Automatic Crank HP-RWHP conversion and max HP limit - Mustang Evolution
Old 04-23-2016, 02:39 PM   #1
Hi Everyone. Thought I would want to get more educated on information about the stock Automatic of my 04. From what I read, the conversion of Crank HP to RWHP would be a loss of 15% on a manual. What would be the % loss of an Automatic?
Furthermore, what would be the MAX RWHP that a stock Automatic can take on the New Edge?
Thanks
KNIGHT4000 is offline   Reply With Quote
Old 04-23-2016, 02:53 PM   #2
Junior Member
Thanks
I'm not sure about the % loss but from what I heard it could handle 400 horsepower but it's really not horsepower you should look out for its more torque that destroys everything (this is all from just reading forums)
Fitzy_2v is offline   Reply With Quote
Old 04-23-2016, 11:39 PM   #3
Steve96's Avatar
The trans in an 04 is one of the better automatic transmissions to have in a 99-04 Mustang. Its actually "beefed" up from the factory. They can handle a little more HP. I cant remember exactly what was upgraded on them, but Im sure someone will chime in. I want to say IIRC that the trans can hold more like 550-600 hp if in good condition. The 2v engine on the other hand is a time bomb over 450 whp and needs a forged roatating assembly.
1996 GT
Old 04-24-2016, 04:27 AM   #4
Junior Member
550-600 that is a lot on stock parts I never heard that much safely but I have heard of people having that but then they end up grenadine there transmission
Old 04-24-2016, 05:04 AM   #5
Mile high JDF's Avatar
The 04s got the 4R75W which is quite strong, Steve's info is correct. A simple convertor swap can turn it into a pretty nasty setup. But as with everything, previous maintenance and abuse will play a big factor into transmission life.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-24-2016, 05:05 AM   #6
Junior Member
The 04s got the 4R75W which is quite strong, Steve's info is correct. A simple convertor swap can turn it into a pretty nasty setup. But as with everything, precious maintenance and abuse will play a big factor into transmission life.
Wow I guess it's time to turn up the boost then. I have a 4r70w
Old 04-24-2016, 05:12 AM   #7
The 4R70W takes a little more work (J-mod) to handle decent power, but the engine rods will let go before the trans does.
Old 04-24-2016, 05:14 AM   #8
Junior Member
What could I do to get up to 500 horsepower short of a whole monster performance rebuild kit.
Old 04-24-2016, 05:15 AM   #9
Out of the trans? Or the engine?
Old 04-24-2016, 05:15 AM   #10
Junior Member
The transmission
Old 04-24-2016, 05:17 AM   #11
J-mod and a torque convertor
Old 04-24-2016, 11:55 AM   #12
Ford states that the 4R70W can handle 506 ft-lbs of torque. There has been speculation that the "70" in 4R70W can be multiplied by 10, and that is the torque handling capacity (700 ft-lbs). The more likely scenario is, that 506 ft-lbs, converted to Newton Meters, is 686 N-M, which can be rounded up to 700.
Transmissions are generally rated for their torque handling capacity, rather than horsepower. Torque is the component in "power" that is most likely to break things.
Old 04-24-2016, 11:57 AM   #13
Junior Member
Wow so what you are saying is my stock 03 4r70w can handle up to 506 ft-lbs of torque
Old 04-24-2016, 12:01 PM   #14
Yes. 506 ft-lbs.
That's what Ford says.
Old 04-24-2016, 04:53 PM   #15
Thanks everyone for the data. Would anyone also have any info on CrankHP to RWHP conversion of an Automatic? Is it 15% like a manual or would it be more?
Old 04-24-2016, 06:40 PM   #16
Steve96's Avatar
Its a little higher % with the autos, I would have to look it up but I want to say its closer to 18-20% or so. Somewhere around there. I could be thinking of another car now that I think more about it, lol. Google it and Im sure you will find it eventually
1996 GT
Old 04-24-2016, 07:46 PM   #17
It varies a lot from vehicle to vehicle, but Steve's estimate is probably pretty close... A few percent more than a manual transmission.
I've heard that Corvettes can break into the low 20%'s. I think that my truck is about a 25% loss!
Old 04-24-2016, 08:14 PM   #18
@Steve96 and straybullitt.
That is something that I was wondering, if it might differ from vehicle to vehicle type. The one stock dyno number I found on a 2000 GT is shown here by American Muscle, and it seems its just 15% loss on an Automatic.
I'm curious if the solid rear axle on that generation might help putting the power down better compared to an Automatic Corvette or other cars with IRS? Then again I'm just speculating.
Old 04-24-2016, 11:17 PM   #19
Steve96's Avatar
It could be that. Variations from car to car of the same manufacturer too Im sure. Look at some dyno numbers from when the Coyote 5.0s came out, there is variation, not a ton but I have seen them 2%-3% different in rwhp. There were some making close to 400 rwhp but they were rated at 412 flywheel hp, so they would be a lower % obviously to the same car the same day on the same dyno making 390 rwhp rated at 412 flywheel hp. I know you know that just thought Id throw it out there as an example, those numbers are fairly accurate from memory and I think they were both manuals. I cant think of an actual manual vs auto comparison I have seen on anything really. Usually its just a % put out there by the manufacturer which Im sure can vary from car to car. I know the kind of dyno used is a factor on all those numbers anyway. The only way to really know what your car is making is to get it on a dyno and see, then you can figure your actual % of loss from the flywheel. I dont want to know how miniscule either of my cars are rwhp wise, ha.
