Clutch pedal bushings - Mustang Evolution
Old 06-02-2016, 09:56 AM   #1
Tardis Traveler's Avatar
The clutch pedal of my '02 4.6 GT has developed a slight side-to-side wobble (There's visible movement of the bushing, threaded shaft and retaining nut when I rock it left and right). I believe the clutch pedal support bushing is going bad and would like to replace it as simply as possible. Can that one bushing be changed out without removing the quadrant and pawl gear on the other end of the assembly? As always...Thanks for any advice.
Tardis Traveler is offline   Reply With Quote
Old 06-02-2016, 10:29 AM   #2
XSlashDashX's Avatar
Mine vibrates a lot recently. Going to replace the quadrant, cable, and add a firewall adjuster soon to see if that fix my problem.
Clutch Pedal Height Adjustment and Clutch Freeplay Mod ab_mach1 1996-2004 Mustang GT 126 10-20-2017 03:21 AM
Clutch Pedal to Close to the Brake Pedal S Marquard 2011-2014 Mustang GT 1 03-28-2016 09:21 AM
Shaking clutch pedal until pedal is pushed GHO5T5NIPER 1996-2004 Mustang GT 78 05-03-2015 11:47 PM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
clutch pedal sags? tedness Pre-2005 V6 Mustang 4 03-19-2005 11:10 AM
11:23 AM
