Upper Control Arms - Mustang Evolution
Old 06-27-2016, 05:56 AM   #1
0440thgt's Avatar
Upper Control Arms
Are aftermarket upper control arms worth the price, or will just getting lower arms be sufficient on street/mild strip applications?
Seems like the lowers take the brunt of abuse and the uppers are just there for support/connection purposes??
0440thgt is offline   Reply With Quote
Old 06-27-2016, 12:37 PM   #2
It is preferable to leave the stock upper control arms and the OEM rubber bushings. That way the upper control arms can still flex without tearing up the torque boxes. It is probably a good idea to replace the upper control arms with an OEM set, so that you will have a fresh set of upper bushings. There is also rubber bushings pressed into the top of the rear end that should be replaced.
And be sure to purchase a quality set of aftermarket lowers.
Old 06-27-2016, 12:46 PM   #3
0440thgt's Avatar
Thats what I had always heard. Thanks for the confirmation.
Im looking at BMR lowers. Any opinions on them?
Old 06-27-2016, 01:13 PM   #4
BMR is a good brand. I'd go with MM or Steeda tho.
As far as the uppers. Leave them stock, try to find a new OEM set, put a poly bushing on the axle side and leave the rubber up in the torque boxes. When my Steeda GT had the SRA in it they actually took a set of stock uppers and welded a plate across the bottom. I had not seen that before but it makes a ton of sense. Stiffens it up a bit without sacrificing the give of the stock control arms.
You could also try trading your SRA for an IRS straight up if you don't want to deal with a 4 link or doing the whole TA/PHB conversion.
2000 Mustang GT Steeda build #48. Bolt ons, suspension, Novi 2000.
Old 06-27-2016, 07:19 PM   #5
So leave the uppers stock? Should the lowers be adjustable?
04sonicgt is offline   Reply With Quote
Old 06-27-2016, 08:53 PM   #6
Leave the uppers stock and put poly bushings in the axle where they attach. There is a tool to do this you can get from MM I believe, makes it easy to do with the axle still attached although dropping a rear is pretty easy. Lowers don't need to be adjustable.
Old 06-27-2016, 10:12 PM   #7
Hmmm.
I never really thought about boxing the stock control arms. I can't use aftermarket control arms in the autocross class that I race in. I don't remember reading any rules about not being able to box the original control arms though.
I'm definitely going to add that to my list of "grey area" modifications!
Old 06-28-2016, 04:55 AM   #8
0440thgt's Avatar
Thanks for the info guys.
Im planning on a small suspension build this fall.
Here is my short list -
Eibach or Steeda lowering springs
Koni yellow shocks and struts
Lower control arms (and advice above on poly in the factory uppers) on axle side)
Steeda bump steer kit
CC plates
Anything else while I'm in there?
Im working off of a semi budget and cant get too crazy or the Misses will go bezerk. πŸ˜‚
I thought seriously about trading this car for a Boss or 5.0 Coyote car, but I swear I just cant part with it. I ask myself if I would miss it if there was a new 5.0 in its place and I honestly would. Its my first Mustang so it has some sentimental value.
Old 06-28-2016, 05:42 AM   #9
CC plates
Subframe connectors.
Old 06-28-2016, 05:48 AM   #10
Originally Posted by straybullitt View Post
Hmmm.
Came from Steeda like that.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 06-28-2016, 05:14 PM   #11
Project Pony's Avatar
Interesting, if I wasn't already sold on the Steedas I'd probably weld in some plates.
Sent from my SAMSUNG-SM-G920AZ using Mustang Evolution mobile app
[SIGPIC][/SIGPIC]
Old 06-28-2016, 05:56 PM   #12
tj@steeda's Avatar
Im working off of a semi budget and cant get too crazy or the Misses will go bezerk. ν ½νΈ‚
Happy to help with forum pricing!
You can email me at tim@steeda.com - well get you taken care of!
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
Win A $300 Gift Card
tj@steeda is offline   Reply With Quote
Old 06-28-2016, 09:24 PM   #13
jeno's Avatar
Here's some stockers from lmr
https://lmr.com/item/LRS-5500CA-K/mu...RS5500CAK_7904
Sent from my SM-N910T using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 06-29-2016, 03:55 AM   #14
0440thgt's Avatar
Thanks for the link Jeno.
Do we have a forum discount code with LMR?
I have the one thru AM.
Old 06-29-2016, 05:04 AM   #15
jeno's Avatar
There always out there just Google lmr discount
Old 06-29-2016, 08:16 AM   #16
0440thgt's Avatar
10-4
Old 07-18-2016, 09:54 AM   #17
DutchManDann's Avatar
+10000000 on the subframe connectors. Should be the first modification you invest in.
As far as the uppers go, on my car after lowering springs and lower control arms, my driveshaft angles were off and I got a really bad vibration at high speeds.
Aluminum driveshaft and adjustable uppers were the only solution. Hope you have better luck than I did
Sent from my XT1095 using Mustang Evolution mobile app
Roxanne- 1998 Mustang GT Convertible: 5-Speed, 2001 PI 2V swap, o/r h-pipe, Magnaflow catback, MGW shifter,
3.73 gears, Auburn LSD, TA diff cover, MM FLSFCs, Ford Strut Tower Brace, J&M SS Brake Lines, and a lot of visual/restoration work.
DutchManDann is offline   Reply With Quote
For Sale: Bmr upper control arm, lower control arms and relocation brackets blacked out gt Mustang Parts for Sale and Wanted 26 05-30-2014 09:04 AM
lower control arms vs. upper control arms 13 stang22 2011-2014 V6 Mustang 24 05-08-2013 06:03 AM
Upper and lower control arms CodyNelson 1996-2004 Mustang GT 25 12-16-2011 04:02 PM
98 cobra upper control arms? SpectorV Pre-2005 V6 Mustang 6 08-21-2005 07:46 PM
Installing Upper Control Arms Rellik Pre-2005 V6 Mustang 8 09-22-2003 06:20 PM
09:25 AM
