oil change - Mustang Evolution
Old 07-21-2016, 08:50 PM   #1
oil change
hello everyone i registered here for my nephew who bought a 2000 mustang gt with a 4.6 liter sohc engine and we changed the oil we checked it first and it was in the range and when i drained it only about 2.5 quarts came out???? wtf?? i understand its supposed to be like 5-6! the gomer at ford says it should take 6 quarts to fill it, well it took like 3! plus a touch more for the filter can someone here help explain this to me because i just dont understand it the dip stick says and said the oil was in range at least half way i would love to hear your comments thanks mark
444 intrnl is offline   Reply With Quote
Old 07-21-2016, 09:06 PM   #2
Revvv's Avatar
Do you have the correct dipstick, or is it too long?
Old 07-21-2016, 09:53 PM   #3
dip stick
its a possibility i know he got a 2000 mustang gt 4.6 and a 2000 serpentine belt wont fit we had to get one for a 97 we could have a can of worms here so that being said can anyone of you measure your dipsticks ( no pun intended ) and let me confirm it with ours, please and thank you
Old 07-21-2016, 10:07 PM   #4
Revvv's Avatar
I am actually headed out to check my oil. Bear with me and I will give you a measurement.
Old 07-21-2016, 10:16 PM   #5
quick question while i got ya
hey revv is it a 4.6 4v if its injected? right? i mean they dont use carbs anymore i usually associate 2v.4v as 2 and 4 barrel. i got a feeling we have a different year engine here
Old 07-21-2016, 10:22 PM   #6
Revvv's Avatar
No carbs anymore. 2002 GT 4.6 two valve engine.
Dipstick is 29" from the yellow stop to the end.
The housing or piping sits level with the valve cover.
Old 07-21-2016, 10:23 PM   #7
Revvv's Avatar
Only on a mustang forum will you find a man wondering whether or not his dipstick is too long.
Old 07-21-2016, 10:27 PM   #8
ok
ill swing by my nephews tomorow after work and measure his dipstick ( ha ha ) so you say 2v=2 valve and 4v=4 valve heads? i have been checkin around and one other guy some place else says his is 27" now that would certainly add some oil but let me check tomorow is your dipstick ha ha twisted?
Old 07-21-2016, 10:40 PM   #9
Revvv's Avatar
Yes, the dipstick is twisted. I'm not entirely certain whether or not the oil pans were changed throughout the SN95 body style.
2v= two valve
3v= there valve
4v= four valve.
Welcome to the confusing world of Ford. I'm a Mopar guy lost and in love with Mustangs. I had to learn the terminology as well.
---------- Post added at 12:40 AM ---------- Previous post was at 12:39 AM ----------
4v will only be on Cobras and Mach 1s in our year model cars.
Old 07-21-2016, 10:46 PM   #10
2v
ok well.. ill assume for the moment its a 2v, revvv do you know where the engine serial number is? supposed to be? and thanks for your time really been a big help i hope his stick is too long that would answere alot
Old 07-21-2016, 10:52 PM   #11
Revvv's Avatar
I am certain your nephew has a 2 valve.
As for the serial number; I will have to look that up. If Scotty comes along and sees this thread he will likely know without thinking.
Old 07-22-2016, 09:37 PM   #12
Its gonna be in a spot real hard to see. As for 2V vs 4V, your nephew has a 2V, they are physically very different looking engines. Not to mention they both take 6 quarts to fill.
If you want to see the differences just look up 2001 Cobra engine and then look up 2000 Mustang GT engine.
Now as far as how much oil came out... you did wipe off the dipstick first and then put it back in to check right? And you should be getting a lot more than 3 quarts out of it. At any rate, do NOT run it with just 3 quarts of new oil in it. Get back out there and put the full 6 quarts in. Never measure with the dipstick when doing the oil change, its 6 quarts and that's what you put in it every time regardless of what the dipstick says.
Old 07-22-2016, 09:43 PM   #13
Revvv's Avatar
I didn't consider mentioning that the oil needs to be at capacity.
I knew the faithful and knowledgeable New Edge Mustang guru would make it to this thread and save the day.
