Leaking oil - Mustang Evolution
Old 05-01-2016, 03:46 PM   #1
superdrift's Avatar
Leaking oil
Whenever i let me car sit overnight then crank it up lately it has been leaking a good amount of oil for the first 2-5secs of startup but it stops right after and if the engine is slightly warm it wont leak. Its leaking somewhere in the area of the oil filter
superdrift is offline   Reply With Quote
Old 05-01-2016, 03:48 PM   #2
superdrift's Avatar
Here is a pic of it inside of a pizza box
Old 05-01-2016, 03:49 PM   #3
fenixignition's Avatar
Oil filter adapter gasket. Shaped like a... gentleman's sausage....
Sent from my SM-G920V using Mustang Evolution mobile app
2002 GT 5sp. 16x,xxx miles
Old 05-03-2016, 10:09 AM   #4
superdrift's Avatar
How difficult is it to replace?
Old 05-03-2016, 01:57 PM   #5
Quite easy. I don't remember if I removed the oil filter or not but you just unbolt a few bolts, pull the piece off where you screw on an oil filter,change the gasket, wipe up a little bit of coolant and oil, and tighten it up.
Old 05-04-2016, 07:56 PM   #6
It is easy, you will need to be prepared to do an oil change. Best to drain the oil before messing with the adapter. Removing the oil filter will help you access the the top bolt if i remember correctly. You will also have to prepare yourself to replace some coolant as well.
All said and done i replaced mine in about 30min with access to a lift.
Sent from my SM-N910P using Mustang Evolution mobile app
Old 05-04-2016, 09:39 PM   #7
superdrift's Avatar
Is it okay to reuse the stuff? Everything has about 500miles on it.
Old 05-05-2016, 04:25 AM   #8
You won't lose much oil at all during this process. Just change the gasket when the engine is cold. Mine only dropped like 1/8th to 1/4 of a quart of oil and not much coolant. Even if you pull your oil filter just don't drain it. Have a catch pan and rags ready.
Old 05-09-2016, 07:10 AM   #9
superdrift's Avatar
Swapped it out and it fixed the problem thanks for the help
Why am I leaking oil? MDoane44 2005-2010 Mustang GT 30 11-16-2012 01:32 PM
leaking a little oil from rear 93_347foxbody 1979-1995 Mustang GT 7 09-11-2012 09:46 PM
Leaking oil sixpac 1979-1995 Mustang GT 10 06-02-2012 08:46 PM
oil pan gasket leaking!! justjake94boss 1979-1995 Mustang GT 7 04-15-2012 01:47 AM
Oil leaking on crankshaft Taxman 1979-1995 Mustang GT 2 04-14-2012 10:40 AM
09:49 AM
