Keeping the 2v - Mustang Evolution
Old 06-24-2016, 11:57 AM   #1
alecas447's Avatar
Keeping the 2v
So after a few tough weeks , I decided to keep the 2v instead of going for a debt for the next 6 years.
So the clutch and tranny pretty much died at the same time.
I just stole my friends 3650 with 40k miles , flywheel, exedy stage 2 clutch, and mgw short throw shifter , all for $500.
I'm still debating if I should try doing it myself or paying $400 for labor.
Any thoughts guys?
Mac o/r H pipe. Flow master super 44s. Accufab 70mm throttle body. Pro comp intake manifold. MSD coils
alecas447 is offline   Reply With Quote
Old 06-24-2016, 12:27 PM   #2
Keeping the 2v
If you don't have time then let a shop do it.
Old 06-24-2016, 12:38 PM   #3
phatspeed7x's Avatar
The transmission swap shouldn't take more than an afternoon with a few buddies. I personally would do the work myself and use the $400 in labor towards another mod.
Glad to hear you're keeping the 2V.
Sent from my LG-H900 using Tapatalk
~2004 GT with Bolt ons~
phatspeed7x is offline   Reply With Quote
Old 06-24-2016, 12:47 PM   #4
rdwelch's Avatar
If you can part with $400 and not lose sleep over it, let a shop do it.
rdwelch is offline   Reply With Quote
Old 06-24-2016, 01:51 PM   #5
alecas447's Avatar
That's what I'm leaning towards more, I don't have much time to do it
Old 06-24-2016, 03:54 PM   #6
Sbales88's Avatar
I would do it myself. It's not like it's a difficult job, also $400 is $400. I'd spend an hour or so a night on it till I got it fixed before dishing out money. I'm also very paranoid about letting someone drive my car, what if they hot rod it? Lol.
Sbales88 is offline   Reply With Quote
Old 06-24-2016, 09:04 PM   #7
Do you have lift access? If no then pay the shop. If you do, DIY with a friend.
Also make DAMN sure they fill it correctly with 3.2 quarts of fluid, do NOT set the stops on the shifter (remove the stops prior) and supply them with a new OEM TB and Pilot.
$400 for a trans/clutch change is actually really REALLY cheap and I dunno how you got all that stuff for $500 but you better be picking up your buddy's bar tab next time you guys go out haha.
Old 06-24-2016, 10:09 PM   #8
Steve96's Avatar
That is a great deal on both accounts!
1996 GT
Old 06-25-2016, 11:59 AM   #9
alecas447's Avatar
Yea it's for sure a great deal
Old 06-27-2016, 11:51 AM   #10
alecas447's Avatar
What oil do you recommend?
Old 06-27-2016, 12:05 PM   #11
Pennzoil Synchromesh.
Old 06-29-2016, 05:07 PM   #12
alecas447's Avatar
Alright guys ! Got it back , after a month, I'm so happy with the results , the car just feels so much better with the shifter and clutch , and the exhaust is a bit better but still there , sigh.
But oh well here it is with my gf try to make me choose between her *** or the car's Click image for larger version
Name:	ImageUploadedByMustang Evolution1467238060.210711.jpg
Old 06-29-2016, 06:06 PM   #13
0440thgt's Avatar
Nice errr, rear end! 😳
0440thgt is offline   Reply With Quote
Old 06-29-2016, 07:32 PM   #14
dave73's Avatar
But oh well here it is with my gf try to make me choose between her *** or the car's Attachment 202949
Car?? What car?
dave73 is offline   Reply With Quote
Old 06-30-2016, 11:29 AM   #15
alecas447's Avatar
Originally Posted by dave73 View Post
Car?? What car?
The car lol,
On a serious note, I'm leaking from where the exhaust manifold connects to the mid pipe, is there anyway to fix this besides replacing the whole manifold ?
Like welding them together or something?
Mac o/r H pipe. Flow master super 44s. Accufab 75mm throttle body. Pro comp intake manifold. MSD coils. MGW short throw shifter, exedy stage 2 clutch
Old 06-30-2016, 03:32 PM   #16
jeno's Avatar
The car lol,
Go to an exhaust shop they can fix it they should be able to make a flange for it
Sent from my SM-N910T using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 07-05-2016, 02:09 PM   #17
alecas447's Avatar
Nope no flange , it's leaking where the manifold meets the mid pipe
Old 07-05-2016, 07:14 PM   #18
jeno's Avatar
What side passenger or drivers side if it's the passenger then you need a new exhaust gasket ir the drivers the a flange
Old 07-05-2016, 07:49 PM   #19
alecas447's Avatar
Drivers side
Old 07-05-2016, 09:31 PM   #20
What no it isn't. The driver's side is a ball/socket the pass is the one with the flange. I mean not sure why its even a question, just order a single gasket there will only be 1 place to put it.
Old 07-06-2016, 06:26 PM   #21
alecas447's Avatar
I fixed the leak.
Now I have coolant leaking inside the car -_-
Old 07-06-2016, 08:53 PM   #22
I fixed the leak.
Well at least you know that can only be one thing. Dash pull time. Its really not hard to pull the dash TBTH. I'd rather do that than motor mounts or a transmission...
Actually... you live in Miami. Do you even need heat? Hell just bypass the heater core and call it good.
Old 07-07-2016, 12:51 PM   #23
alecas447's Avatar
That's exactly what I did, I just bypassed it. I've never even used the heater.
Now I'm going to be doing plugs , what do they have to be gapped at? And I think I'm also going to need a new coolant temperature sensor, I think this is causing me to get 10 smiles per gallon
Old 07-07-2016, 02:57 PM   #24
Gapped to .054, temp sensor is like 2 seconds, just make sure you use high temp RTV on it and let it cure overnight.
Old 08-25-2016, 03:29 PM   #25
alecas447's Avatar
So I've had my car for two months and the throw out bearing has been chattering for a few weeks now and it's the ford throw out bearing , I though those TOBs were the best ones?
doing some house keeping. 99ford Mustang Paint, Appearance & Detailing 28 12-02-2011 12:09 PM
life is really keeping me busy meteorachick The Bar 12 05-08-2010 11:11 PM
So, we've been keeping this a secret for awhile now.. *56K Beware, Pics + Vids Seph Pictures and Videos 23 07-18-2007 06:18 PM
Keeping it real! 03redfire cobra The Bar 7 09-11-2004 11:22 PM
02:30 AM