Old 07-22-2016, 09:51 PM   #14
Eh... I wouldn't call myself all that, I've been on here way way less than in the past. But thanks for the kind words.
Yeah he needs to be damn sure he isn't running the thing at half oil capacity. That'll turn into a bad time real fast.
Old 07-22-2016, 09:52 PM   #15
thanks gentlemen
i will do it scott i knew it wasnt right it couldn t be ill put six quarts in it and while i am at it ill measure the dipstick i really appreciate the help fellas i drive a diesel pick up so this new hot rod crap is new to me and my nephew, it didnt seem to have a deep sump oil pan but still it was very little oil from a normal vehicle once again thanks alot i am sure i will be back with more mustang drama
Old 07-22-2016, 09:56 PM   #16
Revvv's Avatar
If he runs it at half capacity he will get the chance to learn more than he wants about the engine. It will fry bearings, cams, lifters, and every other moving part.
Old 07-22-2016, 10:04 PM   #17
Revvv's Avatar
Bring it on. Some of us enjoy the challenge.
As for the dipstick, the tube could have broken and been replaced with a shorter one at some point.
Ford in general is me to me. I went from Chevy to all Mopar. Like I have said before, I have always had a soft spot for Mustangs. I had a 1964 1/2. My brother had a Fox Body as his first car. I learned that Mustangs are light, nimble, and make great track toys.
If the engine ever pops in my GT I will store and preserve it until I can bastardize it with a V10 or a 6.4 Hemi.
It would be fun to have a HellCat Stang.
Old 07-22-2016, 10:12 PM   #18
old school
i know the old ones but this new generation of things ya never know i love the shelbys of old and all the muscle cars of old but the new stuff is a different animal
Old 07-23-2016, 03:57 PM   #19
Revvv's Avatar
What is the consensus? Status update is needed to stop my curioisity.
Old 07-23-2016, 09:14 PM   #20
29.25 inches from tip to the rim on the handle and its a "T" type handle there is a part no. on the stick its xr3e-6750-ba with 3 qts in it, it read at the top of the range but i put all 6 in today befor i did anything else
Old 07-23-2016, 09:18 PM   #21
Revvv's Avatar
With 6 quarts in the pan, drill a 1/16" hole at the full point on the dipstick.
Something is not sitting as it should. I personally would need a picture to see what the oddity is.
Old 07-23-2016, 09:24 PM   #22
i was just looking over at corral.net another mustang forum and they have quite a bit of misguided info over there i just dont understand why is it so difficult for ford to make a proper length dipstic? according to them ford has changed lengths and amounts like crazy. i looked over there because i googled the part number on the stick and that is a link to it
Old 07-23-2016, 09:27 PM   #23
Revvv's Avatar
Interesting.
I am curious to know why the belt length on the car you are working on is a different length than it should be.
If it is shorter the car could have underdrive pullies. If it's longer there are a lot of questions in my mind.
Old 07-23-2016, 09:41 PM   #24
yea i am really confused on all this revvv if you get a chance put that dipstick part no. up and google it and one of the links was to another forum read what they had to say about it if ya want someone said it was superceded by another dipstic part number heck even a vw beetle takes 4 qts of oil. my nephew is off at maine corp duty this weekend i dont know if the new belt was longer or shorter but they gave him a 97 belt and it fit thats all i know, i also dont know what kind of moron looked up the belt number either
Old 07-23-2016, 10:05 PM   #25
Revvv's Avatar
From 1999-2001 the Ford part number should be 1R3Z-6750-BA.
I have an 02 GT, and apparently there is a difference somewhere. I have no idea what or where the difference is.
Try adding this to your oil next oil change Joe Dirt 222 General Mustang Discussion 18 05-23-2015 01:04 PM
Smell oil burning thru interior air vents after oil change dentman43 2011-2014 Mustang GT 7 10-27-2014 08:36 AM
First oil change what oil sinister 2011-2014 Mustang GT 48 08-18-2014 07:57 AM
To change or not to change? Djulin 2011-2014 Mustang GT 13 04-03-2013 10:20 AM
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 11:37 AM
02:05 AM
