AC Recharge? - Mustang Evolution
Old 06-03-2016, 12:54 AM   #1
Steve96's Avatar
AC Recharge?
My 96 has had ice cold AC until this summer. It started off cold a couple weeks ago and now its not at all. I think and hope it just needs a recharge as it has always worked perfectly and been extremely cold since Ive had it the past 6 yrs or so.
Has anyone done the recharge kit you can buy at parts stores? I have never used one and thought it was worth a try?
1996 GT
Old 06-03-2016, 06:23 AM   #2
PARTSFROMERIK's Avatar
Be really careful with those kits, if you overcharge you won't get any cooling or worse you can blow out the compressor and that wouldn't be fun. If you have any friends at any local dealers you can ask them to bring in your car to get a proper evac and recharge to them it should be little to no cost. I work for BMW and I got my car's a/c recharged here I think it's like 3cents per oz of freeon.. If you want to take the task remember you have to monitor high and low pressure to properly recharge an a/c system. Bite the bullet and take it to a dealer if it has to come to that. Replace your drier also, it's fairly cheap and could solve your issue, a lot of people over look it.
PARTSFROMERIK is offline   Reply With Quote
Old 06-03-2016, 07:56 AM   #3
fomoco4life's Avatar
I tried the kit a few weeks ago on my F150, easy job, and had enough left to top off the mustang as well. Ford wanted $180, the can was $50
Old 06-03-2016, 01:09 PM   #4
Steve96's Avatar
I will do my research for sure before I go crazy with anything. Thanks for the info. I dont have any friends with a dealership or at a dealership unfortunately
---------- Post added at 02:09 PM ---------- Previous post was at 02:08 PM ----------
This is about what I was thinking for mine but just want to take a look at whats out there before I jump into it.
1996 GT
Old 06-03-2016, 01:32 PM   #5
You can do the advanced refill just be careful to not overcharge it because it will not cool down either..
Old 06-03-2016, 02:56 PM   #6
Steve96's Avatar
Talked to a couple people I know one is a certified ASE mechanic and he said the same thing, try the stuff from the auto parts store but dont over charge it and check it periodically
1996 GT
Old 06-03-2016, 02:58 PM   #7
Try to borrow some high and low gauges brother! so you have a more accurate refill
Old 06-03-2016, 02:58 PM   #8
Steve96's Avatar
Anyway bought some at Advanced Auto for $35. Checked to make sure my ac comp clutch was coming on and it was, so I then followed the instructions and checked the pressure every 10 to 15 seconds, emptied almost the whole bottle, doesnt feel like it will ever empty 100%. But the air is blowing as cold as ever now, and the pressure is in the good range. Prob the first recharge it has ever had in the past 20 years.
1996 GT
Old 06-03-2016, 03:07 PM   #9
I'm glad everything worked out brother!
Old 06-03-2016, 03:12 PM   #10
Steve96's Avatar
Thanks. We will see it lasts, Im hoping it will
1996 GT
Old 06-03-2016, 03:12 PM   #11
IF not I got you on some hooks up ;D
Old 06-24-2016, 05:26 AM   #12
Torino's Avatar
I used the A/C Pro and had great results as well...I know that my post is late but just wanted to let others know that someone else had positive results with the item.
Sent from my SM-G7102 using Mustang Evolution mobile app
Torino is offline   Reply With Quote
Old 06-24-2016, 09:15 PM   #13
I agree. The compressor oil we use has dye in it, so if your cars AC system has a leak it's easy to find.
Sent from my HTC One_M8 using Mustang Evolution mobile app
Cam416 is offline   Reply With Quote
Recharge kit Liebert91stang 1979-1995 Mustang GT 8 09-12-2013 07:55 PM
Recharge Air Filter TBone Pre-2005 V6 Mustang 11 04-24-2006 07:07 AM
09:17 PM
