Clutch engagement - Mustang Evolution
Old 06-12-2016, 12:04 PM   #1
Clutch engagement
How high off the floor should my clutch be engaging? Mine might be too high, when I release my clutch I can't use the ball of feet /heel to rotate off the clutch pedal, I have to raise my left foot up and off the pedal. Is that normal?
Sent from my HTC One_M8 using Mustang Evolution mobile app
Cam416 is offline   Reply With Quote
Old 06-12-2016, 02:24 PM   #2
phillip433's Avatar
What kind of clutch do you have?
phillip433 is offline   Reply With Quote
Old 06-12-2016, 05:48 PM   #3
Stock
Old 06-13-2016, 04:08 AM   #4
Revvv's Avatar
I would have to actually see you using the clutch. It would be even better to have someone else drive the car around the block to see exactly what is going on.
Do you still have the stock clutch cable and quadrant?
What year model car?
Old 06-13-2016, 09:28 AM   #5
Revvv's Avatar
I actually paid attention to my feet while driving a little while ago. It is perfectly natural for your heel to leave the floorboard.
Now that I think about it; it would be awkward to leave your foot on the floor while releasing the clutch.
Old 06-13-2016, 11:17 AM   #6
My car is 2003 Mustang GT. As far as I know it's stock clutch , cable and quadrant. I'm looking at getting a center force clutch and factor cable. I was told the plastic quadrant is best over billet ones.
Old 06-13-2016, 11:53 AM   #7
Revvv's Avatar
Plastic breaks, aluminum is much stronger and better suited for a heavier clutch. In reality, at 14 years old the plastic is likely brittle.
Put your foot under the clutch pedal and lift up. If it is the stock quadrant it is self adjusting. You should hear it click as it rotates upward.
Don't force it and break things.
Old 06-13-2016, 05:30 PM   #8
Thanks. Well I find it really high so I won't try to raise it any further. Wilk a fire wall adjuster help make my pedal lower or higher?
T45 Transmission Clutch Fork/TO Bearing Engagement robb15033 1996-2004 Mustang GT 2 06-28-2015 08:54 AM
clutch pedal engagement height Black12 General Car Discussion 0 11-24-2013 10:19 AM
Clutch Engagement graystone2013 2011-2014 Mustang GT 4 07-12-2013 05:28 AM
Clutch engagement issue muscledom 2005-2010 Mustang GT 0 10-22-2012 02:54 PM
clutch engagement problems 1996v6stang Pre-2005 V6 Mustang 11 05-19-2010 08:31 AM
» Members Mustangs
DW
blue
Bluez1
FlyingBobbyG
Add your Mustang
10:45 PM
