Trick Flow Kit(Heads and Cam) - Mustang Evolution
Old 04-25-2016, 11:55 PM   #1
I finally found a capable mechanic in a different city who can Install High Performance upgrades on my Automatic 04 GT. Basically I would like to keep my car naturally aspirated(I like the cam sound) and my goal is ultimately around 330-340 RWHP. With all my bolt ons and Tune, I guesstimate I have currently around 270 RWHP. I hope that 60-70RWHP with high end heads and cam would make that Target plausible.
I have my eye on this:
https://lmr.com/item/TFS-519380375/1...ngine-Kit-44CC
Any thoughts about this Trick Flow kit? The Mechanic said this Kit should be all I need for the install, but there is always a possibility that more accessories might be needed. Would there be anything else that I might require? I guess I would eventually need a Torque converter.
...Another option would be a Coyote Swap. However that would cost me more than my entire car($15000 CAN+ parts and labor). So very unlikely. But ooh man, that power to weight ratio would be sweet.
Owner of: Between Mustangs right now.
KNIGHT4000 is offline   Reply With Quote
Old 04-26-2016, 12:21 AM   #2
Eturner's Avatar
That should put you within your HP goal!.. But for roughly about the same price, you can just SC and have around 400-450hp!..
Sent from the One and Only ME!..🍻
Old 04-27-2016, 02:14 PM   #3
Yes, you would be correct. I just did the math and it seems that a Supercharger would be just $1000-$2000 more than cams and head kit+Dyno tune. However, wouldn't the Supercharger be less reliable, since my car is a daily driver? A procharger or a Kenny Bell would be a possibility, but I heard that the Procharger only kicks in around 4000RPM making no additional low RPM Power and Torque. I like the concept of the Twin Screw KennyBell for its power in every RPM, but it might "turn the engine to cheese" according to some reviews. At least those were the reviews I read that make the cam and heads more of an attractive option. Mind you, if anyone would have more experience about those 3 options, I would very much appreciate it.
Old 04-27-2016, 03:21 PM   #4
Eturner's Avatar
A third option would be a Turbo set up!.. That would also be roughly the same price as a SC!.. Mind you that your doing all the work yourself!.. Also if you keep the Boost low your engine will hold up just fine!..
Old 04-27-2016, 04:12 PM   #5
Mile high JDF's Avatar
I guess I'll chime in on this. A HCI setup will net you somehwere around 330whp if you're lucky. Driveability may suffer depending on the cam setup you go with but you should gain a broader power band.
A Centrifugal blower makes boost as your RPM's rise, I'll post up one of my dyno graphs to show. My first and second gear (manual) don't have a problem building boost quickly and the car feels really responsive, it's only when you try to start building boost in the higher gears that you will notice a severe lag. A Kenne Bell makes full boost instantly, which is a, but I find the power band to be very unexciting and it gets very boring (in my opinion).
I'm gonna be pulling off my Vortech and swapping to an On3 turbo because I've been spoiled driving various other turbo cars.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-27-2016, 04:24 PM   #6
^ does that apply to the Bullitt intake as well? Power wise.
Respect the Classics.
Old 04-27-2016, 05:02 PM   #7
What do you mean?
Old 04-27-2016, 05:07 PM   #8
Swap out a GT intake for a Bullitt intake.
Old 04-27-2016, 05:14 PM   #9
Ah, the Bullitt intake supposedly picks up a few torque but it isn't really worth swapping too considering the cost involved. Ideally you would run an Victor Jr. manifold or find a fancy HPS intake, but both of those are a lot of money to throw at a car to still only make 330-340whp.
Old 04-27-2016, 06:10 PM   #10
2300turboford's Avatar
Here's my trickflow heads I got not to long ago Click image for larger version
Name:	ImageUploadedByMustang Evolution1461802159.965251.jpg
ID:	200350Click image for larger version
Name:	ImageUploadedByMustang Evolution1461802178.267769.jpg
ID:	200351Click image for larger version
Name:	ImageUploadedByMustang Evolution1461802208.487036.jpg
ID:	200352Click image for larger version
Name:	ImageUploadedByMustang Evolution1461802231.555086.jpg
ID:	200353Click image for larger version
Name:	ImageUploadedByMustang Evolution1461802249.957085.jpg
Old 04-27-2016, 06:47 PM   #11
If you are referring to supercharged applications, the flow characteristics of the intake manifold become less important because the intake manifold basically becomes a pressure vessel to store compressed air until it is required by the engine.
Old 04-27-2016, 07:18 PM   #12
jeno's Avatar
I wouldn't do head and cam just forced induction and good safe tune and be done
Mods: Upr Xpipe, Upr CAI, Ford Racing C Springs, Mach grill delete, Chin spoiler, Magnaflow exhaust, SCT 4 Bama Tuned
jeno is offline   Reply With Quote
Old 04-27-2016, 07:38 PM   #13
Ish416's Avatar
I know people who have built NA 2v's and then got bus lengthed by their grandma on her hoveround scooter so badly that she had to use binoculars in her rearview to even see them.
Go FI unless you want to waste money and still be disappointed.
Old 04-27-2016, 07:39 PM   #14
NA 4.6L even at 330hp is going to be a turd compared to something like a 330hp F body. Redline of 5800 to keep the stock rods alive doesn't even start to come close to utilizing the flow potential of the TFS heads.
Keep your motor together and go with a power adder. Get a converter and suspension work done first on your car, launching a bolt on 2V with a good converter will feel like you added a 100 shot to it at takeoff. Then look into forced induction or nitrous. But the redline of the stock 2V is always going to be a big limiting factor.
Old 04-27-2016, 07:47 PM   #15
I wasn't.
Old 04-27-2016, 07:57 PM   #16
I wasn't.
NA, I don't think that you would see much difference in peak power. But they do smooth out the power curve over a stock GT manifold.
Plus, they're pretty!
Old 04-27-2016, 08:30 PM   #17
It's what I've noticed.
Old 04-27-2016, 09:06 PM   #18
They also add 30lbs to the nose of the car and hold heat more than plastic does.
Says the guy who is going to a metal intake as well.
Old 04-27-2016, 09:20 PM   #19
Eturner's Avatar
Name:	ImageUploadedByMustang Evolution1461813488.845105.jpg
My TrickFlow Intake!.. Don't even feel the added weight of the metal intake!.. Plus minimal difference in heat too!..
Old 04-29-2016, 01:56 AM   #20
Thank you everyone for the feedback. Gives me a lot to think about. I guess Supercharging would be the more bang for buck course of action HP wise.
Old 04-29-2016, 06:57 PM   #21
It is. Stock heads, cams and intake and a vortech is 400+ and will have stock street manners and gas mileage when you keep your foot out of it. Why I'm doing a stock HCI 4v with a blower. I'll get 20+ mpg cruising and a metric assload of power over 3500.
Sent from my LG-D801 using Mustang Evolution mobile app
331 with trick flow top end kit or stock 302 with the truck flow h/c/i kit Muller 1979-1995 Mustang GT 6 10-23-2013 07:28 AM
Trick flow heads and intake. Supersleepy96 1996-2004 Mustang GT 5 03-28-2012 06:46 PM
Dyno jet results with new trick flow heads! SlyFox512 1979-1995 Mustang GT 4 02-24-2011 11:14 PM
Best carbureted intake with trick flow heads? SlyFox512 1979-1995 Mustang GT 7 01-23-2011 10:34 AM
Is anyone running trick flow 190cc heads on a 302? SlyFox512 1979-1995 Mustang GT 1 01-05-2011 12:04 AM
02:46 AM
