Rear end question - Mustang Evolution
Old 05-29-2016, 08:21 AM   #1
dayves's Avatar
Rear end question
Hey guys, I've been having an issue coming from the back half of the car for awhile an it's just been low priority but it's time to fix it. When I hit bumps in the road (at low speeds like 1-2nd gear), there a small clicking sound coming from the back, it also happens when I shift sometimes and the car jerks a bit the clicking happens, you can hear it from outside the car as well an it's fairly loud. Any ideas??
dayves is offline   Reply With Quote
Old 05-29-2016, 08:35 AM   #2
jasondanger's Avatar
I'm thinking it's your control arms, bushings are probably worn out. I had the same issue on my Mach 1. Put new uppers and lowers on and it's running smoothly and launching straight as an arrow. You can get a new set for $100- $200, took about 4 hours to put on. It's definitely worth it.
Sent from my SAMSUNG-SM-G920A using Mustang Evolution mobile app
jasondanger is offline   Reply With Quote
Old 05-29-2016, 09:58 AM   #3
dayves's Avatar
What brand do you recommend??
Old 05-29-2016, 10:06 AM   #4
I bought the non adjustable SR performance set from American Muscle, they seemed of good construction. Not sure how they will hold up I put them on only a few months ago but they made a big difference in handling. But the old bushings were shot, as you can see in the pic.
ID:	201705   Click image for larger version
ID:	201707   Click image for larger version
Old 05-29-2016, 11:30 AM   #5
jeno's Avatar
I would go with steeda they have better bushings that last
Sent from my LG-H811 using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 05-29-2016, 11:49 AM   #6
Project Pony's Avatar
I'm trying to decide between the MM ones and the Steedas. Both seem to be good quality, though I may go with the MM as they are a little cheaper.
"Insert clever phase here"
[SIGPIC][/SIGPIC]
Old 05-29-2016, 12:44 PM   #7
dayves's Avatar
Does steeda not make a upper and lower set?? I can only find uppers or lowers, not a whole set from am
Old 05-29-2016, 04:57 PM   #8
fenixignition's Avatar
dont forget, its not really a good idea to replace the uppers with polyurethane without reinforcing the torque boxes. launching will cause extra stress on them. MM doesnt even sell uppers except for replacement stock bushings.
2002 GT 5sp. 16x,xxx miles
Old 05-29-2016, 05:08 PM   #9
phatspeed7x's Avatar
I have Steeda lower control arms installed in my 04 GT. Best suspension upgrade I did.
Worth every penny.
Sent from my LG-H900 using Tapatalk
~2004 GT with Bolt ons~
phatspeed7x is offline   Reply With Quote
Old 05-29-2016, 05:23 PM   #10
jeno's Avatar
Yes they do on steedas site
Old 05-29-2016, 05:26 PM   #11
jeno's Avatar
Well steeda says theres is different and wont damage the torque boxes due to their design in the bushings did some research and all seems good
Old 05-30-2016, 03:09 AM   #12
I kinda remember reading about that actually.
Sent from my SM-G920V using Mustang Evolution mobile app
Old 05-31-2016, 05:41 PM   #13
Watch the bushings in those SR ones. They are not the best by any means.
Old 05-31-2016, 08:07 PM   #14
Thanks man, after reading this I'm starting to think I should have gotten something else, I only drive that car like once a month or so, so hopefully they'll hold up at least a little while.
Old 05-31-2016, 08:42 PM   #15
Steeda... Speed matters
Old 05-31-2016, 10:27 PM   #16
Steve96's Avatar
If the car is driven that little Im sure you are fine, even if you drove it more it would be fine I would think for a couple years. Unless its being pushed to the max all the time
1996 GT
Old 06-01-2016, 02:17 AM   #17
Sometimes lol oh well I'll run them till they wear out and get new ones. At least I did beef up the torque boxes while I was in there so they should be good. One had a small tear so I went ahead and welded them 100%
Old 06-01-2016, 03:45 AM   #18
Don't they sell replacement bushings for cheap anyway? If the arms hold out, just replace the bushings next time.
Old 06-01-2016, 08:10 AM   #19
Steve96's Avatar
Good point. I was also thinking this, unless they are an odd size or something.
1996 GT
Old 06-01-2016, 08:29 AM   #20
dayves's Avatar
If they sell replacement bushings can't I just buy those instead of new Control arms?? Or is that just for aftermarket ones??
Old 06-01-2016, 11:29 AM   #21
Steve96's Avatar
Im sure you can
1996 GT
Old 06-01-2016, 06:44 PM   #22
yes you can. in fact i already bought some, but I am leaning toward buying the steeda control arms instead. The replacements require you to tear the old rubber bushings out of the metal cups which are pressed into the stock control arm. you need to clean it our with a wire wheel or sandpaper. then you slide in the polyurethane bushings into the cups and bolt them back on. the easiest way is one control arm at a time, which would take quite a while. i only have sundays off from work, so i havent really attempted it yet. its like 80 bucks and they sold it on amazon and american muscle. made by Prothane.
Old 06-03-2016, 12:00 AM   #23
Eh, at 80 bucks and the effort required I'd go with the Steedas or MM's.
[SIGPIC][/SIGPIC]
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
another rear end question ryanxstang Pre-2005 V6 Mustang 1 09-22-2007 08:57 PM
rear end question colinsv6stang Pre-2005 V6 Mustang 10 05-22-2005 10:53 AM
&.5 Rear end question ponyboy1995 Pre-2005 V6 Mustang 2 01-26-2004 03:44 PM
04:34 AM
