Problem - Mustang Evolution
Old 04-19-2016, 08:53 PM   #1
smsstang's Avatar
Problem
On the way to work this morning right before I got there I started to feel a throttle lag ? So I opened my hood saw one injector was leaking . After work I open my hood again gave a little push on that injector then started it up waited about 3-4 Minuts saw it wasn't leaking . Started to drive home felt the same lagging when giving throttle then my service engine light flashes for about 2 Minuts then went off and never came back on ? Still lagging in my throttle then I got back to the joys opend my hood and injector seemed like it was dry ? Any ideas ?
smsstang is offline   Reply With Quote
Old 04-19-2016, 09:21 PM   #2
Revvv's Avatar
Wait until the car is cool and then turn the key to pressurize the fuel system. Look at the fuel rail and injectors to make sure there is no fuel leaking that could have evaporated on a warm engine. It is possible that the o-ring is worn or broken. There is a reason why the injector was out of place.
Old 04-19-2016, 09:55 PM   #3
smsstang's Avatar
I just replaced the orings and intake manifold like 2-3 weeks ago so I doubt the ring is bad right ? But I will Check that . Thank you
Old 04-19-2016, 10:37 PM   #4
Steve96's Avatar
Maybe since the work was done it was seated properly and just worked its way out? But if its back in place you shouldnt be having the lag issue unless its still not right. Maybe a bad o ring?
1996 GT
Old 04-19-2016, 10:42 PM   #5
Junior Member
Maybe there is a little pinch in the o ring causing a leak.
Fitzy_2v is offline   Reply With Quote
Old 04-19-2016, 10:47 PM   #6
smsstang's Avatar
Yeah I'm gonna take back off that whole side and look at the o rings and re seat everything and see what happens
Old 04-20-2016, 07:18 AM   #7
infamous281's Avatar
O-ring has a tear , remove and inspect.
Sent from my SM-N910T using Mustang Evolution mobile app
Old 04-20-2016, 08:00 AM   #8
smsstang's Avatar
Okay will do
Old 04-20-2016, 11:36 AM   #9
You can lubricate the O-rings with a little motor oil so that they will slide in easier.
Old 04-20-2016, 11:36 AM   #10
Junior Member
That is what I did when replacing my intake manifold
Old 04-20-2016, 11:41 AM   #11
smsstang's Avatar
Okay yeah I guess I will get all that done and see what happens . Hopefully no more lagging .
Old 04-20-2016, 11:48 AM   #12
Just double check all of the work that you did when you replaced the intake manifold. Make sure that all of the vacuum lines and electrical connectors are connected.
Also, if your Check Engine Light illuminated, there is likely a stored code that you can retrieve and get a better idea of what happened.
Old 04-20-2016, 12:08 PM   #13
smsstang's Avatar
It did it then it went off ? It was weird
Old 04-26-2016, 07:04 PM   #14
smsstang's Avatar
So the injectors arnt leaking no more but still have that little lagging problem do y'all think it could be just time to get new spark plugs .
Old 04-26-2016, 07:10 PM   #15
You can swap them out if they need to be replaced, but you should scan for codes to determine what that flashing CEL was all about.
Old 04-26-2016, 07:14 PM   #16
smsstang's Avatar
Yeah I'm gonna have to do that cause I just got done driving it and it popped on again !! But it really feels like it's a spark plug problem ? How long does it take usually before you should change the spark plugs ?
Old 04-26-2016, 08:24 PM   #17
Ford recommends replacing the factory platinum spark plugs at 100k miles.
A flashing CEL is usually caused by a misfire so you may be correct, and your problem could be ignition related. There is undoubtedly a stored code that will perhaps help narrow down the diagnosis process.
Old 04-26-2016, 08:26 PM   #18
smsstang's Avatar
Yeah I'm only saying because the last time I felt this problem it was probly year and half ago and I changed the plugs and it felt great after .
Old 04-26-2016, 09:19 PM   #19
2kgt1025's Avatar
Scan it, It should tell you what spark plug is misfiring.. when i bought my gt it had a leak and it went in two of the spark plugs also burnt out a coil.
Sent from my SM-G935P using Mustang Evolution mobile app
2kgt1025 is offline   Reply With Quote
Old 04-27-2016, 02:22 PM   #20
smsstang's Avatar
Will a scanner tell you if a coil is burnt ? Also how much are coils usually ?
Old 04-27-2016, 03:11 PM   #21
2kgt1025's Avatar
It will tell you what spark plug is bad, Then you can check if its the coil or the plug. Also its not too expensive if you just need one coil but if you buy all of them i think its like 170 on AM.
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 11:10 AM
Squeeling problem Sil\/erSpeed Pre-2005 V6 Mustang 3 08-17-2003 04:24 PM
News update on engine problem Danger Dude Pre-2005 V6 Mustang 14 08-11-2003 01:54 PM
Major Wiseco Piston PROBLEM! *DUW** plstktnkr2 Pre-2005 V6 Mustang 3 07-21-2003 02:58 PM
02:42 AM
