Cruise control question - Mustang Evolution
Old 06-02-2016, 12:08 PM   #1
jkeaton's Avatar
I did search, I did! My newly acquired GT convertible has the coveted (ha) Mach 1000 sound system; however, the previous owner installed a POS Boss double din head unit in it. The only speakers working are both the door tweeters and subs and the rear tweeters. I'm going to be buying a factory head unit to go back to stock (I like the stock look) , so that's not the issue at the moment. The real issue is my cruise control does not work. I understand the factory head unit has a speed sensitive volume feature that raises and lowers the volume based on vehicle speed....so, could the fact that whoever installed the aftermarket head unit possible hacked up the wiring or did not use the proper adapters and now that's why my cruise does not work? I've checked all the obvious things, fuse, linkage, clutch pedal switch. They are all there, just wanted to get an opinion on the radio thing before I start throwing parts at it if installing a factory head unit does not make it start working. TIA
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 06-03-2016, 12:10 AM   #2
Revvv's Avatar
Something is wrong somewhere. My stereo and cruise works great. I have a Kenwood head instead of the original Mach unit.
Like you, I prefer the Mach head unit.
Old 06-05-2016, 07:17 AM   #3
jkeaton's Avatar
Well, I left a dealer review on cars.com for this issue and yesterday the dealer called me (it was not a bad review but I did mention I was disappointed). He offered to pay to have the cruise fixed so if the radio fixes it, he will reimburse me the money. If the radio does not fix it, off to the dealer and he will pay for it. Pretty nice of them, IMO.
07 V6 Coupe
Old 06-05-2016, 08:43 AM   #4
Revvv's Avatar
It's always good to hear about a dealership doing the right thing.
Old 06-05-2016, 12:19 PM   #5
carlspeed's Avatar
Sounds like one of the wires might not have been hooked up correctly, and it's causing your issues. The answer is way easier than diagnosing it though. Good luck!
Carl
Lots of F-Bodys and now...
'12 Sterling Gray 5.0 M6 w/ Brembos, 3.73s, Borla S-Type catback, and 15% tint
carlspeed is offline   Reply With Quote
Old 06-09-2016, 06:43 AM   #6
jkeaton's Avatar
Well if anyone ever has this problem, I fixed it. Picked up a used MACH 1000 head unit from ebay. The wiring was a bit hacked up by whoever installed the aftermarket head unit, but after I got everything back together (i.e. original) the cruise control now works. Also the subs and the rest of the speakers. This thing sounds good!
07 V6 Coupe
Old 06-10-2016, 09:01 AM   #7
Region: Wyoming
The only part of the 460 my car still has is the badges.
Cruise works fine.
Indy is offline   Reply With Quote
Old 06-11-2016, 01:09 PM   #8
salsa04GT's Avatar
Now that your cruise works tell me do you have an indicator light on the cluster telling you it's on or set? It's not hard to just press the buttons and let off the throttle to tell, but just nit picking about the cluster light I guess
salsa04GT is offline   Reply With Quote
Old 06-11-2016, 05:11 PM   #9
Revvv's Avatar
I have an aftermarket stereo and my indicator light does not work. Cruise control works just fine though.
Old 06-11-2016, 05:14 PM   #10
Revvv's Avatar
If I run across an original Mach head unit it will be put back in my car. My Kenwood has a lot of features, but I prefer the factory set up.
Old 06-11-2016, 05:20 PM   #11
Slater2111's Avatar
I have an original Mach 1000 head unit. There's the common CD stuck in it that won't eject. If I can find it I'll PM you if you really want it.
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Slater2111 is offline   Reply With Quote
Old 06-12-2016, 12:41 PM   #12
Revvv's Avatar
Definitely send me a PM. I'm sure I can repair the CD player.
Old 06-12-2016, 08:06 PM   #13
salsa04GT's Avatar
I have the original Mach system in my 04 GT. never replaced to my knowledge. The only other previous owner was over 70 yrs old. But cluster light still doesn't work. Cruise works great. Is there even a light for the cruise?
Old 06-12-2016, 09:35 PM   #14
Revvv's Avatar
I honestly don't know, but my cruise control works regardless. I'm too lazy too look up whether or not a cruise indicator exists on our New Edge Mustangs. Lol
Old 06-12-2016, 11:01 PM   #15
Revvv's Avatar
All of the research I have found so far claims that there IS NOT a cruise control indicator light in the New Edge Mustangs.
Old 06-12-2016, 11:38 PM   #16
99GT4.6's Avatar
My 1999 GT has no indicator light for the cruise control. FWIW it also has the stock Mach 460 audio in it.
99GT4.6 is offline   Reply With Quote
Old 06-13-2016, 06:58 AM   #17
jkeaton's Avatar
No, there are no indicators telling you the cruise is on.
07 V6 Coupe
Old 06-13-2016, 07:00 AM   #18
jkeaton's Avatar
Copy me on that PM too! I have "CD ERROR". I've done some reading on here regarding that, but most threads just say it's common and none that I could find mentioned a fix.
07 V6 Coupe
Old 01-09-2017, 02:33 PM   #19
jkeaton's Avatar
Question for anyone who has upgraded the Mach 1000 head unit with aftermarket head unit, how are the rear subs controlled? With the stock Mach 1000 head unit, there is a button to turn the "Mach 1000" on and off. What would control it on an aftermarket unit?
07 V6 Coupe
Old 01-09-2017, 04:23 PM   #20
The cruise control on the New Edge was available as an "accessory," so there wasn't any indicator on the dash.
Autocorrect is my worst enema...
Old 01-09-2017, 05:04 PM   #21
jkeaton's Avatar
Yes. We figured that out awhile back. Thanks.
07 V6 Coupe
Old 01-09-2017, 05:26 PM   #22
Why is everyone replying to 5-year old threads lately(????)
Old 01-09-2017, 07:01 PM   #23
jkeaton's Avatar
Actually 6 months.
07 V6 Coupe
Old 01-09-2017, 07:20 PM   #24
(I was answering for NEW viewers) (...yeah... that's believable)
Name:	ImageUploadedByMustang Evolution1484011060.412935.jpg
...& those people from the 60s lol
Old 01-09-2017, 09:53 PM   #25
Just run the cluster diagnostic and you can see all of the idiot lights available.
Neuron is offline   Reply With Quote
Old 01-10-2017, 06:48 AM   #26
jkeaton's Avatar
Grr...forget about the dang cruise control light. I'm asking about the Mach 1000 system....
07 V6 Coupe
Old 01-10-2017, 01:21 PM   #27
Don't need to.
---------- Post added at 12:21 PM ---------- Previous post was at 12:20 PM ----------
What cruise control light?
There ISN'T a cruise control light.
Old 01-10-2017, 02:34 PM   #28
jkeaton's Avatar
Don't need to.
Wait! You said there wasn't one! I'm so confused.
07 V6 Coupe
Old 01-11-2017, 09:40 AM   #29
You said "forget about the cruise control light," but there isn't one to forget about!
Factory speed control or dealer speed control (cruise control) Otlaw80 1979-1995 Mustang GT 6 08-18-2011 08:42 PM
tv cable or cruise control ??? fastang11 Pre-2005 V6 Mustang 4 12-25-2005 02:30 PM
1995 3.8 cruise control? v6Stangin95 Pre-2005 V6 Mustang 7 09-24-2005 04:02 AM
WTB: Trunk Carpet (Black) and Cruise Control On/Off Black95GT Mustang Parts for Sale and Wanted 0 02-16-2004 08:23 PM
07:13 PM
