Yes. You will need the valve covers too as they will be 13 hole instead of 11 like your Romeos. You'll also be going to the 4 thread spark plug holes vs the 8 in your 2004 heads. This is fine if your friend actually used a torque wrench and anti seize when he did his plugs.
You also might need new hardware for your timing cover but the cover itself will line right up.
