Fuel Filter Quick Disconnect - Mustang Evolution
Old 07-06-2016, 10:10 AM   #1
Torino's Avatar
Going to change my fuel filter soon and wanted to know which size quick disconnect tools to buy...seems like a simple question but I am overseas and I want to have all the stuff for my projects at the house when I arrive...can't waste vacation time running back and forth to the parts store!
Sent from my SM-G7102 using Mustang Evolution mobile app
Torino is offline   Reply With Quote
Old 07-06-2016, 10:29 AM   #2
The fuel lines are connected to the filter with clips, so you won't need any quick-connect tools, just a small screwdriver.
Old 07-06-2016, 12:42 PM   #3
Torino's Avatar
From the videos that I have seen those clips help hold the lines in place and are not what allows them to click and lock together...different videos have used different tools to do the job but they do not mention the diameter of the tools that fit the lines. I don't want to spend extra money buying the kit that has multiple tools when I only need 1 or 2 at the most!
Old 07-06-2016, 01:02 PM   #4
Slater2111's Avatar
You can go to your favorite auto parts store and get the multipack of disconnect tools. But the one you need is 5/16 inch
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Slater2111 is offline   Reply With Quote
Old 07-06-2016, 01:21 PM   #5
Now that you have jogged my memory, I believe that you are correct, and the disconnect tool is necessary. My truck doesn't require the tool but my Mustang does.
In any case, I believe that the tool is 5/16. You can buy an inexpensive plastic set of disconnect tools that have every size that you would typically run across.
Old 07-06-2016, 02:14 PM   #6
Torino's Avatar
Thanks guys...that is the info that I needed. I have a few projects planned for my baby when I get home and I want to have everything waiting for me when I get home! No running back and forth to the store because I plan on having plenty of beers while working!
Old 07-06-2016, 03:05 PM   #7
Do you just disconnect the filter and replace or are there other steps before hand?
Hello is offline   Reply With Quote
Old 07-06-2016, 06:08 PM   #8
jeno's Avatar
Just disconnect it with the tool put the new one on
Sent from my SM-N910T using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 07-06-2016, 08:03 PM   #9
You can relieve the pressure by disconnecting the inertia safety switch in the trunk, and starting the engine, and letting it run until it dies. This will minimize the amount of fuel that sprays out when you remove the fuel lines.
Make sure to reconnect the switch before trying to start the engine after the filter is replaced.
Old 07-07-2016, 07:58 AM   #10
Torino's Avatar
I found this video on youtube but I am not sure if my '01 will have that same connection (according to the video it should) to relieve the pressure! Oh and just as an FYI I picked up the K&N fuel filter #PF-2000 for the 99-04 models.
https://youtu.be/68-tJajLCT0
Old 07-07-2016, 08:13 AM   #11
Strange Mud's Avatar
just food for thought...often an entire kit will only cost a few $ more than just one.
Old 07-07-2016, 10:37 AM   #12
Torino's Avatar
Going to give this one a try!
Old 07-07-2016, 11:08 AM   #13
ch0wd0g's Avatar
spend the extra few bucks and get the kit. I did that for my 98 GT when upgraded the fuel pump. I found that i had a use for the others at a later date and was glad i had them.
ch0wd0g is offline   Reply With Quote
Old 07-07-2016, 11:51 AM   #14
Yes. You can use the Schrader valve on the fuel rail to relieve the pressure. The easiest way, is with a fuel pressure tester like he used in the video. If you don't have one, they are usually available as "loaner" tools at the auto parts stores.
Another, much more messy technique, is to poke a small nail, or something similar, into the Schrader valve and let the fuel spray out, much like removing air from a tire.
Old 07-07-2016, 12:29 PM   #15
what about pulling fuel pump relay then trying to start? I know on my 2012 that will prevent it from starting.
Old 07-07-2016, 12:41 PM   #16
Torino's Avatar
Thanks straybullitt! I guess that a fuel pressure tester will be added to the list! I have all sorts of one use tools that are waiting to be used again! 😂
Old 07-07-2016, 03:01 PM   #17
That would also work. Any method that will prevent the fuel pump from turning on is acceptable.
I remember that I read about disconnecting the fuel pump inertia safety switch and decided that I would give it a try, even though I have a fuel pressure tester that would have done the job equally as well. The switch is easily accessible in my gutted trunk.
I was shocked at how long the engine idled with the fuel pump disabled! It had to have been at least a couple of minutes! Haha. Crazy car!
Old 07-07-2016, 03:08 PM   #18
It will come in handy over the years. The same with a full set of disconnect tools. If you ever need to remove the fuel rail, it requires a different size tool than the fuel filter. And the air conditioning hoses are a different size as well.
If you work on your own stuff, you can never have enough tools.
boss mani and fuel disconnect tool nosympathy 2011-2014 Mustang GT 20 06-11-2013 10:37 PM
Where can i buy a fuel filter disconnect tool? sixpac General Mustang Discussion 6 07-30-2012 05:44 AM
12:06 AM
