Need help with ignition - Mustang Evolution
Old 06-08-2016, 04:13 PM   #1
Hello everyone, on Monday I bought my first mustang, it is a 96 GT with only 20,000 miles on it. But today after work I noticed that it took forever to start up. I think it might just because the other owner drove it less than 1,000 miles a year. It is in perfect condition so I don't think there is something seriously wrong with the car. Does anyone have an idea on why it's doing this?
SN95_96 is offline   Reply With Quote
Old 06-08-2016, 05:41 PM   #2
Sounds like a nice find!
I would begin by verifying that there are no trouble codes present. If there are no codes, you should start replacing the maintenance items, such as the air and fuel filters. And thoroughly inspect under the hood for any evidence of rodent damage. (ie chewed wires, vacuum hoses, etc.)
If the problem persists after doing the routine maintenance, probably a fuel pressure test is in order. I would focus on the fuel system first, due to the low mileage, and the age of the vehicle. A lot of condensation can collect in the fuel tank of a car that is only driven 1000 miles per year! Hopefully, your problem is just due to a semi-water clogged fuel filter.
How does the car run otherwise? Does it idle smoothly? And does the engine pull hard all of the way to red line?
Old 06-08-2016, 06:05 PM   #3
Other than the start up issue it runs like a dream, I tried just turning the key and let the fuel pump give it fuel then repeated that and it fired up right away, it doesn't really bother me that much. All I have to do is let the fuel pump prime up before starting it. The only other thing is I hear this weird noise when the clutch is in, it sounds like three rapid squeaks then stops for a second and does it again, when the clutch is out it sounds perfectly fine. Do you know what this would be?
Old 06-08-2016, 06:49 PM   #4
Yeah, swap out the fuel filter and see if that helps. It's probably the original one that came on the car when it was new.
That sound that you are hearing when you push in the clutch pedal is possibly the pilot bearing or the throw out bearing. If it gets worse, you may want to have it looked at, and properly diagnosed, by a knowledgeable mechanic.
Old 06-08-2016, 09:53 PM   #5
Westcoast408's Avatar
Welcome! I m excited to see your the pics of 96gt
Sent from my SM-G920T using Mustang Evolution mobile app
99 Mustang GT F.R 3.73s, MGW Short Shifter, BBK Cai, BBK 70mm Throttle Body, Mach 1 Chin Spoiler, SR Lowering Springs, Koni shocks and struts, Mach 1 Grill Delete, Black Billet Fuel Cap, Trick Flow 75mm Plenum, Raxiom Smoked Tail lights, Magnapack Mufflers
Westcoast408 is offline   Reply With Quote
Old 06-09-2016, 12:14 PM   #6
I just uploaded a few of them, I'll have to get some more sometime
94 gt losing ignition fire-HELP blackhawkkid308 1979-1995 Mustang GT 12 03-23-2013 11:42 PM
Help....ignition question 13BlkSunshine 2011-2014 Mustang GT 5 09-14-2012 01:19 PM
MSD ignition help blown347ranger 1979-1995 Mustang GT 12 05-30-2007 04:09 PM
Help - Ignition Wiring Diagram mustang2002 Pre-2005 V6 Mustang 2 02-11-2006 09:14 PM
Need help with some possible Ignition upgrades Kiljosh Pre-2005 V6 Mustang 10 11-30-2005 11:26 PM
07:59 PM
