How to tell if it's stock or not - Mustang Evolution
Old 05-03-2016, 05:11 PM   #1
salsa04GT's Avatar
Sorry if this is a dumb thread, but I'm trying to learn about my 2004 GT and I've been following ME for a while now and noticed you guys know what you're talking about!
The question is how do I tell if there are aftermarket parts on my mustang? I can tell the exhaust is SLP, but what about other things like under the hood? Such as CAI, pulleys, TB, plenum, etc.
salsa04GT is offline   Reply With Quote
Old 05-03-2016, 05:30 PM   #2
Ferr's Avatar
If the CAI is a completely closed box it's more than likely the stock air box, or the stock air box with a drop in filter. Most aftermarket CAIs are open, at least at the top. If the throttle body doesn't have an aftermarket brand such as BBK on it odds are its stock. I'm pretty sure the brands are usually easy to spot on throttle bodies. There's people here that know much more than I do though, I don't know much about the new edge mustangs. Why don't you post some pics of your engine bay so someone could just directly tell you if it's stock or not?
Btw good luck with your car!
Ferr is offline   Reply With Quote
Old 05-03-2016, 05:30 PM   #3
natestang07's Avatar
Post a picture and we could probably help a bit
Old 05-03-2016, 06:26 PM   #4
salsa04GT's Avatar
Name:	ImageUploadedByMustang Evolution1462321438.299630.jpg
ID:	200552Click image for larger version
Name:	ImageUploadedByMustang Evolution1462321451.665392.jpg
ID:	200553Click image for larger version
Name:	ImageUploadedByMustang Evolution1462321466.198592.jpg
ID:	200554Click image for larger version
Name:	ImageUploadedByMustang Evolution1462321479.632611.jpg
Thanks for the help guys I appreciate it! I'm looking to make progress with her soon and ME is my go-to with anything.
Old 05-03-2016, 06:33 PM   #5
You're good. Engine isn't molested.
Respect the classics.
Old 05-03-2016, 06:37 PM   #6
jeno's Avatar
Stock
Sent from my LG-H811 using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 05-03-2016, 06:59 PM   #7
Revvv's Avatar
That is a bone stock engine.
Old 05-03-2016, 07:49 PM   #8
keeney35's Avatar
Easy to figure out.
Is it fast?
If yes, then it isn't stock.
If no, then yes it's stock lol
These cars aren't fast stock by any means, they are fun tho.
However there are many things you can do to "wake the car up" and make it feel like a very different, quicker car without breaking the bank.
You mentioned it had SLP exhaust, so that's a good start.
Your first mods should be:
Gears (3.73 or 4.10)
Good off road mid pipe if you don't have emissions testing if not at least get an aftermarket catted mid pipe
Short throw shifter if it's a stick, if not you need to j-mod the auto trans(Google jmod)
After that you will need some suspension work no sense in having the mods I listed above if you can't get traction.
Get a good set of lowering springs (I like steeda)
Shocks and struts (koni oranges are cheap and good quality)
Steeda x2 ball joints
Caster camber plates
Subframes connectors (full length)
Rear control arms
And a good tire. Depending on what kind of driving you'll be doing will determine the tire. If it's daily driven but you still want to be able to hook and drive it in rain, then a nitto drag radial is good (555R) if your just gonna drive it in good weather and want the best hook go with Mickey Thompson et streets, or just a good all around tire that I like are toyo r888's.
With that you won't be in it that much $$ and will have a completely different car then you do now.
If you wanna go all out with it and pour your heart, soul and bank account into it then click on my thread "where to go next" and read thru it.
I'm about 5-7k into this engine which seems like a lot but when I'm pushing 375 on motor and 600+hp with boost it's all worth it
Here's some eye candy for motivation Click image for larger version
Name:	ImageUploadedByMustang Evolution1462326540.803667.jpg
04 GT: CAI, 3.73's, Longtubes, Full exhaust, Comp Cams 270's, Short throw, Pullies, Ported/Polished heads, Manley dished/notched pistons, MMR forged H beam rods, FRPP forged crank, BBK 75mm throttle body, MSD coils, 60lb EV6 injectors, Eddy Vic Jr intake, UPR coilovers in front, Steeda lowering springs in rear, Front strut bar, MM caster camber plates, UPR k member, 355lph walbro pump, MMR 8qt oil pan, ARP hardware, EGR delete, A/C delete, ABS delete, EVAP delete.
Honda weight with an American V8
keeney35 is offline   Reply With Quote
Old 05-03-2016, 09:00 PM   #9
A bolt on 2v isn't fast either..
Old 05-03-2016, 09:28 PM   #10
keeney35's Avatar
Never said they are lol depends on what your comparing it to as well lol
Old 05-03-2016, 10:12 PM   #11
Revvv's Avatar
My car is faster than Mustangs that are 10 years older.
Ok, by today's standards the New Edge is slow. When I was drag racing bikes I would occassionally unhook my Ram from the trailer and beat 99-04 Mustangs on the track. Some of that may have been experience at the light, but the Mustang was beat by a quad cab Dodge Ram.
