Need help with lower control arm install - Mustang Evolution
Old 05-28-2016, 05:42 PM   #1
cstyle408's Avatar
I have the upper control arm installed but not fully tightened just yet. The lower control arm is bolted to the body of the car but i cant get it to line up with the bolt hole on the axle. The axle must have shifted cuz its a couple inches off. Any one have any ideas, advice, or instructions. Thanks in advance
cstyle408 is offline   Reply With Quote
Old 05-28-2016, 11:28 PM   #2
jeno's Avatar
You need a extra set of hands to push the axle in the correct position to line in back up
Sent from my LG-H811 using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 05-29-2016, 04:24 AM   #3
Strange Mud's Avatar
when Robostang & I did this (we helped each other with both cars) we had the car in the air on jack points and did one side at a time holding the rear end up some with a jack.
Old 05-29-2016, 05:39 AM   #4
I did mine on a hoist which is so much easier but I also had problems lining up the control arms. Big pry bar and an extra hand helped.
Sent from my HTC One_M8 using Mustang Evolution mobile app
Cam416 is offline   Reply With Quote
Old 05-29-2016, 10:02 AM   #5
smsstang's Avatar
If you have the pumpkin of the axle on the jack then you should be fine what I did when changing the upper arm I took one side of the shock off to give more playing room and you have to push the axle but remember to also twist so it's gonna take some muscle . Hope this helps!!
smsstang is offline   Reply With Quote
Old 05-29-2016, 12:58 PM   #6
On the upper torque arms there is a cut out there where you can use a pry bar on to twist the rear different to help line up the bolt holes
Old 05-29-2016, 05:35 PM   #7
jeno's Avatar
Hey good to know when i do mine
Old 05-29-2016, 09:44 PM   #8
cstyle408's Avatar
I got it in.
Old 05-29-2016, 09:49 PM   #9
cstyle408's Avatar
I jacked up the other side right below the shock mount
Old 05-29-2016, 09:50 PM   #10
cstyle408's Avatar
And noticed the differential shifting the direction i needed it to. Then put a second jack under lower control arm of first side and jacked til the holes lined up
---------- Post added at 03:50 AM ---------- Previous post was at 03:50 AM ----------
Thanks for all the help. Greatly appreciated
Old 05-29-2016, 10:47 PM   #11
Good job
For Sale: Bmr upper control arm, lower control arms and relocation brackets blacked out gt Mustang Parts for Sale and Wanted 26 05-30-2014 09:04 AM
Lower control arm help! ivan88GT 1979-1995 Mustang GT 4 05-14-2014 06:29 PM
upper/lower control arm install chipshot101 1996-2004 Mustang GT 4 07-27-2004 07:18 PM
Lower control arm bolts Monkey Pre-2005 V6 Mustang 1 07-15-2003 10:37 AM
08:55 AM
