Well my build might be moving along here soon. I got a very nice surprise from my VA disability this weekend. They finally approved my claims and back paid me a very large chunk of money. But I can't use it until I get the job with GE aviation I have an interview for this Friday. So here's hoping I get that.
Let's get to the point. I want cams. I have been looking at 3 different cams.
Hitech stage 2 specs are Specs: 234/230 duration, 111 lobe sep, .550/.500 lift
Cushman stage 1 specs
Specs .540"/.550" lift 224/226 .50 duration
with 110 lobe separation
Modular head shop nitrous cams
specs 225/230 at .550/.525 lift center lines 110/110 lobe separation 110
I will also buy the trick flow timing kit, get the cams degrees wherever I buy from, new lash adjusters, supercar GT followers and possibly a spring kit.
These three cam combos will run around 2000 in parts.
What do you all think?
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
