Strange Fueling Issue - Mustang Evolution
Old 06-25-2016, 08:50 PM   #1
Revvv's Avatar
The other day I let the car run while my girls sat in the direct sun. I wanted to keep the A/C on (I know, it's dangerous. Don't judge me). About 30 seconds after I opened the cap the car shut itself off. I thought one of my girls turned off the ignition, assuming I forgot.
Today I filled the car and had another odd, but likely related issue. The car was off when I filled the tank. When I tried to start the car it just spun over as if there was either no fuel or spark. I turn the key out of curiosity to allow the fuel pump to prime. I tried to start the car and it spun over several times before firing up.
The car has always started fine. It normally just needs to be bumped over and it fired right up. After the first incident at the gas station the car acted normal. After today's odd occurrence it appears to be acting normal.
The car is an 02 GT. Stock injectors, fuel pump, etc.
What do I need to check? Suggestions?
Old 06-25-2016, 09:44 PM   #2
jeno's Avatar
Codes
Sent from my SM-N910T using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 06-25-2016, 09:45 PM   #3
Slater2111's Avatar
Could be a PATS issue. That was happening to mine when I first got my car. Passive anti theft system. Basically the key has the chip and the ignition has the chip reader. (Basically) when the chip reader or key goes bad, your car thinks it's being stolen. And it pulls either spark or fuel. I can't remember which one. I am pretty sure it was fuel. But you can always get a tune and have your tuner turn off your PATS system.
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Slater2111 is offline   Reply With Quote
Old 06-25-2016, 09:45 PM   #4
Revvv's Avatar
Originally Posted by jeno View Post
Codes
No codes.
Old 06-25-2016, 09:48 PM   #5
Revvv's Avatar
The PATS is turned off. I was a locksmith when PATS, VATS, etc came out. I hated the system then, and I dislike it now.
Old 06-25-2016, 09:50 PM   #6
Slater2111's Avatar
Very well. I hated mine too. I am out of ideas at the moment.
Old 06-25-2016, 09:53 PM   #7
jeno's Avatar
You know what revv how's the alternator and battery
Old 06-25-2016, 09:54 PM   #8
Revvv's Avatar
I need to find out if there is a vent tune that can become clogged, I don't know where to look though.
The fuel filter looks new, but the undercarriage of my car is spotless, so age isn't easy to determine.
Old 06-25-2016, 09:57 PM   #9
Revvv's Avatar
I have not seen any evidence of either failing. In fact. I opened the windows and top a coupe days ago and listened to the stereo for a few hours. I believe the battery is good. I will plug the SCT in and look at the numbers, but I am fairly certain everything will check out as fine.
Old 06-25-2016, 09:59 PM   #10
Sounds like the fuel filter is starting to plug. It seems like your losing pressure that builds back up while the car is spinning over trying to start. Try this, turn your key to on then off about 3-4 times then try to start the car.
Bigshow14 is offline   Reply With Quote
Old 06-25-2016, 10:03 PM   #11
Revvv's Avatar
It could be a filter. It just seems odd that the issue only happens after the fuel cap has been removed.
Old 06-26-2016, 08:05 AM   #12
Torino's Avatar
Fuel pump or fuel pump relay issue? Those things can be intermittent issues!
Torino is offline   Reply With Quote
Old 06-26-2016, 08:34 AM   #13
Revvv's Avatar
Not what I want to hear. I don't even want to think about dropping the fuel tank in that little car. I don't think I can raise it enough to even pull the tank.
Old 06-26-2016, 08:48 AM   #14
Dropping the tank on your car is very easy. Did you try priming the fuel system yet?
Old 06-26-2016, 08:59 AM   #15
Revvv's Avatar
I have not removed the fuel cap again yet. I have only noticed the problem when the cap is removed. I started the car five or six times last night while working on a stereo problem. It fired up as it should every time.
Old 06-26-2016, 09:06 AM   #16
Fuel filter is a cheap piece of mind. Last thing you want is it to fully plugged in traffic or anywhere else besides at home. Ask me how I know.
Old 06-26-2016, 09:15 AM   #17
Revvv's Avatar
You make a good point. Plus the fuel filter is in easy reach at the rear of the car if I remember correctly.
Old 06-26-2016, 10:20 PM   #18
Torino's Avatar
Now I have to check my fuel filter the next time I am home! 😂
Sent from my SM-G7102 using Mustang Evolution mobile app
Old 06-26-2016, 10:29 PM   #19
Revvv's Avatar
Preventive maintenance.
Fuel issue? Ignition issue? jriccard 1979-1995 Mustang GT 7 07-04-2015 12:42 AM
Strange electrical issue Tpbluegt 1996-2004 Mustang GT 8 09-30-2014 06:13 AM
Got a strange issue. Mustang 4pt0 General Car Discussion 5 02-25-2014 09:53 PM
Strange Exhaust Issue michael81 2011-2014 Mustang GT 1 05-05-2012 07:23 PM
Halos/LEDs won't flash! (Strange issue) MarshallYoung 2005-2010 V6 Mustang 4 01-11-2012 11:47 PM
04:57 AM
