Fuel pump? - Mustang Evolution
Old 04-13-2016, 06:30 AM   #1
LeoGMR4558's Avatar
Fuel pump?
Car turns on but won't stay on unless I leave the gas pressed, my guess is the fuel filter but I want other opinions and experience before I do anything. I'll turn on the car and it'll die right away or it will turn on and the rpms will be real low like it wants to die and then dies.
LeoGMR4558 is offline   Reply With Quote
Old 04-13-2016, 06:32 AM   #2
LeoGMR4558's Avatar
Fuel pump for the title, half asleep right now
Old 04-13-2016, 06:18 PM   #3
I recommend replacing the fuel filter. If the problem persists, then test the fuel pressure. It should be between 40-70 psi with the engine running. After you turn the key off, the fuel system should hold pressure for five minutes, and lose less than 5 psi from the indicated operating pressure.
It is also helpful to scan for any diagnostic codes.
Old 04-13-2016, 06:42 PM   #4
mineralgt's Avatar
Fuel pump?
Check for vacuum leaks loose vacuum hoses or idle air control valve bad
mineralgt is offline   Reply With Quote
Old 04-13-2016, 09:09 PM   #5
Can you hear the pump turn on when you turn the key. It should make a light humming noise for about 3 to 5 seconds.
Sent from my SAMSUNG-SM-N910A using Mustang Evolution mobile app
clean4.6gt is offline   Reply With Quote
Old 04-13-2016, 09:19 PM   #6
infamous281's Avatar
Check fuel pressure , before doing anything fuel related.
Sent from my SM-N910T using Mustang Evolution mobile app
should i have to change fuel.pump and fuel filter?? jmpark527 2005-2010 Mustang GT 11 11-11-2011 09:38 AM
Pruchased my Fuel Injectors and Fuel pump today Brent Pictures and Videos 36 12-14-2010 03:22 PM
Where is the fuel filter and fuel pump in a 1966 mustang 289? brant General Mustang Discussion 6 03-04-2010 04:18 PM
WTB: Electric Air Pump (smog pump) MagnuM Mustang Parts for Sale and Wanted 0 05-16-2007 10:10 AM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-11-2005 11:04 PM
10:26 AM