Old 05-03-2016, 10:14 PM   #12
Revvv's Avatar
By the way, my favorite Mustang is the New Edge. I even bought one after searching for months for a bone stock convertible. The 2v can be built to be fast, but it won't be cheap.
Old 05-03-2016, 10:29 PM   #13
keeney35's Avatar
Cheap, fast, reliable.
You can only pick two.
Old 05-03-2016, 10:31 PM   #14
Revvv's Avatar
Fast and reliable are rare in the world of Ford.
Old 05-04-2016, 01:41 AM   #15
Westcoast408's Avatar
I have a single cab ram hemi with factory 3.92 gears and it feels twice as fast as my gt but the new edge is one of the best mustangs bodies, its true.
Sent from my SM-G920T using Mustang Evolution mobile app
99 Mustang GT F.R 3.73s, MGW Short Shifter, BBK Cai, BBK 70mm Throttle Body, Mach 1 Chin Spoiler, SR Lowering Springs, Koni shocks and struts, Mach 1 Grill Delete, Black Billet Fuel Cap, Trick Flow 75mm Plenum, Raxiom Smoked Tail lights, Magnapack Mufflers
Westcoast408 is offline   Reply With Quote
Old 05-04-2016, 01:43 AM   #16
Easy to figure out.
Is it fast?
Rear control arms
Here's some eye candy for motivation Attachment 200561
Keeney it looks like you build one badass engine. I wish I had those skills.
Old 05-04-2016, 05:32 AM   #17
Mile high JDF's Avatar
Hell I don't even consider my car to be fast
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 05-04-2016, 06:01 AM   #18
Strange Mud's Avatar
Keeney, nice ride.
Mud
Old 05-04-2016, 06:50 AM   #19
keeney35's Avatar
Thanks fellas, 2v's can be bad but it ain't cheap but nothing's better than whipping up on 4v and ls cars with a 2v
Old 05-04-2016, 07:01 AM   #20
Revvv's Avatar
Buiding a fast 2v is extremely expensive. Anything can be done with enough money and the right technology.
Old 05-04-2016, 07:08 AM   #21
Revvv's Avatar
I was told that I could not push a Honda CBR900RR to 200mph. The engine was bored over and stroked. The head was massaged and polished. All four carbs were bored over, rejetted, and polished. After all was said and done I had a CBR frame with a custom engine, and a carbon fiber body fairing.
I ran 211mph in Maxton.
Old 05-05-2016, 05:11 PM   #22
salsa04GT's Avatar
Easy to figure out.
Is it fast?
Rear control arms
Thanks to everyone that let me know it was stock for sure.
And keeney I've been following your build since the beginning and it is bad *** man. Serious motivation for others like me who look for insight and information based on experience. There are a few others on this forum who know who they are that fall in the same category. Thanks for everything guys.
Old 05-08-2016, 07:59 PM   #23
Hutch22v's Avatar
Virgin Engine Bay
Hutch22v is offline   Reply With Quote
Old 05-08-2016, 08:07 PM   #24
Anyone know if the stock coil packs are suppose to be yellow?
Old 05-08-2016, 08:08 PM   #25
Hutch22v's Avatar
Stock COP are black
Old 05-08-2016, 08:10 PM   #26
I ll get a picture maybe there not the coil packs
Old 05-08-2016, 08:14 PM   #27
I was just wondering if its ever had the spark plugs changed, it has 49k
Old 05-08-2016, 08:20 PM   #28
I estimate maybe 250hp or less lol
Old 05-08-2016, 08:22 PM   #29
Revvv's Avatar
The yellow parts are the fuel injectors.
Old 05-08-2016, 08:26 PM   #30
Oh damn I don t know too much of our engines yet but they are the stock for sure?
Old 05-08-2016, 08:40 PM   #31
Revvv's Avatar
Bone stock. Everything under that good is OEM or OEM spec from what I can see.
I have an 02 GT and the cars are identical under the hood.
Old 05-08-2016, 08:46 PM   #32
Okay thanks Revvv.
Old 05-09-2016, 01:01 PM   #33
alecas447's Avatar
My mildly bolt on 2v walks 3vs tbh
Mac o/r H pipe. Flow master super 44s. Accufab 70mm throttle body. Pro comp intake manifold. MSD coils
alecas447 is offline   Reply With Quote
Old 05-09-2016, 01:02 PM   #34
Whatever you say
Old 05-09-2016, 01:33 PM   #35
alecas447's Avatar
Whatever you say
I have the vids lol
Tell me this new mustang commercial is NOT REAL! twk General Mustang Discussion 7 05-05-2014 01:55 AM
How can I tell if my engine is a 1983 302 HO or not? cristobal 1979-1995 Mustang GT 5 12-19-2011 04:43 AM
how can i tell if i have PI heads or not? redbird2289 1996-2004 Mustang GT 4 08-26-2009 08:56 PM
1976 ford mustang will not start, not headlights come on, it is not the battery, why? eifion Classic Mustangs 6 08-24-2009 03:12 AM
Stock V6 please tell me the best way to go to start bit_cloud Pre-2005 V6 Mustang 25 04-28-2004 05:59 PM
03:19 AM
