Are these good Mods? - Mustang Evolution
Old 04-16-2016, 12:50 AM   #1
Question Are these good Mods?
Hey guys I have an 04GT with 50 Thousand miles on it and I'm trying to reach 300+ horse power I'm thinking about just buying a pro-charger but i was told i should beef the engine up a tab bit first so i was thinking Comp Cams,Intake Manifold,3.73 Gears...
I already have the Cold Air, Long Tubes headers,Off road X-Pipes and Cat back Exhaust...
What should i do throw the pro-charger on or take my time and beef the engine up first!
OhPep is offline   Reply With Quote
Old 04-16-2016, 01:36 AM   #2
natestang07's Avatar
Suspension suspension suspension
Old 04-16-2016, 01:44 AM   #3
Mile high JDF's Avatar
That ^ also save your money on the cams/intake manifold/long tubes and just go with a procharger... these engines can handle 450hp so if you're gonna drop a lot of money making more power then you might as well get your money's worth out of it.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-16-2016, 03:04 AM   #4
Might not be as appealing but +1
Get a good set of shocks/springs, maybe CAs and SBs as well.
wawanesa5speed is offline   Reply With Quote
Old 04-16-2016, 11:17 AM   #5
infamous281's Avatar
Engine will be alright to 400ish
Just get a bigger maf, 60-80lb injectors , bigger fuel pump , and get money for a sct handheld tuner , and dyno tune.
Sent from my SM-N910T using Mustang Evolution mobile app
Old 04-16-2016, 11:24 AM   #6
Count Dragula's Avatar
With the 2 valves you can buy just rods or buy rods and pistons and be safe around 600-650 without changing anything else. After that you'll want head studs and other supporting parts. But for 400-450 there is no need to do anything. A good tune will be key and make sure you have enough fuel. 60 pounds injectors would be perfect. 80s is a little overkill.
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 04-17-2016, 11:17 AM   #7
Suspension first, "spinnin ain't winnin". Your stock intake manifold does not need to be replaced, it flows great. Cams... save your $$ and just supercharge it. I'd just get a Vortech S trim and call it a day. If you get the whole kit it comes with everything but you will need a better tune than the stock Vortech one.
But yeah... if you have the stock suspension you'll lose at the track to cars making way less power than you.
Old 04-19-2016, 10:42 AM   #8
Cams can wait. Welded full length subframes, progressive springs, MM LCA's, ditch quad shocks, stocker UCA's, sticky tires.
Once that's done pick up a used Vortech V2 or Procharger, send it out for rebuild and slap it on. Obviously upgrade fuel, spark and tune.
these mods good enough????? samcrored 1996-2004 Mustang GT 0 04-09-2014 07:24 PM
Anybody use these or have used these 04__gt 1996-2004 Mustang GT 19 08-25-2013 02:04 PM
MODS MODS MODS! S197Miller 2005-2010 Mustang GT 28 02-10-2013 01:36 PM
Mods.....Mods.....Mods.... Srohda 2011-2014 Mustang GT 8 06-01-2012 12:50 PM
rank these mods in order of performance gain. MusclesFromBrussels The Bar 15 08-11-2003 06:22 AM
05:53 AM
