Thermostat Laser02 Pre-2005 V6 Mustang 14 07-08-2004 02:08 AM
01:45 PM
