How to remove automatic shifter - Mustang Evolution
Old 07-02-2016, 05:09 PM   #1
I can't seem to figure out how to remove the automatic shifter the whole assembly .
I removed the tow torx screws but not sure what I am missing ...
Any help ?
Hello is offline   Reply With Quote
Old 07-02-2016, 07:46 PM   #2
It looks like I was mistaken when I told you that the shifter end of the cable was accessed from inside of the car.It looks like the shifter protrudes out through the transmission tunnel, and the entire shift cable is accessed from the underside of the vehicle.
Did you remove the cable and determine that it is not the source of the sticking shifter?
The repair manual does not have any specific instructions for removing the shifter mechanism... So it must be self-explanatory. There are likely more fasteners holding it down that haven't been removed yet.
Old 07-02-2016, 09:01 PM   #3
I can see the end of the cable inside the car . I pulled on it with needle nose pliers and it seemed good ! The actual plastic assembly squeeky and I think might be the issue but no idea how to remove it llol
Old 07-02-2016, 09:04 PM   #4
This is underneath the plastic assembly . I can see where to disconnect the cable but I don't have much room . Need to know how to remove that while assembly so I can replace it
Old 07-02-2016, 09:24 PM   #5
Keep in mind that my cars are manual transmission... And I'm using a repair manual as a reference.
Those photos that you posted don't look like the shifter photos in the repair manual that I'm looking at. What they show in the manual is, the cable bolts onto the shift arm of the transmission, so it is adjustable. The end of the shift cable that attaches to the shifter mechanism, is held on with a nylon locking sleeve which is pried off with a screwdriver for removal.
I could be mistaken, but the cable that you photographed looks like the parking brake cable???
Old 07-02-2016, 11:18 PM   #6
This is underneath the car.
The other pictures were of underneath the actual shifter . I took the whole centre consol out to see how it was still attached.
I feel if I take off the metal plate it will come off but looks like there's a gasket maybe foam
Old 07-02-2016, 11:35 PM   #7
Maybe this will help.
http://forums.corral.net/forums/gt-s...al.html#/enter
If you Google "How to replace automatic shifter 99-04 Mustang" there are some threads to read, and Youtube videos to watch.
Sent from my SAMSUNG-SGH-I747 using Mustang Evolution mobile app
Old 07-03-2016, 09:29 AM   #8
Thanks but that appears to just be to replace the shifter nob .
I found one video of someone removing one but it didn't have the two posts like mine that appear to be attached to the car hah oh man something so simple is difficult
Old 07-03-2016, 09:57 AM   #9
Maybe just focus on removing the cable so that you can determine if it is the cause of the problem.
Here is a thread with basically the same instructions as the repair manual.
http://www.stangnet.com/mustang-foru...-cable.828126/
non automatic headlights/automatic turn off silverskoundrel General Mustang Discussion 11 09-07-2013 09:13 AM
To remove fogs or not to remove fogs SystemCritical 2011-2014 Mustang GT 64 05-23-2013 07:10 PM
How to remove stock shifter knob from 1999 mustang gt manual? tung 1996-2004 Mustang GT 3 08-18-2009 08:00 PM
Automatic shifter help!!!! PonDog15 Pre-2005 V6 Mustang 15 11-30-2005 11:19 PM
Automatic Shifter Bezel Monkey Mustang Parts for Sale and Wanted 4 02-08-2004 05:30 PM
06:22 AM
