Performance chip? - Mustang Evolution
Old 05-20-2016, 10:45 PM   #1
Rcmonaco's Avatar
Performance chip?
Hey guys, I was just digging through my car the other day and found this under my steering column. I can't find it online and no one at a shop knows what it is. Is this a performance chip or something? It says "power plug" on it Click image for larger version
Name:	ImageUploadedByMustang Evolution1463805874.478443.jpg
ID:	201235 thanks to anyone who helps. Any input is helpful
Rcmonaco is offline   Reply With Quote
Old 05-20-2016, 10:52 PM   #2
Where does the wire end?
Old 05-20-2016, 10:53 PM   #3
Rcmonaco's Avatar
I tried looking real fast the other day before work and it went waaaayyy up in the wires up above the pedals, so I didn't get a good look. I can take a better look tomorrow
Old 05-20-2016, 11:12 PM   #4
Rcmonaco's Avatar
Ok so impatient me decided to run outside and follow it, two of the wires look like they're grounded and the rest run to this box Click image for larger version
Name:	ImageUploadedByMustang Evolution1463807522.303488.jpg
Old 05-21-2016, 09:23 AM   #5
bkh1994's Avatar
Performance chip?
Does the thing that says #4 in the first picture pull out?
bkh1994 is offline   Reply With Quote
Old 05-21-2016, 04:08 PM   #6
Rcmonaco's Avatar
Yes it pulls out. It's like a little chip
Old 05-21-2016, 04:43 PM   #7
bkh1994's Avatar
Try cranking it without it plugged in. It looks a lot like a security system that the previous owner put on my car. It has that little key that lets you crank it when it's plugged in
Sent from my iPhone using Mustan
Old 05-21-2016, 07:10 PM   #8
Rcmonaco's Avatar
Yep I think you are correct
Old 05-23-2016, 10:26 AM   #9
Region: Wyoming
Originally Posted by Rcmonaco View Post
Ok so impatient me decided to run outside and follow it, two of the wires look like they're grounded and the rest run to this box Attachment 201239
That box is your actual ignition switch. Your key moves a rod in the column, that moves a switch in that box. The position of the switch tells the car what to do (crank, acc etc). You can drop it (if memory serves) 2 torque screws and then slide the switch by hand through the modes if you want, bypass entirely the key switch. But unless you bypass pats it won't start without a key in the column switch.
Indy is offline   Reply With Quote
Old 05-23-2016, 09:19 PM   #10
95v686gt's Avatar
That chip is a security deal. Pull it out and it disables the car. Break the chip it disables the car. It opens the circut in the ignition system so that the car won't start.
Sent from my LGMS330 using Tapatalk
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Chip or no chip- that is the question stangless74 2011-2014 Mustang GT 19 03-04-2013 08:53 AM
I looking for a racing chip or performance chip for my car " 2002 FORD MUSTANG GT? rashane 1996-2004 Mustang GT 3 04-06-2010 12:01 PM
performance chip? Kryptonite 1996-2004 Mustang GT 14 07-11-2007 10:04 PM
Performance Chip or Gears/TLok... which one? AirBrontosaurus Pre-2005 V6 Mustang 10 02-21-2006 09:17 PM
08:03 PM
