Rear End Noise Under Acceleration Over 50MPH - Mustang Evolution
Old 04-21-2016, 07:57 AM   #1
Revvv's Avatar
I am beginning to get extremely frustrated with my newly acquired 2002 GT. I knew it would need a little work, but I am discovering more than I expected to deal with.
I am not a pro when it comes to axles, diffs, and gears. I understand how they work, but I am car from what I would consider competent.
While driving, once the car reaches about 50MPH I hear a howl that is ridiculously loud (in my opinion). The noise only exists when maintaining speed or accelerating. If the car is coasting or decelerating there is no noise at all.
The previous owner claimed to have had 3.73 gears installed about a year ago. I am not sure how to confirm this. The speedometer reads correct, so I can assume the computer was adjusted for the change if there was one.
I have not checked the fluid yet. However, I do not expect to find it to be low. There are no signs of leaking.
Ideas?
Old 04-21-2016, 09:21 AM   #2
95v686gt's Avatar
Did he say if when the gears were installed was there a spool, locker or factory traclok used? If it was factory was the additive added to the oil? Also if it's howling it could also mean it's not shimmed or set right. Gear install isn't too complicated but if they didn't use a install kit with new crush sleeve it could be that. Need to talk to the previous owner and get more details.
95 GT BBK CAI TB MSD 6AL O/R H SLP LM1
Coming soon GT40 Heads Intake and e303 cam with Long tubes
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 04-21-2016, 09:32 AM   #3
Revvv's Avatar
Unfortunately the guy is clueless. I wish I was familiar enough with differentials and gearing to open it up and see the problem. I would love to see this be a simple fix.
I'm not exactly in the position to purchase a new set of gears and bearings at the moment. However, I have to drive this car as a daily driver at the moment.
If new gears are needed I plan to install them myself. I don't know any way to learn except through experience.
Old 04-21-2016, 09:41 AM   #4
Revvv's Avatar
I just sent a text to the previous owner. Hopefully he knew what was being installed and how.
Old 04-21-2016, 09:55 AM   #5
95v686gt's Avatar
Once you pull the diff cover, look for metal in the oil coming out and in the housing. Inspect the ring gear for wear. (Metal shaved off the teeth, chunks missing etc etc). If you find nothing, take some cleaner and clean the carrier as well as possible. Then get a grease pencil and color a section of the gears, spin them one full turn to were the section you colored has made contact with the pinion. Make sure it has even contact all the way thru and meshed properly with the pinion gear. If it doesn't, pull center section and replace with a FRPP carrier install kit with NEW crush sleeve.
Old 04-21-2016, 09:59 AM   #6
Revvv's Avatar
So what you're saying is that I could possibly get away with only an install kit without replacing the entire rear end?
Old 04-21-2016, 10:05 AM   #7
95v686gt's Avatar
If the ring gear is not hurt and there's no metal in it. But if it is a factory traclok, make sure you put in the recommended oil and additive for it. Wrong oil with no additive can also cause issues. I've heard you can use the Lucas synthetic gear oil and not have to use the additive but I'm not sure on that.
Old 04-21-2016, 10:08 AM   #8
Revvv's Avatar
The bad part for me is that I won't know if it has a factory locker, or a different style. It looks like I will need some research.
Old 04-21-2016, 10:13 AM   #9
95v686gt's Avatar
When you pull the cover, you'll see a big gear which is the ring gear. If it's factory when you look at it, it'll have like 4 gears in the middle with a big clip that is in between 2 of them and a pin running thru the center. Look the carrier over really well for a Ford stamp and part number.
I could be wrong on the looks. But if it's got a Ford stamp nine times out of ten it's factory with a different ring and pinion.
Old 04-21-2016, 10:20 AM   #10
Revvv's Avatar
In your opinion, do you think this inspection and tear down can wait until next weekend? I know that is a ridiculous question to ask. No one knows what is behind the diff cover yet.
The worst that can happen is a complete detonation of the rear end as it becomes its own grenade. The axles could slide out, the car could find itself totalled. I'm not sure I like my optimistic outlook.
Old 04-21-2016, 10:22 AM   #11
95v686gt's Avatar
OK other than the noise does it do anything out of the ordinary? Clunks? Vibrations?
Old 04-21-2016, 10:30 AM   #12
DiESeven's Avatar
Does is sound like mine? I had 3.73 installed. I swapped out the entire rear-end with a factory 3.73 rear end because I didn't want to deal with trying to fix it and running in to more problems..
Old 04-21-2016, 10:36 AM   #13
95v686gt's Avatar
A noisy rear end is normally caused by a bad install or gear oil with no additive. It's not as simple as bolt it in and go. The shims have to be installed correctly and in their place they came out of. The pinion angle has to be set properly. The crush sleeve has to be replaced. And if it's a traklock or limited slip you have to use the proper oil or use a additive in the oil to keep from ruining your carrier
Old 04-21-2016, 10:37 AM   #14
Revvv's Avatar
Your video sounds almost like a whine. I have a droning roar. If my car had an aftermarket exhaust I would assume it to be an obnoxious exhaust note.
Old 04-21-2016, 10:38 AM   #15
95v686gt's Avatar
Bet if you pull the cover and grease pin the gear, you'll find the ring and pinion not meshed properly
Old 04-21-2016, 10:40 AM   #16
Revvv's Avatar
Nothing out of the ordinary that I have noticed. No griding when turning. No vibrations. I have not noticed any clunking.
I don't drive aggressively. I'm likely one of the most peculiar people you will meet when it comes to vehicle maintainance and care. I broke enough stuff racing when I was a kid.
Old 04-21-2016, 10:41 AM   #17
95v686gt's Avatar
Just baby it and if it goes to doing anything else park it.
Old 04-21-2016, 10:42 AM   #18
Revvv's Avatar
I hope that I can clearly see the meshing issue. This is a new venture for me.
Old 04-21-2016, 10:44 AM   #19
95v686gt's Avatar
Grease pen is yellow and will show the pattern of the teeth meshing on the ring gear. Google Ring and pinion gear install. It'll show you what I'm talking about
Old 04-21-2016, 10:46 AM   #20
Revvv's Avatar
Perfect! Thank you.
Old 04-21-2016, 11:04 AM   #21
Revvv's Avatar
Watching a few videos, and it looks like a press and a torque wrench are needed.
The last thing I need to pay is labor at the moment. Not that I don't want to pay someone, I'm just stretched financially at the moment. As I general rule I like to pay and then tip whoever does the work.
Now I'm just whining and complaining.
Old 04-21-2016, 11:16 AM   #22
My car was making a similar noise when I purchased it. Turns out it was a bad axle bearing. The axle also needed to be replaced due to the failed bearing.
Lift the rear wheels off the ground and rotate them while listening for any abnormal noises. On my car, it was easy to tell which bearing needed replacement.
small popping noise from exhaust And lag under hard acceleration mattyp511 Pre-2005 V6 Mustang 11 12-06-2014 07:55 PM
Unusual noise under acceleration mmike87 2011-2014 Mustang GT 2 11-05-2012 09:35 AM
347 stroker missing under acceleration? imported_Matt Classic Mustangs 5 12-16-2011 07:29 AM
Strange Whine under Acceleration? Thomas91169 The Bar 36 09-05-2006 08:09 AM
Battery light comes on under hard acceleration Brent Pre-2005 V6 Mustang 23 02-05-2005 03:18 PM
05:00 PM
