Pulleys and Charging System - Mustang Evolution
Old 05-10-2016, 08:57 AM   #1
Michael.s.king's Avatar
Region: Maine
I think I have a problem with my pulleys. Could a bad pulley or pulleys cause the engine to run like crap through a specific RPM range? Could it also cause the battery light to come off and on?
It squeaks real bad in the winter and was going to change the pulleys because of that, but wanted to see if it would cause any of the above. I changed the belt too. Thanks
Michael.s.king is offline   Reply With Quote
Old 05-10-2016, 12:00 PM   #2
Although the pulleys could be the cause of the squeaking noise, it is unlikely that they are the cause of your battery light and driveability problems.
You should begin the diagnosis process by having the charging system (alternator/battery) tested.
Old 05-10-2016, 06:00 PM   #3
fenixignition's Avatar
keep an eye on your alternator pulley. if its locking up and causing the belt to squeal against it, that could be why your battery light comes on. if your alternator isnt spinning, then it wont produce enough voltage, and if the voltage is below 13v or so then the battery light will come on because the battery is not being charged. it may be something else causing your engine to slow down though. cant say with this little info.
2002 GT 5sp. 16x,xxx miles
Old 05-11-2016, 02:59 PM   #4
95v686gt's Avatar
Helps to know what year car also. A slipping belt will affect the charging system along with other things. Bad voltage will cause numerous issues with drivabilty
Sent from my LGMS330 using Tapatalk
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 05-11-2016, 03:33 PM   #5
Revvv's Avatar
I almost hijacked this thread to ask about under drive pulleys. I will try to start a new thread in a bit.
I thought about under drive pulleys due to the OP's issue. Are the pulleys stock?
Old 05-18-2016, 09:53 AM   #6
Region: Wyoming
Underdrive pulley's won't affect how the car runs. It just slows down the accessories. For the most part pullys don't squeak, the belt squeaks. Put on new pullys and an old belt, you'll have the exact same issues.
Indy is offline   Reply With Quote
traction control, check charging system, and a/c acting up 07regency 2005-2010 Mustang GT 7 08-28-2012 01:22 PM
Charging System??? obxdude018 Pre-2005 V6 Mustang 0 02-17-2011 06:57 PM
charging system not working muskrat Classic Mustangs 8 04-12-2008 09:50 PM
A charging system question... silverstang 1996-2004 Mustang GT 1 03-09-2008 07:40 PM
charging system woes Thomas91169 Mustang Audio & Video 15 08-12-2006 12:34 AM
04:26 PM
