High Flow Fuel Rails - Mustang Evolution
Old 07-12-2016, 12:19 AM   #1
Torino's Avatar
I am looking for opinions on the high flow fuel rails for the 4.6L engine...preferably from those that have used them! I am strictly a street (daily driver) person but I wanted to know if these would improve performance any. I am not expecting huge gains, just better fuel flow...also would it benefit to change the injectors and fuel pump as well or will the stock set up work just fine?
Sent from my SM-G7102 using Mustang Evolution mobile app
Torino is offline   Reply With Quote
Old 07-12-2016, 04:38 AM   #2
Mile high JDF's Avatar
Are you N/A or boosted? The stock rails, pump, and injectors should work just fine if you're N/A
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-12-2016, 09:37 AM   #3
Torino's Avatar
All components are working great...just wondering if there was an added benefit other than looks or if people experienced problems with them. Saw the blue ones by BBK and thought they would look good with the other BBK bolt on parts.
Old 07-12-2016, 12:30 PM   #4
Revvv's Avatar
You can run a 6" pipe for a fuel rail if you want to. Once the system is pressurized the injectors are limited to the amount of fuel they can spray. The same goes for your fuel pump.
So if you are after looks only, then you will be fine. Do not expect any gains to be made.
Old 07-12-2016, 01:57 PM   #5
Not needed. Zero performance benefit. Not to mention if you need to go bigger than the stock rails can handle you should be going return anyway.
Old 07-12-2016, 02:37 PM   #6
Torino's Avatar
Thanks guys!
Old 07-12-2016, 02:43 PM   #7
Torino's Avatar
Seems that all the cool stuff that I want is usless! 😂 Unless I want to spend hundreds on pretty stuff...which I don't! I rarely raise my girls skirt and my '72 Torino always goes to the cruise-ins!
need help with custom fuel rails, fittings, fuel pressure gauge tire Pre-2005 V6 Mustang 2 07-13-2015 04:32 PM
High Flow Fuel Rails SELENE 2011-2014 Mustang GT 9 09-01-2013 01:19 AM
Aftermarket Company makes Fuel Rails!!! white95v6 Pre-2005 V6 Mustang 27 12-07-2005 01:01 PM
09:32 AM
