Quick question - Mustang Evolution
Old 04-30-2016, 12:30 PM   #1
jeno's Avatar
Quick question
So somewhere im getting a battery drain with the car off i checked the radio fuse and its drawing 12.54 amps is that correct or should it be a lot lower and then 12.54 with the radio on
Sent from my LG-H811 using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 04-30-2016, 01:49 PM   #2
That is way too high for the radio off. I think that the amperage draw required to keep the memory alive on typical stereo should be less than 1/10th of an amp.
Old 04-30-2016, 02:35 PM   #3
fenixignition's Avatar
A friend of mine had this issue. Ended up being one of the Mach amplifiers.
Sent from my SM-G920V using Mustang Evolution mobile app
2002 GT 5sp. 16x,xxx miles
Old 04-30-2016, 03:15 PM   #4
jeno's Avatar
Ok so i checked the draw at the red hot wire zero amperage so at the alternator im getting 12.8 amp and the battery the same when the car is running shount the amperage go to like 13 to 14 amps
Old 04-30-2016, 03:18 PM   #5
are you sure your looking at amps and not volts? amperage has to be calculated i thought. all you can get when you hook a multimeter up to it is volts and ohms.
Old 04-30-2016, 03:18 PM   #6
If you are referring to volts, you should see at least 24 volts with the engine running.
Old 04-30-2016, 03:20 PM   #7
14 volts
Old 04-30-2016, 04:31 PM   #8
jeno's Avatar
Yeah i think i found the problem the pigtail that connects to the back of the alternator has a bad broken wire
Old 04-30-2016, 05:31 PM   #9
jeno's Avatar
Yup was the problem pigtail at the alternator replaced and know my system is charging at 13.75 even with a load now im happy
Old 04-30-2016, 09:08 PM   #10
Westcoast408's Avatar
Its good to hear you figured out the issue.
Sent from my SM-G920T using Mustang Evolution mobile app
---------- Post added at 03:08 AM ---------- Previous post was at 03:08 AM ----------
I wish I knew more about our cars lol
99 Mustang GT F.R 3.73s, MGW Short Shifter, BBK Cai, BBK 70mm Throttle Body, Mach 1 Chin Spoiler, SR Lowering Springs, Koni shocks and struts, Mach 1 Grill Delete, Black Billet Fuel Cap, Trick Flow 75mm Plenum, Raxiom Smoked Tail lights, Magnapack Mufflers
Westcoast408 is offline   Reply With Quote
Old 05-01-2016, 06:50 AM   #11
jeno's Avatar
Thanks took 6 hours to find it lol
Quick question need a quick answer about exhaust manifolds Ghostedmind Pre-2005 V6 Mustang 7 03-14-2013 11:36 PM
quick question Thomas91169 The Bar 9 03-19-2004 12:53 AM
Quick question... WhiteStang99 Mustang Audio & Video 21 01-26-2004 09:39 PM
quick question on fuel for my stang 232SCstang Pre-2005 V6 Mustang 2 01-03-2004 04:16 PM
quick question, plz help! blackstang2k3 Pre-2005 V6 Mustang 5 09-18-2003 11:15 AM
04:52 AM
