Rear view camera install - Mustang Evolution
Old 05-06-2016, 09:51 PM   #1
Ddejesus523's Avatar
I want to add a rear view camera to my 04GT and was wondering how to wire it up.. I see people grabbing power from the brake lights or reverse lamps.. Is there a difference? Are there any other ways to hook it up? TIA!
Ddejesus523 is offline   Reply With Quote
Old 05-07-2016, 06:49 AM   #2
Revvv's Avatar
I wish I had a good answer. I think the head unit in my 02 is going bad. If I need to replace it I would like to go with a double sin unit with a back up camera and navigation.
The old Megellan died, and I'm tired of wasting my phone battery. Plus, there is no where convenient to put a phone to see the screen.
Old 05-07-2016, 07:37 AM   #3
wmschoonover's Avatar
You need to pull power from the reverse light. That way it's only on when you shift into reverse. If your head unit has a reverse wire like mine does, you can use it. My camera came with an RCA wite that had a power wire corrected.
wmschoonover is offline   Reply With Quote
Old 05-07-2016, 07:42 AM   #4
amazon.com/gp/aw/d/B00RD05MOO/ref=mp_s_a_1_3?qid=1462628438&sr=8-3&pi=SY200_QL40&keywords=Chuanganzhuo&dpPl=1&dpID=31FjKNzaSeL&ref=plSrch
This is the camera I used. Great picture. Can select normal or mirror image and if guide lines are shown. Mounted it right about my license plate.
Old 05-07-2016, 11:20 AM   #5
hihosilver's Avatar
Send a message via MSN to hihosilver
This is what I did:
Amazon.com: Esky 170° Viewing Angle Universal Car License Plate Frame Mount Rear View Camera, 8 IR LED: Cell Phones & Accessories
Fed the wire up through the license plate light grommet. No holes drilled. Tap into the reverse light wire for power.
hihosilver is offline   Reply With Quote
Old 05-07-2016, 05:02 PM   #6
Westcoast408's Avatar
Was it pretty simple to install? What kind of head unit did you need for it?
Sent from my SM-G920T using Mustang Evolution mobile app
99 Mustang GT F.R 3.73s, MGW Short Shifter, BBK Cai, BBK 70mm Throttle Body, Mach 1 Chin Spoiler, SR Lowering Springs, Koni shocks and struts, Mach 1 Grill Delete, Black Billet Fuel Cap, Trick Flow 75mm Plenum, Raxiom Smoked Tail lights, Magnapack Mufflers
Westcoast408 is offline   Reply With Quote
Old 05-07-2016, 05:46 PM   #7
That's exactly the same camera I bought and I was thinking of running it through the same place.. Any leaks?
Old 05-11-2016, 06:17 PM   #8
fenixignition's Avatar
http://www.amazon.com/Chuanganzhuo-U...rds=B01ARR71N4
I just installed one of these. but when i finally got it to work, the reverse lights would not turn off, and i couldnt get it to work when i put my car into reverse.
2002 GT 5sp. 16x,xxx miles
Old 05-11-2016, 06:45 PM   #9
Nvm figured out why. There's a wire meant to pick up on a 12 volt signal from the reverse lights and tell the radio to switch over. I accidently fed 12 volts to the tail lights at all times.
Sent from my SM-G920V using Mustang Evolution mobile app
Old 05-12-2016, 04:57 AM   #10
jeno's Avatar
Awesome glad you got it all figured out
Sent from my LG-H811 using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Anyone use the Raxiom rear view camera mirror? 2013GTpremium Mustang Audio & Video 2 11-17-2015 09:28 AM
Rear View Camera au01st Mustang Audio & Video 24 06-14-2015 09:07 PM
Rear view camera with mirror display sbbamafan Mustang Audio & Video 0 12-22-2013 08:48 PM
2010 GT Rear view mirror camera jrny99 2011-2014 Mustang GT 2 03-15-2012 12:24 AM
Mustang 99 up rear view mirrors power $100 pair Acha3 Mustang Parts for Sale and Wanted 0 08-23-2004 05:50 PM
07:51 PM
