Rear abs sensor not lining up - Mustang Evolution
Old 04-28-2016, 01:42 PM   #1
cstyle408's Avatar
My 98 gt ABS stays on. I took the wheel off and found the ABS sensor is not lining up with the ABS ring on the axle. Its pushed in as far as possible but doesnt go to where it should be like the passenger side. Could it be the rear brake caliper anchor plate is possibly bent a little? Basically, i smacked into a curb sideways snapping the driver side axle and im trying to get my car back on the road. I replaced the axle and seal but i just discovered im still leaking gear oil onto the inside of back wheel. So i have two issues with the driver side rear. I think i might have answered my own question about the ABS but not totally sure what to do about the oil leak from axle. Any help is much appreciated.
cstyle408 is offline   Reply With Quote
Old 04-28-2016, 01:45 PM   #2
cstyle408's Avatar
Pics for previous post
ID:	200386   Click image for larger version
Old 04-28-2016, 01:48 PM   #3
cstyle408's Avatar
And one last thing..... the bolt that holds my rear upper control arm to the axle is bent. Do i just replace the bolt? I want to get new control arms but money is really tight right now.
Old 04-28-2016, 09:07 PM   #4
Did the flange on the end of the axle tube get bent?
That would account for the sensor not lining up, and the leaky seal.
My car got slid into a curb by the previous owner, and they had to replace the entire rear end assembly.
Old 05-01-2016, 09:49 PM   #5
cstyle408's Avatar
I guess when i slid into the curb it cracked the plastic piece that holds the mounting bolt for the sensor and the sensor got pushed back out of its seated position. So i just epoxied the plastic piece and bolted it back into where it belongs after the epoxy dried. No more abs light
Abs rear to non abs rear? misterpancho95 Pre-2005 V6 Mustang 0 01-21-2015 09:29 AM
Fender Lining??? 03RedfireGt 1996-2004 Mustang GT 4 03-02-2013 12:32 PM
31 spline moser Axels to long abs ring not under sensor The grim reaper 1996-2004 Mustang GT 0 02-01-2013 01:00 AM
Red-Lining tgmeyer 2011-2014 Mustang GT 31 06-23-2012 07:08 PM
Every cloud has a silver lining Ken Regional Mustang Discussion 0 05-12-2003 07:25 PM
12:04 AM