1996 GT
Old 04-25-2016, 03:47 AM   #20
Interesting thing is, this Dyno test by LMR has only 3 bolt ons and a stock tune at the beginning and makes a tiny bit more HP than the AM Test car after Bolt ons and a Tune. The LMR GT is a manual, but on the other hand the power difference could be from the Bolt on Brands. Additionally to a Manual vs Automatic dyno comparison on averages of the same model, it would be great to see a database of Testing the most popular Catbacks, Mid-Pipes,CAI and header Brands on a Dyno against each other. Some kind of a HP/Torque consumer report.
Oh I definitely know what you mean. haha. While I would do a Dyno run if there would be one within or near my city, a part of me doesn't want to see the very small possibility that after all the $ on Bolt Ons and Bama Tune, I would only make 30RWHP more.
Granted, I have smoked a couple of newer stock V8s at the traffic lights that were 3-4 times more expensive as my car, but they where over a 1000 pounds heavier and manuals. So if it was driver error on their part, I was just lucky.
Old 04-25-2016, 01:41 PM   #21
The Marauder guys have found the safe limit to the 4R70W is right around 500ft lbs. The 04 GT and Mach autos (and some late run 03s) got the 4R75W which is way stronger. The limit of that trans is the 23 spline stub shaft which starts to get sketch in the 650ft lb range.
Also screw Monster transmission. If you are going to have a built one done get Dan at Silverfox transmissions to do one for you. For a converter... PI, Circle D are 2 of the big names. Then there is Freakshow if you are on a budget.
You are lucky to have an 04 auto honestly... It is by FAR the most capable car transmssion Ford ever used until the 6R80.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 04-25-2016, 11:26 PM   #22
Thank you for the info. I wasn't aware that the Automatic on my 04 was such good quality. I simply assumed it would be similar in quality to the GM Automatics on the 2001/02 Camaro SS, C5s and Ws6s.
Old 05-02-2016, 01:06 AM   #23
phatspeed7x's Avatar
My 2004 GT has the manual transmission. Last year at the summer nationals I put down 250rwhp with only minor bolt ons (intake, exhaust, throttle body and plenum, factory tune with a tank of only 87 octane)
https://youtu.be/_M74OffhdB0
Now I have the race tune for 91 octane and the car seems more peppy. Can't wait for my cams to get here.
Sent from my LG-H900 using Tapatalk
~2004 GT with Bolt ons~
phatspeed7x is online now   Reply With Quote
Old 05-02-2016, 02:05 AM   #24
Eturner's Avatar
When your talking intake and plenum, are you talking CAI/upper plenum?.. Or the Whole Intake manifold?.. And what exactly have you done to the exhaust?.. Just curious!..
Sent from the One and Only ME!..🍻
Old 05-02-2016, 02:20 AM   #25
Airaid cold air intake
SVE 75mm throttle body and plenum.
Stock PI intake.
Stock manifolds.
Pypes off-road H pipe.
Flowmaster Super 10 series mufflers.
Old 05-02-2016, 02:49 AM   #26
Eturner's Avatar
Stock PI intake.
Stock manifolds.
Nice. I've got the TrickFlow Intake mani. With 75mm TB!.. UD Pullies, BBK Tuned Headers, Pypes OR X-pipe, CherryBomb Vortex cat back!.. And a performance 93 tune!.. Never had my car on a dyno though!..
Old 05-10-2016, 05:45 PM   #27
toneman's Avatar
I got a 99 Mustang Gt convertible 5 speed stick with every bolt on you can do. The exhaust is full length headers into an off-road X-pipe with three chamber Flowmaster mufflers. Crower stage 2 cams were put in by Alternative Auto in Chesterfield Michigan and she put down 295 rwhp with 305 foot pounds of torque. That's about roughly all you can get with a 93 octane tune out of a 4.6 2valve with bolt on's and cams. The car runs much stronger than the numbers would suggest. I'm hungry for more power but I'm not doing anymore to this car. It's got a nice rumpy idle and it's fun to cruise in. Hope this helps!
toneman is offline   Reply With Quote
Old 05-17-2016, 09:43 PM   #28
alecas447's Avatar
Thanks
18-20% for auto
Mac o/r H pipe. Flow master super 44s. Accufab 70mm throttle body. Pro comp intake manifold. MSD coils
alecas447 is offline   Reply With Quote
non automatic headlights/automatic turn off silverskoundrel General Mustang Discussion 11 09-07-2013 09:13 AM
Automatic to manual conversion Datstangboi 1996-2004 Mustang GT 2 07-23-2013 08:56 PM
Automatic to 5 speed conversion 03fastblack 1996-2004 Mustang GT 5 02-23-2012 10:44 AM
Think 55mph speed limit is too slow? Apparently these kids for GA do to. Zim The Bar 27 03-15-2006 05:34 PM
Got pulled over again.... for driving the speed limit? WhiteStang99 The Bar 28 06-16-2005 12:42 PM
09:09 AM
