5 link suspension - Mustang Evolution
Old 05-29-2016, 09:21 AM   #1
5 link suspension
Hey guys , I have saved a couple of pennies got about 2,500 towards suspension mods, right now I have full steeds sfc , mm camber plates , ford c line springs , tokico Blues , strut tower brace on a 97gt
I'm thinking the first and most expensive is a 5 link .
Any one know realistic install time
And also what else should I install since I will be there
Plus do you guys see any other set up that would be bettering
Car will be driven on street occasionally in NYC , some autox and track days as well
Thanks in advance
cone carver is offline   Reply With Quote
Old 05-29-2016, 10:06 PM   #2
2500 pennies is only $25.
Is this car a daily driver? Or is it going to be mostly a track car that won't see very much street driving?
Old 05-30-2016, 05:46 AM   #3
It will be driven about 1,500 miles a year on the street.
Old 05-30-2016, 07:13 AM   #4
dave73's Avatar
I know this works great!Click image for larger version
Name:	ImageUploadedByMustang Evolution1464613996.317261.jpg
dave73 is offline   Reply With Quote
Old 05-30-2016, 01:18 PM   #5
jeno's Avatar
Originally Posted by dave73 View Post
I know this works great!Attachment 201764
Its a 97 he has
xxr staggered 17's, ford racing c springs, tokico blue struts, koni orange shocks, shorty billit antenna, billit gas cap, UPR CAI, UPR O/R Xpipe, Magna flow exhaust, Mach1 grill delete w/ chin spoiler, honeycomb blackout, Bama tuned 93 OCT.
jeno is offline   Reply With Quote
Old 05-30-2016, 06:42 PM   #6
Thanks in advance
With $2500 you can get MUCH better than that 5 link.
1. MM LCAs $260
2. FTR Watts Link $1,000
3. MM Torque Arm $ 450
4. MM Rear Sway Bar $370
My set up is:
MM subframe connectors
MM LCAs
MM Panhard Bar
MM Torque Arm
MM Coilovers all around
MM Camber plates
I got the Panhard bar before the FTR Watts Link came out (my friend's design).
The rear end in my suspension is pretty on point right now. I need more front suspension to balance it out, but definitely does the job.
Old 05-30-2016, 06:53 PM   #7
dave73's Avatar
5 link suspension
That FTR Watts Link is pretty sweet!
Old 05-30-2016, 08:26 PM   #8
The 5 link is a good setup but the install will be $$$ unless you are good at welding. TBTH, if you want a street car that goes around corners... IRS.
Old 05-30-2016, 10:39 PM   #9
IRS would need a lot more $ needed to be as competitive, and it would definitely dig into his funds to just get a bone stock IRS. Get the right shock and spring in the rear on a SRA and it can be plenty comfy.
Old 05-30-2016, 10:42 PM   #10
It is a really nice unit. Cool thing about being friends with the owner of FTR, when i eventually have money to build my car right i will be able to just drive over and pick up all the parts lol. Still gotta get back with him to finish up the diffuser design. Just gotta fix my car first.
But the pan hard bar is one of the most noticeable mods i did to my car for cornering, and a Watts Link is so much better.
Old 05-31-2016, 06:48 AM   #11
You've got the Watt's link, control arms and torque arm right around $1700 or so which is what a good IRS and a FTBR or MM kit is going to cost if he does the install himself.
I dunno its not for everyone, I like it. The Watt's or TA/PHB setup, the IRS and the 5 link are all good choices IMO and are all going to be about the same cost.
I still kick around doing a poor man's 3 link and calling it good for a 400hp street car.
Old 05-31-2016, 03:02 PM   #12
I have been considering the IRS, though. A bit more predictable, and the weight may actually help balance out the car.
Old 05-31-2016, 10:44 PM   #13
I would do everything on your list except the five link. Also replace any of the suspension/steering components that are worn out. Depending on the mileage on your car, that may be everything that moves in the suspension.
And invest in a set of super sticky tires!
Save whatever is left, and put it towards a PI swap on your engine.
You should go do a few autocross/track day events before deciding to add substantial suspension modifications. You may want to race the car in a specific class that does not allow certain suspension modifications.
Old 06-01-2016, 06:16 AM   #14
Yep, its heavier but it balances the car better. The FTBR or MM kits aren't exactly expensive or super hard to do while the rear is out and then you are good to go. I'm for sure doing one, actually going to try to trade my 34k mile SRA/control arms/exhaust/3.73s for a good condition IRS and catback.
Old 06-01-2016, 12:04 PM   #15
I'm sure i'd be able to trade my PHB, TA, LCA, 4.10, coil over rear end for a decent IRS.
Old 06-01-2016, 08:00 PM   #16
Hello ,
The car has the pi swap already and i have nitto nt05's , brakes all sorted as well .
I have done some autox and a track day on the current set up .
It's right at the edge of being a dd , with the sparcos and harness and no Ac . It's not that comfortable lol
I just want the next level of handling
On a realistic parts budget . I can do most installs as long as we aren't talking about welding
So maybe I should have asked
What dd/ autox / track day upgrades would you guys do considering what I already have on the car for about 2k?
Old 06-01-2016, 08:16 PM   #17
Hello ,
1. MM LCAs $260
My set up is:
MM LCAs
MM Panhard Bar
MM Torque Arm
MM Camber plates
Do this set up.
Old 06-01-2016, 08:43 PM   #18
When you autocross the car, do you race in a specific class? Or do you just do "fun runs", and go out and try to turn fast laps?
The reason that I ask is because if you want to race competitively, there are rules about what modifications are allowed. Mods that change the geometry of the stock suspension will bump you up into classes that are difficult to be competitive in with these generation of Mustangs.
I raced my Bullitt on a basically stock, completely rebuilt suspension, and it was a reasonably competitive car on sticky street tires. After I felt like I reached the limits of the car on street tires, I purchased a set of Hoosier A6 tires and the car suddenly became VERY competitive.
So my recommendation is, if you feel like you can proficiently drive the car faster than it will go on street tires, move up to a set of R-comps. Once you feel like you have mastered the car on those tires, then start thinking about what modifications need to be done to the suspension to make you faster.
Whiteline Watts Link Rear Suspension NewMtang 2011-2014 Mustang GT 5 01-08-2014 01:04 PM
Whiteline Watts Link Rear Suspension NewMtang General Mustang Discussion 17 12-24-2013 07:03 PM
All members that link to their garage via sig need to update link! Brent ME Site Help & Announcements 5 03-21-2005 05:34 PM
03:11 PM
