99-04 GT or Cobra brakes on a Sn95 - Mustang Evolution
Old 07-22-2016, 09:53 AM   #1
mach5894's Avatar
Has anyone done this conversion and what all do you need to make this happen?
mach5894 is offline   Reply With Quote
Old 07-22-2016, 03:30 PM   #2
Mile high JDF's Avatar
For front Cobra brakes all you need is the calipers, pads, rotors, and mounting brackets. Plenty of places sell used pulloffs for $300- $400 l. You may need a Cobra master cylinder depending on the year of your car.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-22-2016, 09:30 PM   #3
99-04 GT brakes are dual piston but not a bigger rotor like the Cobras. To do the front brakes you need the calipers and caliper brackets. And obviously rotors and pads.
For the rears the 99-04 GT is the same as any 94-98 GT. To upgrade to the Cobras you need to pull the axles, change the caliper bracket mount and then you re-use the calipers with Cobra caliper brackets and the correct Cobra rotors and thinner Cobra specific pads since the rotor is now vented and fatter.
It is a big difference, I would not waste my time with the 99-04 GT front brakes. The difference between the 94-98 GT and the 99-04 GT is marginal. Going to the full 94-04 Cobra/Bullitt/Mach setup is a very big difference in braking.
2000 Mustang GT Steeda build #48. Bolt ons, suspension, Novi 2000.
Old 01-28-2017, 10:46 AM   #4
mach5894's Avatar
Do I need to change the hub assembly or spindle for the front brakes? Going from 95 GT brakes to 95 cobra
Old 01-28-2017, 11:19 AM   #5
Hmm actually I do not know.
Sent from my SM-G925V using Mustang Evolution mobile app
Old 01-28-2017, 12:33 PM   #6
No. They're all the same. You need the Cobra caliper bracket, caliper, rotor and pads. That's it. And 17" rims or better.
Old 01-29-2017, 08:37 AM   #7
mach5894's Avatar
Same master cylinder?
Old 01-29-2017, 01:52 PM   #8
They're not the same but the GT master cylinder works fine.
Old 01-30-2017, 07:41 AM   #9
mach5894's Avatar
Would the cobra master cylinder bolt right up? including brake lines? I'll be tracking the car so idk if the GT master cylinder would still be good for that if it is that a bonus, just curious what I would run into if I swapped master cylinders
Old 01-30-2017, 11:55 AM   #10
I believe that the only difference between master cylinders has to do with whether or not the car is equipped with ABS/Traction control
And I think that my Bullitt, which came with Cobra brakes, has a Cobra ABS pump module.
I don't think that there will be any difference in the braking performance using the Cobra calipers/rotors with the existing GT brake plumbing.
SN95 Cobra 96-98 sub frame connector experience / recommendations Spiney SVT Mustang 5 10-11-2013 09:38 PM
Sn95 Cobra vs. Mach 1 SwatKatz901 1996-2004 Mustang GT 5 07-13-2013 11:37 AM
Sn95 Cobra running hot Brad.krieg SVT Mustang 7 10-17-2012 04:35 AM
Sn95 cobra shirt jwhayne0001 AmericanMuscle 5 11-07-2011 12:02 PM
06:56 PM
