Coilovers? - Mustang Evolution
Old 05-23-2016, 06:36 PM   #1
Coilovers?
I know this has been a common topic, but i would just like to ask for myself before i make any pricy decisions. I want to be lower. Currently on Sr springs and mm cc plates. Want at least 1.5 inches lower than current. My car is a daily, and is no means a track car. My price range is 1500ishh. Ive heard of sr, cx racing, eibachs, but can't decide. Pics would be much appreciated. Thanks, any help i can get would be much appreciated.
wawanesa5speed is offline   Reply With Quote
Old 05-23-2016, 09:52 PM   #2
MM coilovers. You already have the plates so it shouldn't be too bad. I run their coilovers for the KONI yellows
Name:	ImageUploadedByMustang Evolution1464061966.877310.jpg
Old 05-23-2016, 10:34 PM   #3
I was looking at those, but i got confused. So if i buy the mm coilovers with springs for the front and rear, and get the ones specific for konis, i could go on am and get the adjustible yellow konis and it would turn those struts to coilovers?
Old 05-23-2016, 11:44 PM   #4
torchdNblazen03's Avatar
Attachment 201461
That stance though !! Have always loved your car man, looks exactly how a new edge should..
torchdNblazen03 is offline   Reply With Quote
Old 05-24-2016, 12:01 AM   #5
Steve96's Avatar
Man I want coilovers one day. I did a ton of research on the Racelands for $500 (plus CC plates of course), and they actually review well from current reviews. I know their not a true rear coilover and not the best for auto xing but from what I found their not bad for going real low and still have adjustability. I was going to try them, but I dont have the funds to experiment currently so doing springs for now until I can get the exact set up I want for DD the car in the summer. But looking into the Racelands might not be a bad idea for you to check them out at least.
1996 GT
Old 05-24-2016, 05:43 AM   #6
I currently run HnR's all around but the car bottoms out over bumps even no or ones when I'm driving at the speed limit. I have to slow down like a ricer would. I'm looking at the Eibach Pro Kit. I still need to get proper camber caster kits to lean out the camber a bit more. What can I do to combat my suspension bottoming out?
Sent from my HTC One_M8 using Mustang Evolution mobile app
Cam416 is offline   Reply With Quote
Old 05-24-2016, 06:02 AM   #7
Steve96's Avatar
What kind of shocks and struts do you have? Were they upgraded or replaced when you did your springs? This could be the issue. I have H&R Supersports and I dont have issues bottoming out everywhere on my 96, some places but thats to be expected.
1996 GT
Old 05-24-2016, 07:33 AM   #8
I bought the car with the HnR's springs and new OEM Monroe shocks front and rear. I did replace rear control arms with UPR and urytane bushings on the front. It's a really bumpy ride but the car hugs the road pretty good.
Old 05-24-2016, 08:40 AM   #9
Just FYI, you don't need coilovers just to lower the car. If you don't need the adjustability of the coilovers you can run the stock setup with lowering springs and a good set of shocks/struts for a lot less money and get the result/ride you are looking for. I had a set of cheap BBK springs, MM CC plates and Tokico Illuminas on my last Mustang and that thing had a very near stock ride while giving a nice drop but not so low that I'd tear the lip off my front bumper going over a speed bump.
Old 05-24-2016, 08:55 AM   #10
So to answer my second question, could i combine this stuff to make a coilover set for my mustang? Is that how the mm coil sleeve system works? And yeah i know i could get lower with a spring and shock setup, but the coilover option seems like it would be worth the money too me. Click image for larger version
Name:	ImageUploadedByMustang Evolution1464101640.687776.jpg
ID:	201470Click image for larger version
Name:	ImageUploadedByMustang Evolution1464101658.662022.jpg
ID:	201471Click image for larger version
Name:	ImageUploadedByMustang Evolution1464101672.754170.jpg
Old 05-24-2016, 10:39 AM   #11
Project Pony's Avatar
I work for FedEx, you would be astonished at how many, and how often we ship back failed racelands. At least once a week. Come to think, I've not seen any other brand sent back through us due to failure. It's not just thier Mustang coil overs either, I've shipped hundreds of them back for all makes and models. The people shipping them have no problem telling me what a big mistake it was to buy cheap, bottom of the line coil overs. Food for thought.
