Slack in the Gas Pedal - Mustang Evolution
Old 07-02-2016, 03:38 PM   #1
Revvv's Avatar
If I place my foot under the gas pedal I can lift it a couple inches. Is this normal for the 99-2004 Mustangs?
I have yet to run wide open throttle, but if I decided to do so I would like to run with the throttle body open all the way instead of 3/4 throttle.
Old 07-02-2016, 03:46 PM   #2
jeno's Avatar
Yes that's normal and what do you mean you haven't went wot come on revv just do it
Sent from my SM-N910T using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 07-02-2016, 03:49 PM   #3
Revvv's Avatar
It's a 14 year old engine, and at the moment my only form of transportation. I have not pushed the car past about 4200rpm. I am babying this car to keep it alive as long as possible.
Old 07-02-2016, 05:00 PM   #4
jeno's Avatar
Lol there's not a day I go wot or red line at least once 4200 another 2000 rpm isn't going to hurt it.
Old 07-02-2016, 05:04 PM   #5
Revvv's Avatar
With my luck lately parts would detonate.
Old 07-02-2016, 05:53 PM   #6
jeno's Avatar
Lol gotta be positive
Old 07-02-2016, 06:03 PM   #7
Revvv's Avatar
I'm positive that I have had more bad than good happen in the past few weeks. Lol
Old 07-02-2016, 07:25 PM   #8
jeno's Avatar
Well let me ask how does she run any issues with her does she purr and if so well then let her roar! In all honesty these cars were meant to driven hard not abused but driven
Old 07-02-2016, 08:07 PM   #9
Revvv's Avatar
The engine runs flawless. I have a whine in the transmission I can't find, but the engine it beautiful.
Old 07-02-2016, 08:25 PM   #10
jeno's Avatar
Mine does sort of too don't be afraid to get on it it will help clear the engine out
Old 07-02-2016, 08:28 PM   #11
Revvv's Avatar
...and empty the gas tank.
Old 07-02-2016, 08:32 PM   #12
Incoming thread posted by Revvv, titled: "Intake Manifold Blew at Red line. Please HELP!!!"
Old 07-02-2016, 08:50 PM   #13
Revvv's Avatar
Nooooooooooo!
I'm not abusing the car. Now, if I blow the intake manifold off I know how to handle that.
Old 07-02-2016, 10:29 PM   #14
Torino's Avatar
Jeno he is concerned that a few engine parts will get cleaned out! 😂 Revvv I see your point but you have more restraint than most of us!!! Hopefully your luck changes soon!
Sent from my SM-G7102 using Mustang Evolution mobile app
Torino is offline   Reply With Quote
Old 07-02-2016, 10:33 PM   #15
Revvv's Avatar
Thank you Torino. Things will get better or I will move to PA and beg for a job at American Muscle
Old 07-02-2016, 11:07 PM   #16
Revvv's Avatar
If I was not running the stock exhaust my restraint would be tested. I have to admit, I love the sound of a 2v Mustang. Right now the growl comes from a slow cruise with the top down.
Old 07-03-2016, 07:26 AM   #17
fenixignition's Avatar
If your car is stock it can handle just below the red line just fine. It's the red line where the owners manual says you may cause damage. Either way once it's warmed up, make sure you don't give it wot until your above 3k rpm if you wanna be safe, and then let loose to heat everything up and blow out any carbon deposits. How many miles on the engine btw?
Sent from my SM-G920V using Mustang Evolution mobile app
2002 GT 5sp. 16x,xxx miles
Old 07-03-2016, 07:28 AM   #18
Oh and to answer your question, the trick is to grab some rubber hose and small zip ties, and wrap the hose around the cable at the gas pedal to take up the slack, so that the pedal sits a bit higher. After that, maybe don't WOT too hard since your tugging on the cable and not hitting the floor first.
Old 07-03-2016, 09:10 AM   #19
Revvv's Avatar
It is about to turn over 151000.
I know for certain that too end has all new gaskets, and that the timing chain, guides, etc are new. I have the receipt from the previous owner. The engine decided to make a little noise while he was out of town and paid to have the entire timing system replaced and the top end looked at about two year ago.
Old 07-03-2016, 09:15 AM   #20
Revvv's Avatar
If I pull any length out of the cable it will be done at the throttle body. I can put on a new ball end just as easy, if not easier than putting hose behind the pedal.
I really wanted to make sure the extra wiggle room was normal. My boot rests perfectly at the moment.
Throttle slack LuvStangs Pre-2005 V6 Mustang 74 05-23-2013 10:33 AM
fixing the throttle cable slack? Crowned1 Pre-2005 V6 Mustang 6 05-21-2013 09:26 PM
Cultch pedal slack Matney10 Pre-2005 V6 Mustang 18 02-02-2012 11:41 AM
Taking Up Slack In Accelerator Pedal OsirisGuy Pre-2005 V6 Mustang 20 10-23-2007 05:43 PM
Anyone here every slack lined before? fast64 The Bar 15 12-29-2005 05:59 PM
04:48 AM
