Strut Replacement - Shock Mounts/Bushings Advice Please - Mustang Evolution
Old 06-30-2016, 05:09 AM   #1
I am going to replace the stock shocks/struts on my 2004 Mustang GT with 22K on it. Going to pony up for the Bilsteins. It is a nice day driver which I want to improve the handling but not damage the ride quality since my wife and I take it on the weekends for longer trips.
So far I have put a CAI, short throw, upper/lower control arms, and I will be welding in subframe connectors in a few days. Down the road I will probably change out the brakes to vented discs and replace the stock sway bars.
While I have the struts off the front what else should I have on hand to replace - should I have new shock mounts if so which ones should I buy? Should I get some Energy polyurethane bushings for the top of the strut rods? Any thing else?
I don't think there is anything to change for the rear other than the shocks?
FordTrax is offline   Reply With Quote
Old 06-30-2016, 11:59 AM   #2
Yes!
It is a very good idea to replace the strut bushing.
I just used quality OEM style replacement bushings when I did mine, to keep the ride quality from deteriorating.
Old 06-30-2016, 12:06 PM   #3
Slater2111's Avatar
I got the poly strut mount bushings in mine. Did I notice any difference. Ehh a little. Was it worth it. That's up to you.
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Slater2111 is offline   Reply With Quote
Old 07-01-2016, 09:08 AM   #4
fomoco4life's Avatar
Tie rods and balljoints, I recommend Steeda, and why not new springs while your there, again I love Steeda. Chances are your spring isolators are also warned but that's up to you if you're going to use those or not
Old 07-01-2016, 07:32 PM   #5
tj@steeda's Avatar
Check out these packages for your New Edge.
1999-2004 Mustang Suspension Packages | Steeda Autosports | Free Shipping!
Thanks for the continued support. We have Bilstein packages available with progressive rate springs. The progressive rate springs will make sure you keep a comfortable ride, but at a lower ride height, and with improved handling, as well.
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
2006 GT strut and shock replacement suggestions PendletonCowboy 2005-2010 Mustang GT 1 02-14-2016 05:06 PM
SVE lowering springs with kyb strut and shock kit???? mcvicar04 1996-2004 Mustang GT 1 12-07-2011 09:04 AM
Strut/Shock info Mustangfan2003 1996-2004 Mustang GT 6 11-25-2009 07:43 AM
Shock & Strut ? mrvMustang Pre-2005 V6 Mustang 19 06-17-2006 10:21 PM
whats the best shock strut? powerhungry966 Pre-2005 V6 Mustang 7 04-09-2006 12:48 AM
02:25 PM