Sent from my SAMSUNG-SM-G920AZ using Mustang Evolution mobile app
[SIGPIC][/SIGPIC]
Old 05-24-2016, 12:56 PM   #12
Steve96's Avatar
It could be the shocks and struts being an OEM replacement causing the issue or not enough dampening. The ride is going to be rough though with the H&R SS springs, you could go with a lesser drop like SR, Steeda Sport that Scotty mentioned, get a 1.5 drop and more of a stock feeling ride since their not as agressive. H&Rs are known to be stiffer with higher spring rates, their a great spring and quality product though. If you want to keep the springs upgrade your dampners and you should feel a diff but it still will be stiff or maybe stiffer with heavy duty dampners but will not bottom out the suspension as much.
1996 GT
Old 05-24-2016, 12:57 PM   #13
Steve96's Avatar
I usually just put about 300lbs of sand bags in my trunk and the same amount in the front on the floor as well, gets it pretty low. Lol
1996 GT
Old 05-24-2016, 01:01 PM   #14
Steve96's Avatar
Thats some good info, see researching them I didnt find anything this negative but most were other cars, mainly German or Japaneese, etc they were reviewing them on. I know a member (The Chech) had them on a Roush new edge and had pretty good results and a couple others on here. If Im going to do coilovers in the future most likely it will be MM as they are tried and true.
1996 GT
Old 05-24-2016, 02:00 PM   #15
Originally Posted by wawanesa5speed View Post
So to answer my second question, could i combine this stuff to make a coilover set for my mustang? Is that how the mm coil sleeve system works? And yeah i know i could get lower with a spring and shock setup, but the coilover option seems like it would be worth the money too me. Attachment 201470Attachment 201471Attachment 201472
Those are all the exact parts i use.... Personally if i had to do it again (which i will eventually) i would do the Bilstein or the MM Damper set up instead of the KONIs
Old 05-24-2016, 02:30 PM   #16
Why Bilstein over Koni?
Old 05-24-2016, 02:36 PM   #17
Yeah why?
Old 05-24-2016, 03:41 PM   #18
Yeah why?
I haven't had issues with mine, but i've heard that when tracked a lot the KONIs can blow or leak easily... If you aren't racing then there shouldn't be an issue, but i do. And the Bilstein sleeve and retainer set up is slightly different, which looks a bit nicer made.
Old 05-24-2016, 06:44 PM   #19
Good reason then. I won't be tracking mine anytime soon so I'll go with the cheapest available
---------- Post added at 12:44 AM ---------- Previous post was at 12:44 AM ----------
Cheapest between Bilstein and Koni that is
Old 05-24-2016, 06:45 PM   #20
Also, you can email them and answer a bunch of questions and then they can recommend spring rates. I went with 375/250. For a street car i'd do probably 300/200. Mine is pretty rough on the street. I also keep my shocks/struts on full soft on the street.
Old 06-13-2016, 09:45 AM   #21
So I called mm and they said they wouldn't recommend their coilovers for a daily driver set up lowered more than 1.5-2 inches. I have the sr lowering springs and I'm still looking to lower a little more than an inch on all 4 corners. Can anybody recommend any other product, springs or coilovers that can get me around a 1/2 inch wheel gap. I still think the sr lowers look alittle 4x4.
Old 06-13-2016, 01:17 PM   #22
Steve96's Avatar
My SR with no isos got me about 1.75" or close to it, front dropped more than the rear. I do see mixed results on the drop from the SRs though? H&Rs will get you close to what you need on the fronts, and Sportlines. The rear is where you will be a little short on what you want. I know its something you shouldnt do but a ton of people do, is to cut a coil off the rears to even it out like on the H&R Supersports. Maybe cut a coil out of both front and back, and you would be well over a 2" drop, but it may ride like crap and lessen the life of the springs, I dont know on that part long term. I know many guys who ran cut stock springs tho and they didnt mind the ride but they also had heavy duty shocks and struts, LCAs, and subframes.
