1st gear to 2nd gear grind - Mustang Evolution
Old 05-29-2016, 05:44 AM   #1
It seems to a little rough to 2nd gear when the car is cold. As it warms up it easier to shift to 2nd gear. Any ideas?
Sent from my HTC One_M8 using Mustang Evolution mobile app
Cam416 is offline   Reply With Quote
Old 05-29-2016, 07:20 AM   #2
Strange Mud's Avatar
grind or rough?
notchy (rough) is common. A grind is a problem worthy of wtty fix.
Old 05-29-2016, 07:42 AM   #3
Westcoast408's Avatar
I think it s normal when the car is cold. Sometimes mine does that early in the morning going from 2 to 3rd but never after it s warmed up.
Sent from my SM-G920T using Mustang Evolution mobile app
99 Mustang GT F.R 3.73s, MGW Short Shifter, BBK Cai, BBK 70mm Throttle Body, Mach 1 Chin Spoiler, SR Lowering Springs, Koni shocks and struts, Mach 1 Grill Delete, Black Billet Fuel Cap, Trick Flow 75mm Plenum, Raxiom Smoked Tail lights, Magnapack Mufflers
Westcoast408 is offline   Reply With Quote
Old 05-29-2016, 07:45 AM   #4
Steve96's Avatar
My 96 does this too from 1st to 2nd when its cold, easy shift and it doesnt, only when Im getting on it a little bit and its not warmed up all the way, like half throttle pulling out into traffic or something. After its warmed up it doesnt do it, maybe a couple off times but it may have been me, lol
1996 GT
Old 05-29-2016, 08:31 AM   #5
Originally Posted by Strange Mud View Post
grind or rough?
Rough describes it best. Only when cold.
Old 05-29-2016, 08:39 AM   #6
v8pony's Avatar
TR 3650? Extremely common in these trannys, it's normal.
2002 5spd GT
Feb 2013 Mustang of the Month
Old 05-29-2016, 09:02 AM   #7
Any point getting it rebuilt?
Old 05-29-2016, 07:00 PM   #8
ddtmoto's Avatar
Region: Utah
if the rebuilder knows these gearboxes and will money back guaranty in writing that his expertece will address your 'issue'... probably won't happen.
ddtmoto is offline   Reply With Quote
Old 05-30-2016, 08:30 PM   #9
Change the fluid to 3.2 quarts of Synchromesh. But the 3650 is notorious for this, quality control issue on them from the factory. A rebuild with all the TSBs done will address this issue. Basically the TSBs are a new fork, syncrho assembly and a revised fill. I had a rebuilt 3650 that shifted like a dream, absolutly zero issues.
Old 05-30-2016, 08:43 PM   #10
Thank you
Mustang 2nd gear cold trans grind wawanesa5speed 1996-2004 Mustang GT 45 09-01-2016 09:14 PM
Rough shift from N to 1st and 2nd gear new '14 kgallowaypa 2011-2014 V6 Mustang 31 09-05-2014 05:44 PM
1st gear & 2nd gear out! Vick Classic Mustangs 3 05-01-2012 08:29 PM
2008 3rd gear grind when cold gotmach Pre-2005 V6 Mustang 16 02-06-2009 07:07 AM
reverse gear grind chris098 1996-2004 Mustang GT 8 01-21-2008 09:49 PM
06:30 AM
