Speed sensor for automatic transmission - Mustang Evolution
Old 05-29-2016, 01:50 PM   #1
mustang_brody's Avatar
Where is the speed sensor for a 04 mustang gt
mustang_brody is offline   Reply With Quote
Old 05-29-2016, 05:38 PM   #2
jeno's Avatar
You have to use a tuner to adust it for tires bigger than stock and rear gears
Sent from my LG-H811 using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 05-29-2016, 06:30 PM   #3
Diehard's Avatar
In other words there is no physical speed sensor.
Speed is calculated based on tire size, gear ratios and engine RPM.
Well there are speed sensors for the ABS system but don't think that's used for odometer.
Old 05-29-2016, 06:42 PM   #4
jeno's Avatar
Exactly
Old 05-29-2016, 07:28 PM   #5
Slater2111's Avatar
Double tap. But I just now saw you're auto should be in the same general location.
Slater2111 is offline   Reply With Quote
Old 05-29-2016, 07:31 PM   #6
Slater2111's Avatar
Originally Posted by Slater2111 View Post
There should be a Vehicle speed sensor installed on the transmission left hand side. Search for VSS transmission. I think that's what you're referring to.
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Name:	ImageUploadedByMustang Evolution1464571856.189912.jpg
Old 05-30-2016, 08:28 PM   #7
Yep, he asked where the OSS sensor was, not how to change his speedo.
That said, if he IS looking to change his speedo there are no gears past 98 and TBTH the best way is a tune or a speedcal.
Transmission(5-speed to 6-speed) 01mineralgreyv8 1996-2004 Mustang GT 12 05-29-2013 05:58 PM
Can you change a manual transmission to an automatic transmission 2007 mustang? Ekon General Mustang Discussion 3 12-18-2011 03:09 AM
What Ford 4 speed automatic transmission will bolt up to a1976 302 engine? annawan Classic Mustangs 5 12-12-2011 02:57 PM
crank angle sensor/camshaft position sensor instalation 1996v6stang Pre-2005 V6 Mustang 0 11-03-2011 05:57 PM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 04:49 PM
06:33 PM