1996 GT
Old 06-13-2016, 01:25 PM   #23
Cx racing coilovers are good for adjustability. Can get you as low as youd like. About 875ish
Sent from my LG-H634 using Mustang Evolution mobile app
19robby2 is offline   Reply With Quote
Old 06-13-2016, 05:05 PM   #24
I'll do some more reaserch about cx racing. I would be nice if the solution I settle with can still use my mm cc plates. Has anyone here got mm coilovers and uses them for a daily and runs them low?
Old 06-14-2016, 02:18 PM   #25
PARTSFROMERIK's Avatar
I've been running racelands for 5 years combined on my Bmw and Mustang, the Bmw was a show car which just saw a lot of highway cruising miles (about 200k in a year) They were great. I have them on my Mustang for about a year and a half now. the car gets beaten to death tons of launches and hard cornering etc. not one time have they disappointed. yes it is what you pay for but the mustang is daily driven I will say it is incredibly low if you want to see it I am on IG as @erikduijsens
PARTSFROMERIK is offline   Reply With Quote
Old 06-14-2016, 10:38 PM   #26
Steve96's Avatar
Ive only really heard negative things about the Racelands on here to be honest. When I was researching them all the reviews I could find were favorable or at the least moderately rated. Ive spoke to several people on Instagram about their Mustangs with Racelands and they all love them for the money
---------- Post added at 11:38 PM ---------- Previous post was at 11:37 PM ----------
I was thinking of trying a set a while back but I will be waiting now
1996 GT
Old 06-15-2016, 12:05 PM   #27
Ende up going with a set of those Tein lowering springs. The ones that promise 2.5 drop in the front and 2.3 in the rear, figure I'll run those with no Isos, Koni yellows and steeda x2s and sell my old sr springs. Hopefully this will give me the look I want!
Old 06-15-2016, 12:19 PM   #28
At the end of they day remember its 500$ with camber plates lol. But I have no complaints and I have been on them for 2 yrs.
Old 06-15-2016, 07:00 PM   #29
Steve96's Avatar
That will be real low. I thought about those same springs too, the Tein S Techs I think. Their a good name and quality. Hard to find a lot of pics or reviews of Mustangs that use them. They are priced well too. Have to put up some pics for sure. You will prob have to roll your fenders Im assuming since in front you will be pushing 3" lower
1996 GT
Old 06-15-2016, 08:17 PM   #30
Yeah, even with my sr springs my rear fenders just barley my rear tires. Looks like I'll have to roll. I'll post lots of pics, yeah it doesn't seem like to many stang owners run Tein.
Old 06-15-2016, 11:55 PM   #31
Steve96's Avatar
When I shopped them they were like 649 or 689 with CC plates. Nevertheless cheap
1996 GT
Old 06-22-2016, 01:34 PM   #32
Name:	ImageUploadedByMustang Evolution1466623978.588910.jpg
ID:	202726 springs and LCA came today. They both look amazing. Really exited to see how these springs will look and perform!
Old 06-24-2016, 01:24 AM   #33
Steve96's Avatar
Derelection of Duty is the next book on my list to get.
The book covers everything Clinton did to undermine the security of the nation.
Im very interested in those springs too, keep us posted, and pics!
1996 GT
Old 06-24-2016, 03:51 AM   #34
Mile high JDF's Avatar
Lol on what your quote got changed to
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 06-24-2016, 07:16 PM   #35
toneman's Avatar
I bought SR coil overs and caster camber plates too from American muscle. My car is not a daily driver, but they work just fine. The car actually rides better than the Eibach lowering springs I had on it.Click image for larger version
Name:	ImageUploadedByMustang Evolution1466817314.370101.jpg
toneman is offline   Reply With Quote
2013 coilsprings or coilovers?? Villero1834 2011-2014 Mustang GT 28 01-04-2015 12:39 PM
Coilovers for 13' Deepblue_coyote 2011-2014 Mustang GT 8 11-29-2012 06:08 PM
Coilovers. McQueen 2011-2014 Mustang GT 16 09-08-2012 09:14 PM
coilovers? davidn7488 2011-2014 V6 Mustang 0 09-04-2012 01:43 PM
Koni coilovers Venomouz831 1996-2004 Mustang GT 36 08-26-2012 01:27 PM
08:31 AM
