Grounds on car - Mustang Evolution
Old 07-10-2016, 01:48 PM   #1
Grounds on car
98 ford Mustang gt. Anyone know we're the grounds are on the car. Can't find diagram anywhere. Or how do I check with a volt meter if it's getting proper ground. Help please
Sent from my SAMSUNG-SM-N910A using Mustang Evolution mobile app
clean4.6gt is offline   Reply With Quote
Old 07-10-2016, 02:26 PM   #2
Ground for what. ?
Hello is offline   Reply With Quote
Old 07-10-2016, 03:23 PM   #3
The grounds for the car, like engine ground location, chassis ground, etc etc... im having a charging issue. I've replaced alternator and battery 2 times, and I've replaced battery terminals, I've replaced alternator pig tail.. When I first start the car it volts read 14.2.. as I turn on headlights it drops to 13.6 and never recovers to above 14, then when I turn the ac on it drops lower to like 12.7v and never recovers back to 14v even if I Rev the engine and hold it it only climbs to 13.6v. I've change the serpentine belt thinking it may be slipping under a load but still sam issue. So I'm curious as to where the grounding locations are for the body, chassis, transmission ground, I've watch some how to videos on you tube to check to see if the car is properly grounded. What should the mustang be and how should I check it on a volt meter. A wire diagram would be great.
Old 07-10-2016, 04:47 PM   #4
Revvv's Avatar
It doesn't sound like you have a problem with the grounding on your engine. You may have a short somewhere, but...
Old 07-10-2016, 04:56 PM   #5
mineralgt's Avatar
I don't think you have a charging issue just using more power as your turn more things on. If it were dropping below 12 volts then there is a problem. Those numbers don't look bad at all for all the power you are using with everything turned on.
mineralgt is offline   Reply With Quote
Old 07-12-2016, 07:51 PM   #6
I've owned the car for 4 years. It's been the same since I got it. All the info I read on it says that under a load it should always hold around 14v. Due you guys think that there may be to long of wires on the alternator pig tail I replaced. I'm still curious to know what the ground readings are for the motor, and chassis, etc,etc. That's been something else I've been reading.
Engine grounds 02StangGT 1996-2004 Mustang GT 2 03-19-2013 06:17 PM
The guy turned in his Car Title and I want to buy his car. How do I get a new Title for the car? stanley General Car Discussion 2 04-10-2010 10:45 AM
Size of bolt that grounds computer Brent Pre-2005 V6 Mustang 3 12-12-2005 02:32 PM
this car isnt a parts car Rellik The Bar 11 10-09-2003 10:04 PM
Car Audio ---> Car Video Ken Mustang Audio & Video 2 05-07-2003 11:47 PM
04:04 PM
