Idling issues - Mustang Evolution
Old 06-24-2016, 08:22 AM   #1
Jay180's Avatar
Idling issues
So yesterday I go to drive my car and once I turn it on I hear a loud humming noise coming from the cai and it'll shoot up to 2k in rpms then drop to 500 and turn off I'd have to tap the gas but every time I tap the gas it'll just go up to 2k and I will hear the humming noise again, anyone know what might cause this?
Jay180 is offline   Reply With Quote
Old 06-24-2016, 05:57 PM   #2
Steve96's Avatar
Your IAC valve. It needs to be replaced, only get the motorcraft one, store brand ones are terrible, I tried a couple and they didnt work
1996 GT
Old 06-24-2016, 08:11 PM   #3
Jay180's Avatar
Alright thanks
Old 06-24-2016, 09:11 PM   #4
Steve96's Avatar
It sure does sound like it anyway, you usually get that humming noise from them
---------- Post added at 10:11 PM ---------- Previous post was at 10:10 PM ----------
You can also look for a Hitachi brand IAC as they make the original parts for Ford
1996 GT
Old 06-25-2016, 09:43 PM   #5
Jay180's Avatar
So I switched out my iac valve with another I had around and the humming and crazy idling went away but now it's dying at idle probably 1/3 times
Old 06-27-2016, 01:37 AM   #6
I suppose that the IAC that you had *laying around* could be defective as well...
Did you do the idle relearn procedure, by disconnecting the negative battery cable for 15-20 minutes?
Old 06-30-2016, 09:23 PM   #7
Jay180's Avatar
Yes I did. And when I tried to start it 2 times it tried to start up but sounded like it was choking then the 3rd time it fired up. Fuel issue?
Old 06-30-2016, 10:02 PM   #8
Possibly. You could do a fuel pressure test to find out.
I suspect that it is a problem with your IAC though. I would try a new OEM Motorcraft IAC and see if that solves the idle problem.
Old 06-30-2016, 10:04 PM   #9
Jay180's Avatar
Yeah I'll go check my fuel pressure and switch out my iac. Thanks I'll see if that solves my problem
Old 07-01-2016, 12:41 AM   #10
Revvv's Avatar
Just for an experiment you could clean the AIC. That might surprise you.
2010 GT - issues, issues, issues. Anyone experience this? Binks 2005-2010 Mustang GT 2 05-09-2015 10:22 AM
Idling Issues Cise 1979-1995 Mustang GT 6 01-22-2015 11:52 AM
Idling Issues KARgt13 2011-2014 Mustang GT 19 01-05-2013 07:49 AM
!Help! Engine Idling and Rev Issues 06v6stang Pre-2005 V6 Mustang 5 08-08-2008 07:12 AM
Help Needed In England - Idling Problem glenheyes 2005-2010 Mustang GT 11 04-21-2008 03:08 PM
07:54 PM
