Do I need subframe braces? - Mustang Evolution
Old 06-16-2016, 09:48 PM   #1
Hey guys. Just had a question about subframe braces, do I need them? This summer I'm doing a lot of suspention work, new springs, shocks, pan hard, ball joints etc. in an effort to make my car a great handling machine. Subframes have always been on the list, but recently I've heard they are more for drag racing, and add considerable weight. Do I need them on a car that does weekend track days?
wawanesa5speed is offline   Reply With Quote
Old 06-16-2016, 09:51 PM   #2
Slater2111's Avatar
They don't add that much weight. Maximum motorsports makes the best. They are weld in. They do make the car feel more tied together. I don't know why I waited so long to do mine. No regrets.
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Slater2111 is offline   Reply With Quote
Old 06-17-2016, 11:20 AM   #3
Add a lot of weight and only for drag racing? Roofles. They are basically required on any 04-down.
Also MM does NOT make the best ones and that is one of the few things they make that isn't the best. Steeda is going to be the best for regular full length subframes. Other options for ground clearance are Spintech and Global West and then the whole Stiffler's matrix setup. Global West has a matrix too.
Old 06-17-2016, 11:28 AM   #4
Slater2111's Avatar
Well I sure liked them!
Old 06-17-2016, 11:41 AM   #5
Oh they're a really good product, not saying they are bad at all. The Steedas include extra bracing tho and attach a bit more firmly to the chassis. Not really anything you'll notice for a street car or even most ppls weekend track cars. But still if buying new braces I'd always get the Steedas unless running side exhaust or something REALLY lowered. Then it would be Spintech.
Old 06-17-2016, 11:49 AM   #6
Lorraine's driver
ab_mach1's Avatar
Does Steeda make a bolt-on subframe kit? I'm not familiar with the shops around me and really don't trust them. I'd like to replace the stock ones on my Mach.
Instagram: @ab_mach1
Old 06-17-2016, 02:37 PM   #7
Never use a bolt on kit. Find a shop or don't run them. And to answer your question, no they don't.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 06-17-2016, 03:18 PM   #8
Lorraine's driver
ab_mach1's Avatar
Lol I was afraid of that. I need to quit fiddle-fartin' around about it and just find a shop.
Instagram - @ab_mach1
Old 06-18-2016, 05:54 AM   #9
I just replied in a pair and I love them. Makes the car handle like it should from factory.
Sent from my HTC One_M8 using Mustang Evolution mobile app
Cam416 is offline   Reply With Quote
Old 06-18-2016, 07:32 AM   #10
PARTSFROMERIK's Avatar
That is one rusty drive shaft.
PARTSFROMERIK is offline   Reply With Quote
Old 06-18-2016, 09:31 AM   #11
I live in Canada. The previous ow er drove this mustang in the winter on winter tires. It's hard to prevent rust on our salty winter roads. I won't be driving it in the winter.
Old 06-18-2016, 10:46 AM   #12
Oh man that blows, upgrade to an aluminum one? and keep it for those summer drives.
Old 06-18-2016, 10:59 AM   #13
I feel. I live in manitoba. The reason I'm asking about Subframes is because I wanted to know If I needed
To get them before I coated the bottom of my car with rust protect. Didn't want to paint and then grind it off to weld the braces on. My ds looks identical lol
Old 06-18-2016, 12:30 PM   #14
I'm happy I bought them. My car always acted funny over train tracks and uneven ruts. Now it's much more predictable.
Old 06-18-2016, 04:43 PM   #15
Labrat's Avatar
Myself I prefer the BMR SFC011 - Subframe Connectors, Weld-on, Boxed | 2005 - 2014 Mustang | Sub Frame Connectors | BMR Suspension - High Performance Suspension & Chassis to the Steeda product. They are both quality companies that I have purchased from.
Labrat is offline   Reply With Quote
Old 06-18-2016, 05:02 PM   #16
That subframe connector isn't made for the "Edge" platform.
Old 06-18-2016, 05:23 PM   #17
Labrat's Avatar
You are right. Never said it was. But BMR will make a quality part for the edge platform also.
Old 06-18-2016, 05:32 PM   #18
The BMR subframe connector for the Edge platform looks crazy too.
Old 06-18-2016, 05:42 PM   #19
Labrat's Avatar
The major point being made is that you are connecting the front and rear sub frames and that will defintely make your car handle better. And I do agree that the only way to go is with a welded assembly.
Old 06-21-2016, 05:23 AM   #20
I have done to many mods to list on my 97gt
Best mods I have ever done
Are nitto nt05's and subframes come in second , first suspension mod I believe should be done
cone carver is offline   Reply With Quote
Old 06-21-2016, 09:16 AM   #21
Agreed. I'd also recommend replacing the old rag joint steering shaft with MM one piece steering shaft.
Front Upper Strut Tower Braces Kustumb 2005-2010 V6 Mustang 10 03-21-2013 09:30 PM
DIY chassis braces:rear strut tower Yellow50 2011-2014 Mustang GT 9 02-05-2013 08:11 PM
Benifits of strut braces? oldtexasdog 2005-2010 Mustang GT 6 07-01-2010 10:01 PM
Convertible fender braces uvm81 General Mustang Discussion 8 05-29-2009 06:49 AM
So I am getting my braces off... n8r The Bar 19 12-09-2005 02:41 AM
11:48 PM
