Wheel bearing? - Mustang Evolution
Old 05-14-2016, 09:33 AM   #1
Wheel bearing?
Hey guys! Pretty sure i know the issue is the passenger side wheel bearing going out, but i thought i may as well concur with you guys first. The issue is my car makes a pretty loud humming/whirring sound when going in a straight line. The noise stops completely when i turn to the right, but intensifies when i turn to the left. The noise is louder at higher speeds. I checked for anything rubbing on both sides and could find anything. Wheel bearing?
wawanesa5speed is offline   Reply With Quote
Old 05-14-2016, 10:41 AM   #2
Project Pony's Avatar
Could be, fortunately they are not too expensive and pretty easy to replace
Sent from my SAMSUNG-SM-G920AZ using Mustang Evolution mobile app
[SIGPIC][/SIGPIC]
Old 05-14-2016, 12:13 PM   #3
Revvv's Avatar
It could also be a differential problem. You need to get the rear wheels off the ground to check it out.
My 3.73 gears are noisy. I did not do the install. I will likely pull and replace everything at some point. There are people that swear that 3.73 gears make noise. I have ridden and driven enough cars to know that the rear gears should be quiet.
Old 05-14-2016, 05:35 PM   #4
Sorry, shouldve included that the noise is coming from the front passenger side haha. AM has good deals on the bearings, but where do i find the hub dust caps and spindle nut?
Old 05-14-2016, 05:44 PM   #5
jeno's Avatar
Whats wrong with dust cap and spindle nut you have now and since you gonna do this i would do both sides
Sent from my LG-H811 using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 05-14-2016, 07:02 PM   #6
Revvv's Avatar
Oops
Old 05-14-2016, 07:21 PM   #7
Yeah my plan was to do both sides. I read that the nut is one time use only, and that the dust caps are likely to break when removed?
Old 05-14-2016, 07:29 PM   #8
jeno's Avatar
Call am or lmr and ask specifically for those parts
Old 05-14-2016, 09:15 PM   #9
I've re-used the nuts before on cars, they hold fine. My truck has new bearings on all 4 corners since last year and no issues at all.
Old 05-14-2016, 10:11 PM   #10
Found some on rockauto for really cheap. Think ill go with that.
Pinion Bearing or Wheel Bearing? SCCofSV 2005-2010 V6 Mustang 0 09-30-2012 02:43 PM
Wheel bearing???? Plz help Stanggt1990 1979-1995 Mustang GT 16 06-16-2012 01:14 PM
wheel bearing Bosaliniee 1996-2004 Mustang GT 4 05-23-2012 10:30 PM
Hub/wheel bearing 02PONY 2005-2010 Mustang GT 6 04-09-2012 12:51 PM
Front Wheel Bearing Replacement 00vertstang Pre-2005 V6 Mustang 3 03-24-2007 09:42 AM
11:37 AM
