Oil pressure sensor - Mustang Evolution
Old 07-03-2016, 10:25 PM   #1
Jay180's Avatar
Oil pressure sensor
Name:	ImageUploadedByMustang Evolution1467606303.388049.jpg
This wouldn't be the oil pressure sensor right? I'm currently trying to install an oil pressure gauge and I can't find any pictures that would be clarify
Jay180 is offline   Reply With Quote
Old 07-04-2016, 03:42 AM   #2
fenixignition's Avatar
That would be it.
Sent from my SM-G920V using Mustang Evolution mobile app
2002 GT 5sp. 16x,xxx miles
Old 07-04-2016, 10:57 AM   #3
Ogre's Avatar
Use the set screw / Allen screw at the bottom for your gauge...
Ogre is offline   Reply With Quote
Old 07-04-2016, 11:19 AM   #4
Revvv's Avatar
A real world numerical pressure gauge is not a bad idea. It would also be nice to know the actual engine temp.
---------- Post added at 01:19 PM ---------- Previous post was at 01:18 PM ----------
Originally Posted by Jay180 View Post
Attachment 203103
Where are you installing the gauge?
Old 07-04-2016, 11:55 AM   #5
Jay180's Avatar
The thing is is that the pressure sensor that came with the gauge is smaller than the sensor on the car. As in it looks like it won't screw in. I'm routing it to my dash wanting to screw it on top of the 2 middle air vents
Old 07-04-2016, 01:06 PM   #6
Ogre's Avatar
Lowe's sells brass fittings in the plumbing section that will adapt it to what you need.
Old 07-04-2016, 01:22 PM   #7
Should be a 1/4 NPT fitting. Need to verify tho. Run a line off that, T it, put the stock sensor on one end of the T and run the aftermarket sensor off the other T. That way you don't have a dead gauge and also you have a backup in case the aftermarket one fails you can still verify you have at least 6 psi
Old 07-04-2016, 02:37 PM   #8
Jay180's Avatar
Alright thanks guys I appreciate the help
Old 07-04-2016, 04:13 PM   #9
Ogre's Avatar
Leave the stock pressure sensor alone and use the plug off the bottom shown in the pic. Same results with no "T", and looks stock.
Old 07-04-2016, 05:58 PM   #10
Jay180's Avatar
Name:	ImageUploadedByMustang Evolution1467676696.325419.jpg
That one?
Old 07-04-2016, 06:06 PM   #11
Revvv's Avatar
Attachment 203127
That one?
Yep
Old 07-04-2016, 06:11 PM   #12
Jay180's Avatar
How much oil, if any will, come out?
Old 07-04-2016, 06:17 PM   #13
Revvv's Avatar
I would suggest changing the oil, and while the engine and pan is empty you should only get a drop or two.
Old 07-04-2016, 06:41 PM   #14
Shadetree43's Avatar
I used a "T" on my 14 3.7, installed after sat overnite. Just a couple of drops came out. I also used teflon tape on threads also. No leaks.
Thank you for the info in the allen screw. Was not aware it could be used. If my Autometer sending unit will fit, I'll eleminate my "T".
Shadetree43 is offline   Reply With Quote
Old 07-04-2016, 06:43 PM   #15
Jay180's Avatar
Thanks fellas
Old 07-05-2016, 09:16 PM   #16
Jay180's Avatar
So I tried to put my sensor where you told me and my sensor is still too small I guess it's time for the T
Old 07-05-2016, 09:40 PM   #17
Ogre's Avatar
You need to go to Lowe's and get adapters to step down from the hole where the Allen screw is to the size of your oil pressure fitting. I said that in a previous post...
Old 07-05-2016, 10:04 PM   #18
Jay180's Avatar
Alright haha I thought it would have been a direct fit sorry for my inexperienced mistakes
Oil Pressure sensor Leak Renuco612 2011-2014 Mustang GT 13 08-24-2015 08:25 AM
New oil pressure sending unit, still 0 oil pressure Iryan7 Pre-2005 V6 Mustang 9 07-13-2015 03:15 PM
fuel pressure sensor clamp samuelsmith Mustang Parts for Sale and Wanted 0 04-26-2013 11:04 AM
Fuel Pressure Sensor Help Jumpshot 1996-2004 Mustang GT 8 04-08-2013 08:04 PM
fuel line pressure vs rail pressure Sirtat 2005-2010 Mustang GT 2 01-10-2012 05:03 PM
07:44 PM
