Benefits of EGR delete? - Mustang Evolution
Old 05-03-2016, 06:01 AM   #1
0440thgt's Avatar
Thinking about doing some long tubes on the ole GT and was looking at EGR deletes. I know how the EGR functions, but cant understand the benefit of deleting it???
0440thgt is offline   Reply With Quote
Old 05-03-2016, 06:12 AM   #2
Cleaner engine bay. That's it.
Old 05-03-2016, 07:36 AM   #3
0440thgt's Avatar
10-4
Old 05-03-2016, 08:58 AM   #4
Revvv's Avatar
I think the real question is; what is the EGR, and why does the car have it if it doesn't need it?
Old 05-03-2016, 09:52 AM   #5
Its been discussed ad-nauseum on this and multiple other forums. Its on there for emissions reasons but deleting it frees up zero power so in the end, it just cleans up the engine bay. And is also illegal to delete...
Old 05-03-2016, 09:55 AM   #6
Revvv's Avatar
Interesting. My 03 Ram doesn't have an EGR. It came from the factory without one. So why is it illegal, and if it does nothing, why add it in the first place?
Old 05-03-2016, 09:58 AM   #7
I didn't say it did nothing, I said it did nothing power wise to delete it. And as it is a factory emissions item, deleting it is illegal. Dodge started putting it on the Hemis in 04. Probably because of increasing Federal emissions regulations TBTH.
Old 05-03-2016, 10:25 AM   #8
Revvv's Avatar
As for the EGR; it stands for Exhaust Gas Recirculation. I have looked at this system over and over again, and I cannot find a single use it to be on an engine. On the flip side of the coin, the EGR hurts nothing remaining in place. In my mind it would appear to introduce unwanted hot air to the air fuel ratio, but I don't think it is enough to hurt anything.
...and Scotty is correct, it is illegal to remove any factory installed smog emissions on a street driven vehicle, despite their value or lack thereof. It is illegal to remove catalytic converters, yet millions of cars have had the cats removed.
Right now I am not a fan of regulated emissions. I am looking for an engine for my Dodge Ram due to clogged cats. There was no obvious warning sign at all that pointed towards the cats being clogged on my truck. No foul smell, no lights, and no noticeable lack of power.
I say there were no obvious signs because there were multiple warning signs that pointed to extreme back pressure in the engine. I blew a radiator, and after replacing that the bottom radiator hose blew off, running the engine hot before the temp guage could warn me (sensors designed to measure liquids do not read hot air and steam well). I buttoned that up and assumed the hose to be my fault. I checked everything over and nothing appeared to be damaged. The next weak link was the seam in the coolant overflow box. After that was repaired the water pump started to leak. I replaced every part of the cooling system without thinking about back pressure.
The next weak link in my cooling system was caused when the engine over heated. I had a head gasket blow. I could see air pumping via bubbles through the radiator. By that time it was too late. The heads on my truck are trashed, and the bottom end is destroyed due to coolant being introduced to the oil in mass quantities. To make things more interesting, the intake plenum was full of oil.
I know, that was a long post. I just felt like clearing up my negative opinion concerning emission systems. Plus it may give someone else a warning sign before they lose their own engine.
Old 05-08-2016, 08:05 PM   #9
Hutch22v's Avatar
Name:	ImageUploadedByMustang Evolution1462759385.219952.jpg
Cleans up engine
Just recirculates I unburned exhaust gasses back down the intake manifold during regular driving
Does nothing at WOT
Hutch22v is offline   Reply With Quote
Pro chamber benefits? Ruthless Pre-2005 V6 Mustang 3 09-24-2011 07:38 AM
98 cobra fipk intake benefits? mz98snake General Mustang Discussion 6 06-06-2011 08:14 AM
Matt Lienart reaping celebrity benefits Brent The Bar 4 04-01-2008 07:47 PM
FINALLY some benefits from working in retail Seph The Bar 9 12-10-2004 03:12 PM
Benefits of an aluminum driveshaft... i need some help Zim Pre-2005 V6 Mustang 26 04-05-2004 08:49 AM
03:50 AM
