Car still idling rough ..!!! - Mustang Evolution
Old 07-10-2016, 02:32 PM   #1
smsstang's Avatar
When I start up that mistang it goes from 1000 to 900 and keeps surging up and down sounding like if has a cam . Once I give it some gas it levels out but higher than 900 . After awhile it will go down to about 900 once it's heated up . Since that I've replaced a cop that could have been bad with a brand new one and still doing it . I have no clue why it's doing this on start up .
smsstang is offline   Reply With Quote
Old 07-10-2016, 04:32 PM   #2
Jon3.7's Avatar
Either vacumn leak or iac
2013 GT, A6, VMP Tuned, Lethal O/R H pipe, GT500 Mufflers
2016 EB, A6, Steeda Tuned, Steeda CAI
Jon3.7 is offline   Reply With Quote
Old 07-10-2016, 07:25 PM   #3
smsstang's Avatar
Ok is there a way to check if it's iac?
Old 07-10-2016, 08:09 PM   #4
Jon3.7's Avatar
unplug it and see if it acts any different. You can also take it off and clean it out.
Old 07-10-2016, 11:28 PM   #5
smsstang's Avatar
So unplug it while it's running and if idle changes then it's iac ?
Old 07-11-2016, 05:29 AM   #6
jeno's Avatar
Yes while it's running if it runs the same then it's the iac
Sent from my SM-N910T using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 07-11-2016, 07:15 AM   #7
smsstang's Avatar
Ok will try that out today thanks
Old 07-11-2016, 06:42 PM   #8
smsstang's Avatar
So had the car running unplugged the iac and it dropped down to a very low idle never died but very low ?
Old 07-11-2016, 07:43 PM   #9
jeno's Avatar
Well then the iac is working you have other issues maybe a vacuum leak
Old 07-11-2016, 07:45 PM   #10
smsstang's Avatar
What's a easy way to check for a vac leak ?
Rough idling 98stang6banger Pre-2005 V6 Mustang 4 01-21-2016 07:46 AM
Car idling rough p2195 and p2197 hdez41 2011-2014 Mustang GT 63 08-30-2015 01:21 PM
Rough idling Xaperez100 Pre-2005 V6 Mustang 7 02-11-2013 05:48 PM
Rough Idling greenmustang27 Pre-2005 V6 Mustang 2 05-14-2009 09:29 AM
Rough Idle and Rough Start Cajun JungleBoy Pre-2005 V6 Mustang 3 04-23-2006 11:33 PM
12:48 PM
