Heel Toe Shifting - Mustang Evolution
Old 06-03-2016, 05:16 AM   #1
Heel Toe Shifting
I have a 03 GT and man is it hard to Heel tow shift properly. I drove civic before and they were easy as pie to shift but this beast is opposite. I find the gas pedal too far to the right and way below the brake pedal.
Any ideas?
Sent from my HTC One_M8 using Mustang Evolution mobile app
Cam416 is offline   Reply With Quote
Old 06-03-2016, 06:15 AM   #2
PARTSFROMERIK's Avatar
Make shift pedal extenders?
PARTSFROMERIK is offline   Reply With Quote
Old 06-03-2016, 07:18 AM   #3
Mile high JDF's Avatar
This should help make it a little easier. http://www.mustangworld.com/ourpics/fcar/99pedals.htm
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 06-03-2016, 07:33 AM   #4
This should help make it a little easier. Mustangworld - 99 - 00 Gas Pedal Adjustment tip
Woahhh I am going to try this out TODAY!!!! thanks man!
Old 06-03-2016, 10:54 AM   #5
Another, much more involved solution is to try and locate a pedal assembly from a Bullitt. The pedals are configured differently than a GT to facilitate easier heel to toe braking.
Old 06-03-2016, 11:33 AM   #6
Oh boy! Thank you all.
Old 06-03-2016, 02:57 PM   #7
Definitely what JDF posted. I didn't even like my Bullitt pedal assembly honestly. I did the spacer.
Old 06-03-2016, 03:05 PM   #8
I did not know the Bullitts had a different pedal location
Old 06-03-2016, 03:13 PM   #9
Yep. They do.
I'm not positive, but the Machs and Cobras may have the same pedal assembly.
Old 06-03-2016, 07:16 PM   #10
fenixignition's Avatar
I did the spacer thing with rubber hose and zip ties
Sent from my SM-G920V using Mustang Evolution mobile app
2002 GT 5sp. 16x,xxx miles
New Product - Steeda S550 Heel/Toe Pedal and Covers Now Available! tj@steeda 2015 Mustang GT 8 03-25-2015 07:43 PM
Remove the struts without messing up Camber/Toe sebasflorez Pre-2005 V6 Mustang 3 09-04-2013 01:14 PM
Camel toe thread.............. 12second5.0 The Bar 12 06-22-2006 11:36 AM
06:47 AM
